I voted for the side switch… because i like to hold my lights that way and find it very inconvenient to go for the tail switch to interact.
I have one light with a magnetic ring and to me that’s way better then any switch. There is a physical motion that results in a mode - always the same. The ring is easy to find. Turn it one way or the other. Can be used with ramping, easy to figure out… But it costs more to get it right i guess.
My faves tend to be 1-mode tail-clickies with forward-clicky (momentary-on) switches. I hold lights icepick style (vs sword style), so a tail-clicky is the easiest way to turn it on/off while aiming the light at eye-index or neck-index, depending.
1 mode means a simple on/off, no accidentally putting it into firefly mode when you want to daylight up what you’re looking at. There are no mistakes. And momentary-on means being able to flash’n’dash without a noisy click giving away your position.
My EDC is a (RC, unfortunately) ’502 with 5000K XP-L. Simple, does what I need, end of story. When I eventually put together a “dream” drop-in, I’ll toss that into an L2M with FC switch and see how that works out.
For variable light output, my DV-S9 works beautifully with a magnetic slider. Moonlight to full-tilt in a simple slider, just like a wall-mounted dimmer switch. Plus off, of course. Physical lockout with ¼-turn to eliminate parasitic drain.
If I needed the flexibility of modes, I’d love the way my Quark 2AA-X does it with the twisty-head. Snug means turbo (and nasty strobe, so eliminate that), and loosened means moon/low/med/high. Alas, it takes AAs, so brightness falls as the cell(s) wear. Hate that more than the green tint from its AR-coated glass.
With a single tailswitch, something like 10 quick baps on the switch to go into “programming mode” to toggle features, whether turbo-only for “tactical” mode, or f/l/m/h cycling through with each switch bap. Maybe as you point out above, selectable options for memory on/off and possibly doubleclick-for-turbo on/off.
I voted both, but for the most part I like one or the other…not both at the same time. What I really want is an 18650 host with side switch only. I have a Lumintop SD26 with side e-switch. Removable tailcap so it can be locked out. Also, the Convoy BD06 is another great example using side switch only, but with a mechanical switch. However, both are 26650. I just don’t see the point in turning on/off at tail and then switching modes on the side.
Momentary use or signalling. A forward clicky tail is good although a double side switch (foreward clicky and momentary) providing an effect similar to the push button momentary and slide switch on some older lights would be better. The old angle head military flashlights with a side button and switch (I have one in near perfect condition purchased from clothing sales during annual training in 1991) are an example. With the switch on pressing the momentary button provided a ‘turbo’ equivalent. Modern hardware and firmware make it possible to far surpass this old standard. Momentary turbo by half pressing the forward clicky while in any mode selected by the momentary switch is one example although many other benefits are possible (my 2018 blf/ol contest entry - not enough time to design and test hw and fw for the current contest).
Just stumbled across this thread.
I dont know why so many torches have a tail switch these days, makes one handed operation a real nuisance!
Seems only maglite have side switches these days.
Ive never really found it an issue. Another feature thats lost is the ability to easily use it as a flasher or for signalling purposes.
I dont get the whole tactical style of many of these lights. Great for mounting on your rifle for shooting at night, but seems most of these lights are made this way to look “cool” like something SWAT teams would use lol.
I must say I still love my LED Lenser P7, its pretty old now but the one thing i hated about it other than the poor runtime off AAA batteries was the tailcap switch. They improved it on later versions and made it rubber and was less slippery but its still hard to use one handed. Not very ergonomic.
Both switch locations have their advantages and disadvantages, so there are some things that I like about side switch lights and some things that I don’t like about side switch lights. And there are some things that I like about tail switch lights, and there are some things that I don’t like about tail switch lights.
I know exactly where the tail switch is located, but when I grab the light, my fingertips are not readily located there. On side switch lights, my fingertips are right there on the side of the light, but not on the correct side of the light. So I either have to change my grip to get my fingertip on the rear switch, or I have to rotate the light in my hand to get the side switch under my fingertip. Neither one of these is a bigger deal than the other, so I just pick my lights on the basis of beam profile and power to size ratio, and trust choice of switch location to the judgment of the manufacturer.
Definitely side switch for big lights. Side switch is nice for EDC to avoid the light turning on in pockets. Either way I don’t really care where the switch is. Maybe tailswitch is better for throwers as you hold them to your shoulder to see better and side switch for floody lights ?
I don’t care where the switch is as long as my fingers find it quickly.
I don’t care how many switches are there as long as each adds something useful.
Typically I don’t like tail switches or double switches because they are more bulky than just side ones - though there are exceptions to the former and there might be exceptions to the latter.
I agree, I dont find it too big a deal to turn the light round to find the switch and usually can do it one handed, I do have to say that ive had some tail switch lights turn on in my pocket also if the button did not need much pressure to switch on.
