The difference is the same; each mode should do without crazy difficulty what it is claimed to do. I’ve already purchased the Brontelight BT31 instead.
Why create such drama about simply changing your mind? Why try to trash an excellent light? Just so that you don’t feel guilty for dropping out? Just simply drop out. Others will buy the light you didn’t want. No hard feelings needed.
The BT31 I avoided after considering it. No meaningful reviews, high cost, mediocre specs for what it is, only 1 BLFer posted they actually bought it, etc. Not sure why anyone would buy it over a TN42, but neither light is in the same class as the GT, not even close.
What’s the point in a 2.5 Amperes Turbo mode when high is already 2 Amperes ?
The 25% increase from 2.0 to 2.5 Amperes will be visible on a lux meter, but hardly / not to the naked eye.
This is a run time chart with the BLF GT proto Narsil running two amps at the end of ramping.
This particular GT also has spring bypasses on the battery carrier.
The runs were stopped when the low voltage kicked in for the first time.
This chart is a comparison running the BLF GT on high, the original Narsil at 2.5 amps and the proto Narsil at 2 amps. Both runs were with 30Q batteries.
Nice graphs, looks regulated to me for 40 minutes, so with the 8x carrier double that.
It is not clear to me what the difference is between ‘original Narsil’ and ‘proto Narsil’. Narsil is the user interface so are they different user interfaces?
The main difference was the original Narsil ramped to the maximum current output of the driver which was 2.5 amps at the LED. Prot Narsil used here ramps to 2 amps which is where this run time test was carried out. Double click takes you to 2.5 amps.
The surprise to me was the little difference there was running at 2.5 amps against 2 amps in light output and throw.
Pretty neat, 30Qs do not have the highest mAh and it is with four where eight can be used too in the production lights.
I can’t see the runtime graph in the sole BT31 review but the text say it keeps the output above 50% indicating a decreasing output over time.
Huge kudos to all the folks here that are designing and testing these BLF creations. It’s so cool to see BLF being used as the medium to make these lights happen. The GT is looking absolutely formidable. And I’m also seriously impressed by Steve’s shots where the Q8 beer can floody light holds its own against some serious throwers simply by virtue of its sheer output. Incredible! :+1:
