How to measure tailcap current properly?
35 posts / 0 new
dangerous
dangerous's picture
Last seen: 2 years 11 months ago
I thought measuring tailcap current would be very straightforward, but I am seeing some odd things…
Is it normal for the numbers to be bouncing up and down from roughly 2.2A to 2.4A with a given cell in a given light? Will different quality cells and different quality lights have higher variances in current when in use? EVERY cell I have shows these fluctuations except my VTC5s. This makes me think all other cells are inferior. :quest:
Do you only consider the peak current when evaluating the current if it varies like that?
The specific cells I’m testing are: Unprotected EVVA KK, Protected NCR18650B, Protected Olight 3400, Unprotected Samsung ICR18650-26C, Unprotected NCR1860PF, Unprotected EBL 2600, Unprotected VTC5…
The specific multimeter I am using is the INNOVA 3320 Auto-Ranging Digital Multimeter, which I am using on the DC 10A setting….
BLF
Edited by: dangerous on 07/27/2014 - 10:02
M4D M4X
M4D M4X's picture
Last seen: 10 min 53 sec ago
do you use thick, short measuring cables?
thin ones raise the resistance a lot (for measuring purposes) and add to the inner resistance of the cell – that affects the Amps a lot.
find all available items in this list
i launched my new blog - all deals for members without MAP B$ Wink
find a short description about my idea here
if you want to buy a flashlight or battery for a better price: just send a mail - i will try to save you money!
dangerous
dangerous's picture
The cables are the standard ones that came with the multimeter – 22AWG (0.326 mm²) with a length of 40 in (1m).
BLF
Hikelite
Last seen: 55 min 52 sec ago
Those are some thin wires, some better standard ones are 18AWG, they could easily be 1.3-1.6meters.
You need to think about the entire circuit, so current travels 1m*2.
Use 12-14AWG with a max length of 1feet per cable, that is safe to get you better/correct results on low voltage-high currents circuits.
dangerous
dangerous's picture
The thing that bothers me the most is how the NCR18650B cells have so much lower current than the VTC5 even though the current draw is less than 3A. I thought they would have been closer at such low current. This makes me reconsider using NCR18650 in so many of my lights…
BLF
Illuminaria
Last seen: 3 years 2 months ago
I would throw my Samsung ICR18650-26C in the microwave if that would magically convert them to VTC5’s, no? Using 4 Samsung ICR18650-26C in my 4 cell, 11 amp, lights works well enough till I hit the lottery. The non high current drain batteries seem fine for more modest lights.
Cereal_killer
Cereal_killer's picture
Last seen: 1 month 1 week ago
Consider buying a external shunt modified DMM from me ($10 shipped), you can take accurate current readings up to 20A!
If you don’t you’ll need to, at the very minimum, upgrade your DMM leads, factory ones (even high quality Fluke leads) are only reliable to ~1A. Its best to use >14AWG stranded wire and solder them to the inside of the DMM (but this will make it only usable for current measurements) that’s why I sell the ones I do, so you can have an accurate current measuring DMM without having to make yours useless for other readings.
Also note, even tho the sheathing of your stock leads appear to be ~22AWG in size it’s most likely that there are only around 30 strands inside making it ~28+ gauge.
Always remember SPC Joey Riley, KIA 11/24/14.
dangerous
dangerous's picture
Those Samsungs are great for the price considering I got mine for under $3/each, but my protected NCR18650B were the same price as my VTC5 ($11/each), which is why I regret buying so many NCR18650B. The NCR18650B are providing under 2.4A in the same light that the VTC5 are providing over 2.8A…
BLF
dangerous
dangerous's picture
So most people think it is the cables that are causing the fluctuations in current? I would understand if the cables aren’t giving accurate reading, but I don’t really get why the current would fluctuate more with all cells besides VTC5…
I guess most people just don’t see these current fluctuations when taking tailcap currents…
BLF
Hikelite
dangerous wrote:
Illuminaria wrote:
I would throw my Samsung ICR18650-26C in the microwave if that would magically convert them to VTC5's, no? Using 4 Samsung ICR18650-26C in my 4 cell, 11 amp, lights works well enough till I hit the lottery. The non high current drain batteries seem fine for more modest lights.
Those Samsungs are great for the price considering I got mine for under $3/each, but my protected NCR18650B were the same price as my VTC5 ($11/each), which is why I regret buying so many NCR18650B. The NCR18650B are providing under 2.4A in the same light that the VTC5 are providing over 2.8A...
3A current is not a big deal for NCR18650B, so don't blame the cells.  Fix the cable, or current measuring system. Don't ever forget that anything through a current has to pass will drop some of it.   X3 for example has a contact board then these some wires to the driver, just a bit of waste there too, we can easily call this a not so perfect concept for low voltage circuits and high currents.
Illuminaria
your are seeing poor contact as mine are normally steady. Make sure battery post are clean and good contact on tube. Your meter may be in question, CK’s meter may be a good option if any doubt. Check your leads, on ohms, is the reading steady? What about measuring battery voltage at rest, should be dead steady on first 3-4 digits.
Cereal_killer
dangerous wrote:
[Those Samsungs are great for the price considering I got mine for under $3/each, but my protected NCR18650B were the same price as my VTC5 ($11/each), which is why I regret buying so many NCR18650B. The NCR18650B are providing under 2.4A in the same light that the VTC5 are providing over 2.8A…
Just making an offer but I’d trade you one of my current reading modified DMM’s for a NCRB straight up.
dazed1
dazed1's picture
Can you tell me what did you measure with B vs the VTC5? how much difference there was, and at what amps?
Oops, now i read it you already answered, sorry. What light it was can you tell me?
Fenix TK61 MOD> resistor, transistors, copper heatsink, Artic Cooling MX4, dedome, 3A > 5.7A ~ 1700 lumens > (600.000cd)
Hikelite
Meter is in question here like many poor measurements that are talked about on the forum. You do not measure current over 2meters at 22AWG, the voltage will drop to 3.78V from 4.2V only because of the 2meters 22AWG wires, not counting other loses like springs, etc. Important to remember that an uncompressed spring is not going  to have as low resistance as a compressed spring that will also create what some call "unknown variable", so the numbers bouncing has at least one clear explanation, the one one would be poor contact or dirty contact.
dangerous
dangerous's picture
Hikelite wrote:
Meter is in question here like many poor measurements that are talked about on the forum. You do not measure current over 2meters at 22AWG, the voltage will drop to 3.78V from 4.2V only because of the 2meters 22AWG wires>
These are 1m cables and voltage readings match the OPUS BT-C3100 within .01v every time.
The numbers I mentioned here were from the XinTD X3, but I reproduced the same pattern in other lights such as the Nitecore P12 (under 3A, but the VTC5 pulls .5A higher than the NCR18650B.
BLF
Hikelite
I do not think you quite understand some basic stuff, I am only trying to help you.
1meter is in one direction there other direction is another 1 meter, so it is 2 meters that is how current travels. Reading battery voltage has nothing to do with reading the current you want to read on the same multimeter.
dangerous
dangerous's picture
Ah, I see now. Thank you.
BLF
Hikelite
Get 2pcs of 1feet of 12-14AWG wire and use those as leads for your multimeter when measuirng current. You will see a big difference with the NCR18650B, also do not forget to chek how pressing the cell (compressing the spring) will change the current reading slightly, but since the cables are so thing now, the compression will not cause a big difference in current reading.
dchomak
Last seen: 1 hour 48 min ago
A real problem with measuring tail cap currents on multi-emitter lights is the total resistance introduced in the meter path. Most meters use a .01 ohm shunt resistor and even if one solders 2 – 1 foot 14 gauge copper wires to the insides of the jacks, there is an added .015 ohms in the path. (2 feet of 14awg copper is .005 ohm) Pass 15 amps through that setup as I do through my modded 6-XM-L2 SKR, and you will drop (V=IxR) 15 x .015 = .225 volts. That is a HUGE amount.
It’s just like running the light on 4.2V cells that are discharged to 3.975V. Couple that with the fact that LEDs when running in DD or with FET drivers on high and you will measure much less current than it would pull without that added resistance. Also remember that LEDs are non-linear in their current demands. Slightly increasing, or decreasing, the applied voltage will disproportionately affect the current draw. In other words a sight increase in voltage can greatly increase the current draw.
Of course when measuring smaller lights, as is the case in the OP, or current regulated drivers, the added resistance in the meter circuit does not matter so much.
Cereal_killer knows this, hence his suggestions.
Hikelite
The point I am trying to stress here is that NCR18650B are definitely capable of 3A if that is the load. You don't need VTC5 for 3A, if you got them that is good, useful cells, but NCR18650B has no problem delivering 2.8 - 3A, since  X3 is using a Nanjg 105C driver.
GW3
Does the driver produce a PWM output? I’m wondering what would happen if a digital sampling meter, taking a sample at brief intervals, runs into that situation.
HKJ
HKJ's picture
Last seen: 4 min 12 sec ago
GW3 wrote:
Does the driver produce a PWM output? I'm wondering what would happen if a digital sampling meter, taking a sample at brief intervals, runs into that situation.
Most DMM's are fairly good at averaging measurements.
My website with reviews of many chargers and batteries (More than 1000): http://lygte-info.dk/
Pavithra_uk
Pavithra_uk's picture
I used 20miliOhm resistor and mV range multimeter.
then 1mV = 50mA
thulfiqar
thulfiqar's picture
Last seen: 5 min 37 sec ago
Hi ,
What is the Typical Resistance in a Flashlight Switch , I just measured the resistance in my Flashlight switch and it was 1 ohm ?!
is it really 1 ohm or my multimeter is wrong ? (DT830D Multimeter) Big Smile
Thanks
djozz
djozz's picture
Last seen: 1 hour 21 min ago
thulfiqar wrote:
Hi ,
Thanks
Hi thulfiqar, in my signature line below you can my tests, and one of them is about switches. If I remember well, the typical small Omten switch should have roughly 0.01 Ohm resistance. These are values that normal multimeters will not measure well.
GW3
I have a similar cheap multimeter and it is useless at low ohm readings.
Lexel
Lexel's picture
Last seen: 8 min 55 sec ago
best is to measure the voltage over it with current you know flowing through it
R=U/I
for example
R=0,03V/3A=10mOhms
maukka
maukka's picture
Last seen: 4 min 21 sec ago
Exactly. If you don’t have a good resistance meter with 4 wire testing, check out HKJ’s article under the heading Low ohmic measurement:
http://www.lygte-info.dk/info/Measurement%20UK.html
Tinderbox UK
Tinderbox UK's picture
Last seen: 2 min 18 sec ago
Use a short piece of solid copper wire to bridge the battery to the flashlight case, and use a clamp a meter on the cable, the UNI-T UT210E clamp meter has an 1ma DC resolution, we had a group buy going a while ago as it`s such a great meter for the price.
John.
SkyRC MC3000 – Maha C9000 – LaCrosse BC-900 – Floureon BT-C3100 V2.2 – Accumanger 10 and 20 -Thunder AC6 LiitoKala Lii-100 – Cozypony 24W Solar Panel – Soshine H4 – Soshine T2 – Soshine E4S
dmsoule
Last seen: 52 min 16 sec ago
I thought that clamp meters only measured AC current, or at least the affordable ones. Does this UNI-T use a Hall effect sensor??
djozz
djozz's picture
Yes, it does.
