Another almost finished project
Nice work.
Some copper is gummy and will grab the tool edge when drilling, same thing happens with acrylic plastics. i dull the cutting edge with a stone to solve this. Here are some additional tips for machining copper: copper tips
Dull bits and wax…!!??? Oh I will never get off this steep learning curve :person_facepalming:
I read some of the suggestions and balked at the milk suggestion :open_mouth: but hey, I might just try it one day :student:
The dulling of the tool bits only really come into play when using carbide inserts or carbide tipped tools. It won’t help with a HSS tool. And it’s not really dulling it so to speak just take a stone and barely break the sharp edge.
Thanks for explaining further bluechips :+1: I’m finding even the smallest of variables can change the way a piece will cut.
good work pp
different angles needed for copper brass ect…
Are you sure this applies to copper? I have read that the tools should be as sharp as possible, otherwise the copper starts to “smear” all over the place due to the rubbery consistency. I also experienced the same thing.
With brass however, it is common to dull up the tools so the tool doesn’t get sucked into the material.
Nice build mate. Where do you buy your metals from? I have been looking for solid copper tubes to make heat sink out of.
I go to a local place called Robert-Cameron. They are one of the few places here that stock a lot of odd materials and odd sizes not just the common ones. I might pay slightly less if I find it online but then I would have to wait for delivery :weary:
I got some work done on the switch. It’s kinda big and doesn’t mesh well with the head but oh well, add it to the list of ‘better ways of doing it’.
I lathed up a hole punch to make the right size rubber boot
I also cut a foam packer to stop the batteries rattling since there is no spring in the rear.
Press fit for the switch retainer?
Yes. I don’t think I’m talented enough for threading in that small pocket. :stuck_out_tongue:
Unfortunately I’m with you on that.
I fitted the electronics tonight. My mind wasn’t in the right headspace when reflowing the leds so it was a bit messy. I displaced a dome with tweezers on one of the leds, i’m considering dedoming all of them. I also couldn’t figure out why it wouldn’t turn on when I was finished so after some head scratching found I missed a solder jumper on the driver for 2s. So it is functional and i’ll tweak it here and there a bit.
Wow, that is one sweet looking light. The knurling looks like its cleaned up a treat. :+1:
Whats the light on the far left?
Wow that is beautiful, and it blends in nicely with your collection also. Did you make any of the others?
good job pp
Thanks Moose. The fat left one is a fivemega cooly, currently running mtg2, q-lite, 2x 26350.
Can you tell I like 26650 lights … :smiley: No I didn’t make any of the others, modified 1-2 but not made.
Thanks ltp :+1:
I feel your days of buying lights is nearly over. :slight_smile:
Lol, don’t worry I still see new lights come to market and think “ooooh shiineey” :money_mouth_face:
When I see you turning out unique lights as good as any custom light you can buy, well I’ll let you answer the rest. :smiley:
