As a side note, it has become very common on ecigs to lock/unlock the device with a fast serie of five clicks. Although it may seem cumbersome on paper it has proven quite fast and efficient. However, it takes a friendly switch - on some lights the side switch is too stiff for such a fast click action.
Long press to unlock is just plain anyway. :person_facepalming:
The UI as it stands could really be improved. I think that could make or break the sale for some people.
BangGood lists this at $110. Any idea if thatās going to be roughly the price?
Any idea how much lower lumens the 219Cs are? The XP-G2s in the Meteor are about 11% brighter than the 219Cs, presumably the G3s in this are a bit better again. Can we expect over 10000lm from the 219C version?
What does turbo drop down to after it gets too hot? Presumably it canāt sustain 5100lm until the batteries die.
The runtime numbers look wrong, as 100lm matches up with 500h. Iām guessing it should either be 50h at 100lm or 500h at something like 10lm. Also 600lm at 14h seems high
Weight is listed at 550g without batteries. With 45g batteries that would make it 730g. That seems very high for the size. For reference the X80 is 510g with batteries and the X45 is 700g. Is it actually heavier than the X45 or is the weight listed including batteries?
