New 4XP Noctigon MCPCB for quad optic
509 posts / 0 new
Charga
Charga's picture
Last seen: 6 days 10 hours ago
I personally don´t care about the driver type in the new D4 – I want the most lumen out of it in turbo mode (hopefully nearly 4400 lumen in the XP-L HI version Evil ); batteries can be recharged! Big Smile
' Lumen est omen '
Hope is no option!
ToyKeeper
ToyKeeper's picture
Last seen: 4 hours 49 min ago
kiriba-ru wrote:
2 hours? 20% drop? Are you sure?
No. Nobody has numbers yet. Those are made-up.
kiriba-ru wrote:
And no, you cant show all factors in 3-dimensional graph…
I didn’t try to put all factors into one graph. Smile
A 3-dimensional graph can show 3 factors. In this case:
X = brightness level in UI (1-9 of 9, or 1-150 of 150)
Y = lumens
Z = time
kiriba-ru wrote:
Ramping fet is smth very strange. You are trying to manage some parameter that you havent calculated and dont know exactly its value right now. … Cell voltage and R can be tested each time you turn switch on and some standart discharge curved can be used to make lower modes (50% and less) more stable (compensate cell discharge).
I’m not trying to regulate flat lumen output in firmware at all, and I don’t think the D4 firmware does either. I don’t care much if output sags over time. I do try to regulate heat though, because I don’t like to damage the hardware or burn the user.
The firmware could attempt to do flat current regulation on a FET, by increasing PWM level or decreasing PFM ceiling as voltage drops. I’ve done it before. It’s complicated and fragile and not very effective. I don’t find it worthwhile. Current regulation is better handled at a hardware level.
zak.wilson wrote:
  • Good efficiency
  • High maximum current
  • Ability to fit in a pocketable light (let’s call that about 20mm driver diameter)
  • Low price
As far as I can tell, the D4 should have high maximum current, ability to fit in a pocketable light, and low price. The efficiency isn’t going to be as good as a Zebralight, but it should be significantly better than a FET-only driver. So… 3/4 maybe?
zak.wilson
Last seen: 2 hours 50 min ago
The D4 gets 3/4, but it doesn’t have a boost driver. I was specifically addressing boost drivers: good ones are either big or expensive.
Ceilingbounce – flashlight testing and runtime graphs for Android
AEDe
AEDe's picture
Last seen: 14 hours 22 min ago
Does anybody of you use lights except for wow – effect?
As already said this host can carry 5-7W for long time. With 10-15W consumption it would be hot like zebra on turbo. With 20W+ it would be an useless toy. I have 30W pocket light of similar size and overheating(65C) occurs after 17 seconds.
A price of Skilhunt h03 with buck driver is obout 30$. So D4 with dd , pwm and unknown output (becouse of rumping) is only quite expensive host for mod.
After M43, D4 is huge step back for Hank. I understand that d4 is already in production but I hope to see good drivers in the next Hank s light.
-X3-
-X3-'s picture
Last seen: 4 hours 41 min ago
The Meteor is called Noctigon MEteor, and is sold as a semi-high end flashlight with a rather high price-point…
The D4 is sold under Emisar brand, at 35$ for a quad… you can’t expect the same level of technology/efficiency/Russian eforums exigence…
Please, Russian fellows, give us the secret to make 35$ flashlights with magical boost driver fully relgulated at all levels Flat Stare
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
gukase
Last seen: 2 years 7 months ago
I don’t want cheap flashlight. I want to spent my money for good thing that I can use every day.
Trevi_lux
Trevi_lux's picture
The good thing is that no one forces you to buy it ….I do not understand your disgust, if something I do not like I do not buy it and I do not walk all day complaining ….
I like this price at what it offers, so I will buy one. The good thing is that no one forces anyone to buy anything.
(of course, I will buy it only if Hank decide sell in his store….)
AEDe
AEDe's picture
X3 wrote:
The Meteor is called Noctigon MEteor, and is sold as a semi-high end flashlight|
So we waited the same hi level with out analogs on market. But we received another astrolux.
It’s as if the ferrarri will release ford fiesta.
This is disappointment and nothing more/
Agro
Agro's picture
Last seen: 1 hour 31 min ago
If this one is not good enough, buy a zebralight instead. Problem solved.
kiriba-ru
kiriba-ru's picture
Last seen: 12 min 52 sec ago
And be happy with its greenish tint Big Smile
Trevi_lux
Trevi_lux's picture
It’s fun to see how people who pay the price of a mid-range flashlight want to have a zebralight in their hands ….;-)
AEDe
AEDe's picture
M43 also had a price of a mid-range flashlight when it was relised. I dont want another zebralight.
I was waiting for good 4led light with good modern driver for adequate price.
Trevi_lux
Trevi_lux's picture
AEDe wrote:
M43 also had a price of a mid-range flashlight when it was relised. I dont want another zebralight. I was waiting for good 4led light with good modern driver for adequate price.
I really understand you…but the “adequate” price for this, is obviously higher than 35 USD…(is only my opinion, of course)
hIKARInoob
hIKARInoob's picture
Last seen: 22 min 47 sec ago
When the M43 was released there was no cheap variant of such a light. Today we do have cheap/affordable single 18650 triple and quad lights. It might be tricky if the D4 were priced significantly higher than $35, as people might (= will) find it overpriced. It’s a choice I’m sure, but I also understand the disappointment.
AEDe
AEDe's picture
I agree to add 15-20 bucks and even 25 bucks for good driver .
For those who do not want to pay much astrolux and manker exist with similar lights.
and all these have low quality , pwm or dd driver bad ui and so on. And now there is one more such light. So I am not happy )
Trevi_lux
Trevi_lux's picture
I think that the last Manker are not comparable with the last Astrolux…. (better of course the Manker)
kiriba-ru
kiriba-ru's picture
Manker u11 coupon price was $30. Quality host with build-in charger, buck driver, side switch, compact size. Same quality light without manker brand could probably cost much less (utorch?). Make changes to fit quad optics (similar to my quad kit, even less machining in comparing with place for reflector). Optics is not more expensive than reflector. PCB footprint doesnt influence on board self-cost (neverless board is single or quad led). Only thing that can increase price – three extra leds (not big difference between 4xXP-G3 vs 1xXP-L).
Serp
Serp's picture
Yep
IMHO.
Here the question is not in price. Many were waiting for the same functionality as in the Meteor. And not at all for $ 35. Let it be more expensive. Let it be $50-70. The cost of parts for Indigo is about 15-20 dollars. But not everyone can make a circuit board himself Sad
ToyKeeper wrote:
A big part of why I make everything open-source is to make sure nothing has to depend on one developer
The code for indigo 5.0 is also open. But it’s in assembler
Indigo_5.0_final.txt
http://forum.fonarevka.ru/attachment.php?attachmentid=87964&d=1382298519
If someone irritates links to a foreign forum, I’m sorry. It’s just a way to show the best that is for today Big Smile
djozz
djozz's picture
Last seen: 2 hours 31 min ago
No one has ever objected to any link to any forum on BLF Smile
Reyden
Reyden's picture
ToyKeeper][quote=Reyden wrote:
It seems “ramping” is not clear enough to describe the concept. It is unrelated to heat or power regulation. It is an interface style. The Meteor has 9 brightness levels (plus short transitions between each):
I just wanted to say that M43 driver could have full smooth dimming but it’s more technical issue. That’s the first time that I see this graphs, who is the source? I might have missed something because I’ve never used M43 only his free beta version “Indigo” they’re close but not the same regarding to interface and in reality it has completely smooth ramping, as i can see it. So I would prefer not to compare flashlights but more talking about driver features.
Open source? It’s fully open as mentioned above. May be the time for dedicated “Indigo” topic on BLF has come. Spread the light! Smile
kiriba-ru][quote=ToyKeeper wrote:
Now you understand that smaller steps are not reasonable by eye.
This is the key point.
I would pay even more if it worth it. Anyway I can do it by myself, no sense to argue. We are just discussing why we have that we have..
Qwertus
Yes, 2 years we waited Noctigon Meteor M13/M14 and got Noctigon Astrolux. Disappointment.
-X3-
-X3-'s picture
Disappointment is one thing.
Being rude is another…
Calling the D4 a “piece of shit” even before the first user review will not make Hank modify his product Flat Stare
I wish all the Russian crowd that show itself here to bash a new product was that effective to help BLF in making new products… but it seems easier to bash the Q8 for some people…
Reyden
Reyden's picture
If you mean collaboration, as experience shows, it’s more phenomenon than real business. Talking is of little use. But that would be great.
hIKARInoob
Love Love Love Emisar I luv youuuuuuuuuu!!!! Love Love Love
Jerommel
Jerommel's picture
Last seen: 1 week 1 day ago
I think it would be interesting if someone from Russia (or any fonarevka member) would offer to sell those nice drivers here on BLF (and in English language).
Especially in Europe it is hard to find interesting drivers.
KD has a couple, but usually with horrible mode spacing… FT is the same..
AEDe
AEDe's picture
It seems almost nobody on BLF interesting in hi efficiency driver , and convinient for daily use UI. DD and wow effect are the main thing here. It is great pity)
luminarium iaculator
luminarium iaculator's picture
Last seen: 1 day 46 min ago
Yes… Or swapped to fresh one. 4 fresh cells should be enough for some serious use? But I really doubt someone will use turbo that often. We have middle or lower modes if needed.
Jerommel
Jerommel's picture
I’m definitely interested.
But i get lost on fonarevka because of the language…
It seems Eastern Europe has much more experience and knowledge of electronics.
AEDe
AEDe's picture
If you are interested I can try to translate the description of some drivers and send you by PM .
Sure more options would be better although it is a big pain for small seller…
Or Hank could also offer host option so we could build whatever we want Wink
