Yes you are right when tell its personal which someone will spend in the light, but when tell about the light is cheap or expensive you are totally wrong….
Like I said, I left the DT70 for the super disapoint specs and quality issues and bought a TN40S which costs much more than imalent, but it was very cheap in comparison…….
I avoided:
*Contemplated with DOA light (a great number of users suffered it)
*Needed to mode to use non proprietary batteries
*Bought a light with liar specs which I will regreat at the first moment I’ve turned on
*Needed to support the huge and fast thermal stepdown
*(Possible) needed to create another thread here to get attention by manufacturer to solve my issue (not guarantee if it will solve or not)
Otherwise, with TN40S mine experience was great:
*Not worried about the big bad history of fails
*I put the batteries wich I want without cares if the light will switch on or not
*The specs are higher than informed
*Have NO frills in turbo mode even in painful hot to hold condition, making possible to cool with water or not care about if was a cold and windy night
Yes, that DX80 if going to same way of DT70 is VERY expensive……
The question here is “what is your money for you?”, for me, I not spend my money in some doubtful product, I wil research and evaluate if this produtc deserves my money!
Would love for there to be a smaller version of this that thermal compounds to a copper spacer soldered to the MCPCB. Or just straight to an extra thick mcpcb that sits on a shelf that thermally conducts the body so that it cools off the LEDs as well as the head/handle. The fan/radiator would be integrated into the head aesthetically and it could be modular where it unscrews from the head so you could replace the pump. It could be made stealthy so that you wouldn’t see any pipes and wouldn’t know it was water cooled. That would be amazing, think of the runtimes!
There are ways to do miniaturized water cooling involving small fans and aluminum tubing. Think, high performance cpu cooling.
It would be impossible to retrofit though. The tubing would have to be manufactured structurally into the mounting plate of the LEDs and possibly into the body to save space.
I don’t know what sort of space is used for cooling in the design of the DX80, but I’m guessing it could be accomplished in about an inch of head/body tube space. Would involve a small fan and tiny radiator, and some venting. Natural heat driven fluid circulation.
Would probably drive the price up another $100, though.
Oh well, Gearbest just listed this light as well. With discount code “DX80” they’re selling it for $220 or 190 Euro. Pfff, what a great price… And that’s with 8 pieces of their protected Samsung 30Q batteries…
I do hope that they will add a spare driver in that box The heat caused will fry the default one in no time, my DT70 died after only like 10 hours of moderate usage( driver fried)
