We’re just scratching the surface of short arc with our LED lights
The only way to get better is to keep building!
The BLF GT will hopefully be on this list soon
Well it’s also #1 for LED flashlights that are available on the market
Guinness apparently didn’t take Ra’s Maxablaster submission because it wasn’t a retail flashlight.
If I ever build a light that makes the top 3, I will call it _blaster
Will update asap.
Unfortunately the Hyperblitz and the Zielscheinwerfer won’t make it on my list since they are both tethered, not “portable”.
If people want to see those lights they can go to your document instead
You’re right, I was looking at the wrong images that weren’t the hyperblitz.
I’m not sure if the Zielscheinwerfer counts as “portable” based on the guidelines I mentioned at the start, do you think it can be carried in one hand for many minutes with the ballast and batteries and everything?
Looks a bit too heavy to me, but idk.
I assumed that the moon blaster was battery powered and portable if it is only 120W, but without images it is hard to be sure.
I will have to look into it.
