TANK007 PA02 is a portable mini flashlight, which is best for doctors, nurse, medical students, etc.
Professional and User-friendly design make you comfortable and convenience.
Never afraid to be compared with other flashlight, even we encourage you to do so.
End click switch with feel comfortable.
Constant current circuit chip for constant brightness.
With diffusers specially designed, it can work as a camping lamp, signal stick or bracket light.
Lamp OSRAM
Output Levels Three mode
Max Brightness 90 Lumens
Throw Beam 80 Meters
Battery 2*AAA
Input Voltage 0.8V-3.7V
Burn Time 1.2 hours
Material Made of durable aircraft-grade aluminum T6061
Treatment Premium Type III hard-anodized anti-abrasive finish
Reflector Vacuum coated aluminum optical reflector
Lens Tempering optical lens
Switch End click switch
Construction Waterproof to IPX-8 standard
Impact Resistant Anti-drop height of 1.5 meters
Size Length: 5.00 inch; Bezel diameter: 0.54 inch
Weight 0.90 ounces (excluding batteries)
If I were buying this for myself, I’d agree with you on all three points. But, about your point two: My personal preference is 5000K, but I think for medical it might be better a bit warmer - maybe 4500K.
