Hardware will support both, so really it’s up to the software. Supporting both at once was the plan though, at 20A input current the IC will be shedding a lot of heat so driver temp may become important.
Very nice! I just had this image in my head of a graph charted and recorded by an MCU. Then able to load that information back to a computer for easy observation of heat flow. Or an MCU in calibration mode that monitors the heat flow on any given level and calculates the best thermal performance for that particular setup.
Edit: After reading this, it sounds the same as what BLF firmware is already doing. However, it’s different in my head anyway. Maybe just more detailed and more complicated than needed. :person_facepalming:
Noob question :
The lower resistance the sense resistor is the higher the output ?.
I was changing the emitter in my C8S and damaged the sense resistor, I don’t have a R025 but I have a R018 but I think that’s a to low value making the driver over heat?
Correct. R018 may be a bit too low unless you have a good thermal connection between the driver and the host.
Thanks for the fast reply.
I went ahead and changed the resistor to R018 and the driver works .
It steps down fast and starts to blink, but at least it works. I don’t know if I damaged something else when I shorted the reflector but I will try to find a higher value resistor and see how that works out.
Just the fact that I made it work again I consider a victory I am more of a solder two wires kind of guy.
hi, i am using the KX70 32mm “6V” Boost driver in a courui d1 with a xhp50.2, powering from some good keeppower protected batteries, and notice often that something shuts down the flashlight in middle of using it. it would require me to remove the battery to restart it. it seems like the batteries are going short or something in the driver is failing, have you observed this?
I have not experienced that on any of my samples no. What current is the protection rated for? The driver can pull up to 10 amps from the cells depending on output and charge level.
solRNY, protection circuits are an additional hurdle which reduces a cell's discharge performance. Your protected KeepPowers are more than likely low drain cells with standard discharge protection circuitries, causing additional output voltage sag. The equivalent series resistance in one of those protected batteries is equal to the internal resistance of its low drain cell (high, above 50-60mΩ) plus the resistance of the probably two 8205A MOSFETs (close to 15mΩ) which switch the cell's cathode. This is very high and completely inadequate for even remotely close to high drain applications.
A high drain cell's internal resistance is generally well below 30mΩ. Mooch, the vaper's community reviewer, concluded that low drain cells are only worth it at up to half of its rated maximum discharge current (or so) versus the 2800-3000mAh high drainers. It can be argued that the test's cutoff value is very high (3.2V) and I agree, but anyway it serves as an enlightening reference: Which High Capacity 18650 is the Best? -- Shootout Bench Test Results @ E-CigaretteForum
V1 posted on Thu, 08/10/2017 - 15:17; redundancy typo fixed.
thanks for the battery education. I will use high drain unprotected cells.
0K my technical fellows, just found this lost beauty (I hope): CF FX-17A 17mm 3V - 9V 2.2A 1 cell or 2 cells 2 Groups 3 to 5-Mode Driver Circuit Board @ Kaidomain
No relevant information found for the driver. My observations:
- Reverse polarity protected. As Jensen567 explained in this same thread some messages ago for the H1-A, this means the driver innards' ground plane is isolated from the host, which is heat transfer detrimental.
- Amount of modes and spacing: 5-40-100%, with optional strobe and SOS. :THUMBS-UP:
- Last used mode memory, 3 seconds. :THUMBS-UP:
- Stock output is 2.2A, sense resistor :facepalm: 0.1Ω , 0.22V sense voltage. This is inefficient, a lot of power is lost here.
- Height is listed as 8mm, spring excluded I believe.
Sheesh!
It's 17mm, but wrong in every other aspect. An LD-29 beats it hands down.
Cheers
I have a couple of those on the way already actually. Im guessing it is QX9920 based but will find out. Plan to use them in some converted mini-mag triples, so not going to push much current.
Mmmkay fellows, finally found and opted for this “host” of my liking: ThorFire TA13 (Sofirn SF30?) questions
Excellent driver boot in there, doesn't it? It probably is the better zoomie flashlight for modding one can buy in that price range. ;-)
Not gonna mod it straight yet, looks nice, no hurry. I'll buy parts as I can slip €urobucks for it, economy is tight now so we'll see.
Cheers
I have a Sofirn SF30A on the way from Aliexpress because of this tread on TLF, I have a “spare” driver from a Jaxman X1S I plan to use with a XHP35 HD.
Thanks for the link, khas. I'd have preferred for those %@#@&$ not to “hide” the pictures.
Something is said about the led sitting 5mm “too low”, or the lens not being able to get close enough above the emitter, limiting flood. Don't know how do they solve that.
Mine isn't going to be fully modded “straight away”. As it comes from the warehouse I'll just put a dedomed emitter in it.
Do XHP35 HDs dedome well?
They probably dedome as well as XPL HD. Why not just go with XHP35 HI though?
I'll probably go with an XHP35 in a near future, for now I'll just swap the stock XM-L2 with a dedomed XM-L2/XM-L, the stock driver isn't meant to handle high voltage emitters.
The XM-L I have is an old school emitter, produced maybe by the end of 2013, this means it can probably take some high current without blowing up.
However, I still have an old XHP70 M4 40H bought from Kaidomain… (still available on their “AliExpress branch”: https://www.aliexpress.com/store/product/Cree-XHP70-M4-40H-4000K-Neutral-White-LED-1-Piece/708513_32683288528.html). Do you believe, Jensen567, we could reconfigure the H2-C output voltage range to start off from ≈5.xV? Should be feasible, isn't it?
Cheers
Yes changing the output voltage on H2-C should be possible, that’s my next endeavor as I will probably need to do that for my scratch build anyway.
I see the H2-C manages ≈2.5A in turbo at 12+V with ease and efficiency, at least as long as the input is 2S. How about stacking an R050 (or two R100s) in parallel with the stock ones? That would mean 3A for turbo, 2A after 60s stepdown. I'd just need a Sinkpad XHP70 6/12V MCPCB.
Mmm...
Cheers ^:)
The thing I dislike about 12V XHP50/70 is that on all the DTP boards I have seen, the thermal pad is no longer isolated, and sits at the 6V midpoint of the series chain.
Most lights have the battery negative connected to the flashlight body, so if the thermal pad is not isolated, and the board is DTP, we need to worry about isolating the MCPCB from the flashlight body which can be a pain.
