Broke a nanjg 105d driver trying to swap the MCU. I don’t actually know if it’s totally gone, but I lost 2 solder pads in the process. Plus I might have damaged the driver retaining ring on my c8 to the point I might never be able to unscrew it again without causing some damage to the host
I broke a glass vase today, dropped from a high shelf. The momentum was strong, sending tiny sharp pieces all over the place, making the floor a death trap. It would have been a special kind of hell to clean up the mess without missing a tiny piece.
But I had my light, X45 is my savior! A sixteen thousand lumen of salvation!
The floor was instantly filled with hundred thousands of twinkling little diamonds, and I collected every single one of them without a hassle.
Nice use of your light! Almost makes me want to start breaking some glass
I was being clumsy AF yesterday for no good reason. I dropped batteries a whole bunch of times and ended up denting a couple. Fortunately they were from my oldest set of Eneloops.
Broke the end off a 7135 chip on a 5-chip custom 105d driver, apparently by cranking down too hard on a driver retaining ring.
I suspect it was already cracked as I was tightening the retainer trying to restore proper behavior, it had quit working reliably.
Oops.
My Ice Maker broke itself today. Luckily I took out P.C. Richards’ 10 year warranty. Totally worth the $300 I spent. My warranty runs out in May of 2022.
Broke a leg from a AMC7135 in my attempt to bend and add to a driver, plus cracked a glass while assembling my S2+ triple. I guess I’m supposed to remove the glass when using the triple tir optics
My air conditioner broke today
And it’s 40 C today…
Broke my smartphone, a Samsung Galaxy S3 Neo. Fell from my hand when I was fetching it off the hanging workpants during break time, when I was going to check my tracking codes (for a new Convoy S2 and a pair of Wii-Mote controllers)
But to be fair, I had already lost hope for it: the firmware didn’t update past Android Kit-Kat so I could hardly use the SD card storage, the outer host was all chipped paint, I couldn’t connect it to the PC as an external USB device (took forever to load, then failed), the screen had cracked under the protection, the silicone cover I put on it fell to desiccated pieces months ago, it sometimes crashed so hard it reset completely, and the battery was so worn, anything below 30% meant basically no charge at all. It was a trooper, but it’s been officially 3 years since I got it, and it was time to retire the old soldier ( v_v)7
Tonight, after I give my presentation for the final uni paper, I’m headed off to get a Motorola
I broke the power supply for my Raspberry Pi. :cry:
Today i have learned the hard way that you always have to be careful with a soldering iron!
While solder blobbing brand new (my first 26650’s) i accidently shorted one (which gave a nice spark) because i had the big part/edge of the iron too close to the edge of the cell, that made the wrap melt, all because i forgot the size, im used to 18650’s probably, which never gave problems.
Cell is ok, need to rewrap it.
Try this on for size: I was messing with the hidden menu of my 46” flat screen TV…hit the wrong button and bricked it! Won’t even turn on or anything!
Solution: Buy new motherboard for TV…$240!
Not a bad price for a TV repair considering, but a TERRIBLE price to pay for just poking buttons on the remote!
Ouch!
What TV is that? I guess Samsung. There is a chance you can revive it; some will accept a fw from a usb drive or have a serial port exposed.
I broke a magnet ring while trying to fit it to the tail of X6.
Ya…samsung…tried the USB fw thing…didnt work. I read in some forums you could remove the eeprom chip and reflash it, etc, etc…but that was above and beyond my capabilities and I would have to buy the hardware to reflash it with no guarantee it would solve the issue. Quickest and not much more expensive than buying chip flashers was just to replace the board. Installed it…works again…expensive lesson…ugh!
Not today, or even yesterday, but on March 25th I “broke” my arm/neck (slipped a couple of discs in my neck, pinched the radial nerve in my left arm. Still dealing with the arm pain even after surgery) while pruning trees away from the house …
on June 22nd (because of the March 25th incident) I broke a new spending record for myself. $100,805.35 for the Ti plate in my neck. Geesh.
And today, I broke another record for myself, as of 1:55 this afternoon I will be 55 yrs old, feeling it, feeling it all too well…
Have been on Dr.s orders to cease and desist for the past 8 weeks, who knows what I might have broken had I not been sitting around on my hands.
Titanium sure is expensive where you live
My expensive ($25) multi-meter broke. Screen no longer works even with new battery. Funny thing is my cheap harbor freight multi-meter keeps on working and has been for at least 2 years. lol
