Nitecore i8 Multi-Slot 5V USB Intelligent Charger For Li-ion/IMR/Ni-MH Battery
Use coupon code 347f56 to lower price by -$10.20 to $39.75
Lumintop Tool Ti XP-G2 R5 And Nichia 219B Titanium 110LM AAA Mini LED Flashlight
The flashlight price currently dropped to $42 and using coupon code 2017FNL price is further lowered by -$12.60 to only $29.40 !
Both Nicha 219 and XP-G2 versions are available.
VIOFO A119 1440P 160 Degree Wide Angle Car DVR With GPS-Black
Use coupon code: CE621F to lower price by 20% (currently $74.39).
This camera delivers good quality FHD recordings along with GPS location tracking comparable with products worth 3-4x times the price.
BLF A6 XPL 1600LM 7/4modes EDC LED Flashlight + INR18650-30Q Battery
Flash sale for only <7 days at $20.95!
Banggood 11th Anniversary Campaign has began.
There are many different discount coupons - not only for specific products but everyday there’s chance to get 11% OFF coupon valid on Sep 07 for everything except Smartphones, Tablets and “Promo” tag Items. Everyone can get up to 5 coupons - there are chances every few hours and there are no conditions - just click +yellow “Pick Now+” button when the counter indicate next round has began.
There’s also a game with various missions (task which are quite easy to perform) - first 110 people who complete all missions will get free Eachine E52 Drone
There’s a catch - final mission is to place an order over $50 on Sept 7 - but that’s one or two flashlights and you can use 11% off coupon which is valid only on that day.
BlitzWolf® 15W 2A Foldable Portable Dual USB SunPower Solar Cell Panel Charger with Power3S
is now in promotion for $24.99 (lowest yet).
This panel can easily charge any smartphone and will also charge in overcast conditions as well (with decreased rate of course).
Pair with LiitoKala Lii-100 0.5A/1A Li-ion Ni-MH USB Battery Charger for example and you can have independent power source for your flashlight needs:)
Banggood 11th Anniversary promotion calendar (click on links to see the details):
MON
TUE
WED
THU
FRI
SAT
SUN
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
1
2
3
Update: flashsale ended. Use coupon code 2017FNL to lower price to $24.50
Astrolux S3 XPL-HI 1400LM EDC LED Flashlight 14500
is now in flash sale for only $23.95
This is the most pocketable thrower out there with over 1000lm possible with decent high current battery (to get highest light output spring bypass might be required).
Two LED tints are available: 1A(cool) and 3B(neutral), driver uses Bistro firmware developed here at BLF, turbo mode is direct drive (through FET), low modes are regulated by 1xAMC7135. Lots of mode configurations to choose from (driver is programmable).
Astrolux S42 4xNichia 219C/XP-G2/XP-G3 A6 2023LM Rechargeable Mini LED Flashlight
is in promotion for VIP accounts:
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$24.95 |
$23.95 |
$22.95 |
$21.95 |
What’s more it’s still possible to lower the price further with BG points!!! Prices can be as low as in table below(provided enough points is available):
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$20.96 |
$19.88 |
$18.82 |
$17.56 |
Additional 18650 body tube available here: Astrolux S41/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube for $3.29 or with BG points for:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$2.80 |
$2.76 |
$2.73 |
$2.70 |
$2.63 |
ThorFire TK15S XP-L2 1050Lumens 6Modes EDC LED Flashlight 18650
using coupon code a0f9a1 price will drop by -$11.60 to $17.39
Very detailed review by SoCalTiger here:
[REVIEW] Thorfire TK15 & TK15S (XP-L2, 1x18650) (Pictures, Output, Beamshots, etc.)
ThorFire TK15 XP-L2 1050Lumens 6Modes EDC Tactical LED Flashlight 18650
using coupon code 025a62 price will drop by -$10.80 to $16.19
New Ampcore Plus USB cables are now in preorder with great prices.
Those new version cables have metal plugs and are kevlar reinforced, cable organizer is included.
BlitzWolf® Ampcore Plus BW-MC7 2.4A Kevlar Durable Micro USB Charging Data Cable 3.33ft/1m
1m/3.33ft micro USB | $2.99 right now(limited pieces), normal price $5.49 after preorder.
BlitzWolf® Ampcore Plus BW-MC8 2.4A Kevlar Durable Micro USB Charging Data Cable 6ft/1.8m
1.8m/6ft micro USB | $3.49 right now(limited pieces), normal price $6.49 after preorder.
BlitzWolf® Ampcore Plus BW-MC9 2.4A Kevlar Durable Micro USB Charging Data Cable 8.2ft/2.5m
2.5m/8.2ft micro USB | $4.49 right now(limited pieces), normal price $6.99 after preorder.
BlitzWolf® Ampcore Plus BW-MF9 2.4A Kevlar Durable Lightning Charging Data Cable with MFi 3.33ft/1m
1m/3.3ft Lightning | $6.99 right now(limited pieces), normal price $10.49 after preorder.
BlitzWolf® Ampcore Plus BW-MF10 2.4A Kevlar Durable Lightning Charging Data Cable with MFI 6ft/1.8m
1.8m/6ft Lightning | $7.49 right now(limited pieces), normal price $11.49 after preorder.
BlitzWolf® Ampcore Plus BW-TC8 3A Kevlar Durable USB 3.1 Type-C to Type-C Charging Data Cable 3.33ft
1m/3.3ft USB 3.1 Type-C to Type-C | $7.49 now in preorder, normal price $9.99 after preorder.
LUMINTOP IYP365 Brass Nichia 219BT/XP-G2(R5) 200LM 3Modes Portable EDC LED Penlight
Coupon code available now!
» Request via PM here«
LUMINTOP IYP365 Titanium Nichia 219BT/XP-G2(R5) 200LM 3Modes Portable EDC LED Penlight
Made with titanium with brass ring inserts. Both high CRI Nichia 219BT and cool white Cree XP-G2 R5 bin available.
Coupon code with nice discount available now!
» Request via PM here «
Astrolux K1 Stainless Steel XP-G3+365nm UV+Red LED 250LM USB Rechargeable Mini LED Keychain
New keychain light now in preorder for $14.75 (only 200 pcs for that price).
Compact stainless steel construction, USB rechargeable, white + UV 365nm + red LED, max 250lm (Cree XP-G3 white). Four colors to choose from.
Do you have a deal on the BLF X5 or the astrolux S3 under 20 usd?
Any chance for NW or high CRI models
Extra 25% OFF 2017 LED Flashlight Anniversary Pre Heat
Only flashlights from the above list can use 17FLANNP coupon code. Collection includes almost hundred flashlights, batteries and chargers from leading brands.
Note: some flashlights have better discounts using dedicated coupons - remember to check list in original post first.
Nitecore TIP 2017 XP-G2 360LM Metallic USB Rechargeable LED Mini Keychain Light
Using coupon code TIP11TH price is $19.46 (instead of $29.95, 35% off). Limited offer - only 300pcs for that coupon.
