I have only lost 1 package from gearbest from quite a lot untracked orders . Shipping without tracking isnāt actually slower . Only in Christmas there was a bit of delayā¦
I can imagine a good number of export house employees delaying or cutting short their Chinese new year celebrations to get product out the door after yesterdayās speech and their own countryās warnings to prepare for the worst.
Mine finally arrived yesterday, works but seems to be the same brightness no matter what kind of battery I use. Also the pocket clip kind of sucks. Other than that, nice little light.
Iāve been following your pictures and text and Iām getting a tad lost. My UT01 has a switch which is also ever so slight off-centre to the right, just like yours. Iām trying to dismantle it but having very little luck. I cant see to get the driver out, nor from the mcpcb led side. Also, now that Iāve out it back together, I have to leave it screwed on slightly loose or the light wonāt work - most odd.
Did you have any more luck getting inside your light?
I donāt have the UT01 in hand yet, but from what I have read you are supposed to be able to rotate the switch pad button left or right with tweezers etc. to center it. Then reinstall boot. At least thatās the way I understand it to be.
Hm, thatās what I understood but neither the boot (the boot being the silver ring?) or the button on the board are budgingā¦and Iām not being too gentle either. Iām probably doing this wrong. Iāll keep on at it.
I had the same problem you mention but in the Klarus Mi7. Lithium batteries were no brighter than NIMH or AA primaries. Turned out to be a defective driver. Klarus USA sent me a replacement headā¦then there was brightness.
With these output for reference, does anyone know what would be the approximate corresponding output with a Nichia 219C hi CRI swapped in, using a regular Eneloop.
I got mine two days ago. The switch is clicking but half of the clicks do nothing. Removed the boot and pressed the switch with a plastic something and it was also not responding for every click so I have a bad switch. :cry: The switch was well centered in the hole.
I try to contact with Gearbest.
Take a look at post #18 where āso farā I have found a simple fix that is working. I canāt attest to it being a long term solution yet as Iāll have to use/carry it for a while. But I offer it here in case it helps someone else. It may or may not be the fix for your light, but maybe it will turn someoneās frown upside down
