Sorry, BG has marked this as unbeatable deal now so points can not be used.
Xiaomi Redmi Note 4 Global Edition 5.5-inch 4GB RAM 64GB ROM Snapdragon 625 Octa-core 4G Smartphone
This phone is now in preorder for $188.99 and BG points can be used to lower the price even more:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$160.64 |
$158.75 |
$156.86 |
$154.97 |
$151.19 |
This is official Global version (with european LTE band B20), and EU charger.
Specs highlights:
- 4GB RAM
- 64GB storage memory
- 5.5” Full HD screen (403 PPI)
- Snapdragon 625 (octacore, 8x ARM Cortex A53 up to 2.0Ghz, 14nm)
- FDD-LTE bands: B1/B3/B4/B5/B7/B8/B20
- 4100 mAh battery
- fingerprint reader
- all metal case construction
Note: BG specs omit TDD-LTE but I believe there’s no Note 4 version without B38 and B40 TDD-LTE bands.
VP3 can use points….at least it let me bring it down to 27.35….
Edit…in reference to the S41…
Astrolux S41 4x Nichia 219B/XP-G2/XP-G3 A6 1600Lumens Mini LED Flashlight is right now for $23.56 in unbeatable promotion so points do not work.
Lumintop SDmini XP-L HD/XP-L HI 1000LM Rechargeable EDC LED Flashlight
is now in promotion for $36.90. Points do not work.
Holster and USB charging cable (standard micro USB) is included. Flashlight has 4 constant modes and 3 hidden blinkies, max 1000lm, two LED options are available: Cree XP-L HI for better throw or Cree XP-L HD for more light.
Nitecore MT22A XP-G2(S3) 260LM 4Modes Multi-Task Compact LED Flashlight AA
is in preorder and using coupon code 17NTC the price drop to $23.96
3 colors available (the third one is yellow).
Got my S41 yesterday, arriving from California. Works perfectly. Great deal. Thanks.
Convoy Flashlight Headband Headlight Band For 18650 Flashlight Black
is now in flashdeal (meaning: points won’t work) for $2.59
XANES SFL-01 600LM XPG + 2 LED Bicycle German Standard Smart Sensor Warning Light Waterproof Bike Front Light Headlight Flashlight 5 Modes USB Charging Night Riding
is in promotion for $8.39 and using BG points it’s possible to lower the price to:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$7.13 |
$7.05 |
$6.96 |
$6.88 |
$6.71 |
No more deals for Astrolux A01?
Sorry, promo ended for now. Now alu version is at $9.95. You can use 4BLF code to lower price or use points:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$8.46 |
$8.36 |
$8.26 |
$8.16 |
$7.96 |
Astrolux K01 CU XP-L 7/4modes 1400LM Tactical EDC LED Flashlight 14500
is now for $28.95 and using BG points it’s possible to lower the price even more:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$24.61 |
$24.32 |
$24.03 |
$23.74 |
$23.16 |
Three LED tints available: 1A (cool white), 3D (neutral), 5A (warm).
using the above link price drops to $21.95 and using BG points the price can be lowered further:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$18.66 |
$18.44 |
$18.22 |
$18.00 |
$17.56 |
Update: Deal expired. Now coupon available - send me PM for details
Nitecore NU05 35LM 4Modes Multiple Scenarios USB Rechargeable Headlamp Mate Kit
Using this link the price is $10.95 (for light only) and $15.95 (set: light + bike mount + headband + USB cable).
BG points work so it’s possible to lower the price further:
Light only:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$9.31 |
$9.20 |
$9.09 |
$8.98 |
$8.76 |
Set:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$13.56 |
$13.40 |
$13.24 |
$13.08 |
$12.76 |
This small light is micro USB rechargeable, has 4 light modes (5 total when indicator blink is included), 2 white LEDs and 2 red LEDs with flasher this makes it ideal for use as an emergency and safety light.
Runtime is stated to be max 20h (red indicator blink), minimum at 1h for 35lm constant white light.
It’s extremely compact (29.5mm x 30.3mm x 16.3mm/1.16” x 1.19” x 0.64”) and weights only 10 grams (0.35 oz).
Portable USB Rechargeable Dimming LED Mosquito Insect Repeller Light Outdoor Emergency Camping Lamp
is now in preorder for $7.99 (target price set at $13.99) and using BG points it’s possible to lower price to:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$6.79 |
$6.71 |
$6.63 |
$6.55 |
$6.39 |
This is dual color light - standard white LEDs and yellow 580nm LEDs. Yellow light attract less insects than white light but most importantly does not disrupt human circadian rhytm - blue light present in white LEDs suppress the secretion of melatonin, see here for example: Harvard Medical School : Blue light has a dark side
Besiter 20000mAh QC3.0 Quick Charge Dual USB LED Display Power Bank with Type-C and Micro Input
using coupon code 15K6X price drops to $29.74 (-$5.25).
Xiaomi Mi Note 2 5.7 inch Dual Curved Screen 4GB RAM 64GB ROM Snapdragon 821 Quad Core 4G Smartphone
using coupon code note264G price drops to $323.83 (normal price: $399.79).
Spec highlights:
- Qualcomm Snapdragon 821 (Quad Core, Max to 2.35Ghz)
- 5.7” OLED curved display, 77.2% screen-to-body ratio
- 4GB RAM
- 22.56 Mpix camera with 4K video
- 8 Mpix front camera
- 4070mAh battery
- FDD-LTE B1/B3/B5/B7
- TDD-LTE B38/B39/B40/B41
- Full NFC functionality: Read, write, card emulation, P2P
- fingerprint reader in home button
- USB Type C charging port (cable included)
- Quick Charge 3.0 support
- full metal frame
- US charger
Huawei G9 Lite 5.2 Inch Fingerprint 3GB RAM 16GB ROM Kirin 650 Octa core 4G Smartphone
using coupon code BGG9Lite price drops to $131.99
Specs highlight:
- Kirin 650 CPU (16nm, Octa-core: 4*Cortex A53 2.0GHz + 4*Cortex A53 1.7GHz)
- 3GB RAM
- 16GB storage
- 5.2” Full HD IPS screen
- FDD-LTE B1/B3
- 3000mAh battery
iMars™ iM-L2 U5 Motorcycle LED Headlight Hi/Low Beam Strobe Spot Light
use this link to lower price from $14.99 to $8.99 and what’s more using BG points it’s possible to lower the price even further:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$7.64 |
$7.55 |
$7.46 |
$7.37 |
$7.19 |
Specs say it’s capable of delivering 3000lm on high mode and it’s able to run on wide voltage range (12-80V DC).
Astrolux A01 Nichia 219B 102LM AAA Mini Waterproof Keychain EDC LED Flashlight
for VIP2 and above accounts is now for $7.95 and using BG points it’s possible to lower the price even more:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$6.76 |
$6.68 |
$6.60 |
$6.52 |
$6.36 |
