[Mod]XHP35 HI, 86mm reflector, H2-C driver, & a recycled host.
11 posts / 0 new
FmC
FmC's picture
Last seen: 3 hours 53 min ago
 It's been a little while since I done a decent mod, & I've been keen to get something together.
 I had a spare XHP35 HI laying around that I robbed from my PK26 upgrade, & I wanted to suss out it's potential as a thrower.
 The new H2-C driver from KD looked like a great option, & it hit the mailbox on Friday. Jensen567 had done a bit of tweaking with the driver, & it looks like a great performer, with good efficiency.
 I decided to re-use a modded host that I've used a couple of times now, as it's perfect for this combo. It's an "L3", which was sold under the Solarstorm & Fandyfire brands a few years ago. It uses a 2S3P cell arrangement. I transformed it into a single-LED thrower a while ago, where it produced 814k of throw with an XPG2, & since then it has been host to an XHP 50 & XHP 70 as well.
 Today, I started by changing the sense-resistors on the H2-C driver to a combined R030 value, which gave a ~2.3A maximum to the XHP35, when I bench-tested it with my UNI-T clamp meter.
I'd previously made a driver caddy, using the stripped L3 driver board, a couple of PC motherboard stand-offs & some copper scraps;
After a little prodding around, I found that grounding pin #1 of the MCU could be used for an E-switch.
With a few slices of heat-sink cube, the driver was sandwiched in place;
I re-used a 32mm Noctigon that had already been altered to fit the heat-sink;
I'd previously tested the ideal focus height with this reflector, which is about 0.030", & already had a centering ring & shims to suit.
Assembled light, with Convoy S2+ for size comparison;
 Performance;
* 2256 Lumens, using my "pipe-meter"
* 510k Throw (1428 meters).
 Beamshots; looks like a furry friend wants to be in the spot-light tonight!
Cheers Beer Smile
Edited by: FmC on 06/25/2017 - 05:15
MRsDNF
MRsDNF's picture
Last seen: 6 hours 16 min ago
WOW. What a beast. Love the mods you have done to this light to get it working. Well done. Thumbs Up
luminarium iaculator
luminarium iaculator's picture
Last seen: 5 hours 42 min ago
That is a modd Thumbs Up
EasyB
Last seen: 4 hours 46 min ago
Nice mod and result. Sort of like a mini TN42. I particularly like the heatsinking of the driver and figuring out how to use an e switch. So the e switch changes the modes just like tapping a clicky switch would?
If you don’t mind, I’m curious how the XHP70 performed in this reflector. Was the emitter sliced and could you give the throw number?
pinkpanda3310
pinkpanda3310's picture
Last seen: 10 hours 5 min ago
Very nice. Did you use an KD86 OP reflector with the xhp’s ? If so did it still have a donut ?
CRX
CRX's picture
Last seen: 3 hours 8 min ago
Nice build Thumbs Up
BobbyMK
BobbyMK's picture
Last seen: 2 hours 38 min ago
Awesome!!!
I always wanted to use this reflector in the D01 but i was never able to find the right adapters.
 Olight i3s, Olight S1, Olight S Mini, JetBeam Jet-1, BLF 348, Astrolux S41S, UF SK-98, Convoy S2+ 3*XP-G2, Convoy S2+ 3*XPL, Convoy S2+ 219CT, Convoy M1, Convoy C8, Brinyte B158, Courui D01, Convoy L6, Noctigon M43
NeutralFan
NeutralFan's picture
Last seen: 20 hours 11 min ago
Very nice mod FmC. I like how you were able to re-use so many parts.
I’d rather use my flashlight around the house than turn on the lights.
Jensen567
Last seen: 7 months 1 week ago
Nice mods! Glad to see someone using my data for a real build too. Interesting discovery on the MCU pin 1 for changing modes, I will have to update my post with that info.
FmC
FmC's picture
If you don't mind, I'm curious how the XHP70 performed in this reflector. Was the emitter sliced and could you give the throw number?
Yes, the E-switch mod scrolls through the modes, but if it's left in any mode for more than a half a second, it requires a double press to start the mode scrolling again. I really don't know what the pin function is that I'm beating on, but it seems to do the trick Smile
I did use the OP version of this reflector with the XHP 50 & 70, but don't seem to have written down any performance numbers. The 70 was sliced, & was a nice light, but they were not driven to the max with a FET driver.
pinkpanda3310 wrote:
Very nice.  Did you use an KD86 OP reflector with the xhp's ?  If so did it still have a donut ?
The OP reflector masked the older XHP donut hole fairly well - I think it was only noticeable on a wall in very low output.
djozz
djozz's picture
Last seen: 1 hour 45 min ago
Very good mod! Lots of clever and handy stuff for a great result. Smile
