I received my Emisar D4 in the nichia flavor today. I’m loving it. Thank you Tom E and Toykeeper for nailing the ramping UI. Thank you Hank Wang for bringing this light to market. The quality is top notch and the price is an amazing value. I have another one on its way with the xp-g2 5D tint. I love all the choices available. I had been wanting a Zebralight SC62-3 but this light has scratched that itch for sure. Good job to everyone involved.
I would be happy to produce such patch, but so far I don’t have a way of flashing the patched firmware and so I can’t test it. Developers seem to move away from SOIC8 chips, so investing in a SOIC8 setup at this moment doesn’t seem like a good idea….
Confirmed, I can reproduce it with your steps. Why doesn’t it happen every time after a power-reset?
TK you have just won the best line in August award.
I cant decide which:
“When it first turns on in turbo, it will generally exceed the target temperature before it stabilizes. This is because, even with the predictive algorithm, thermal lag still delays the measurements too much to avoid the initial peak. Basically, thermal regulation is rather unpleasantly like trying to steer a fast-moving cow around a hairpin turn on an icy race track. While wearing someone else’s glasses.”
LOL
“Basically, thermal regulation is rather unpleasantly like trying to steer a fast-moving cow around a hairpin turn on an icy race track. While wearing someone else’s glasses.”
LMFAO
And for the rest of us I think you just made a 4th gen light (we don’t actually control it) we give it our input and then it decides the exact output. sounds about right, maybe like modern high performance aircraft we can’t react fast enough.
All Hail TK and her Fly by Wire flashlights! Were not worthy
I have another usability comment…
I’d prefer the light not to remember the ramping direction for too long. Myself, I forget it seconds after I stop ramping. After that I never know what will the light do if I start ramping again.
Can’t get D4 out of my head.
This light really shows how UIs of my other flashlights suck.
Very rich, but not complex. Allows to do nearly anything that I want quickly. Doesn’t really have a lot to memorize. Click, click+hold, 2-click, 3-click, unscrew slightly. Not little, but far from the 20-clicks I’ve seen in a similarly rich driver.
Nevertheless I have some thoughts, which may or may not be an improvement.
I just got stuck in the momentary mode. How many times do I need to click to escape it? I needed to look up a diagram. If screwing / unscrewing the tail would reset that, it would be nicer (though I recognise some may want to keep this mode forever, regardless of battery changes).
It would be nice to have a shortcut to roughly-max-thermally-stable mode.
If I enter thermal calibration mode, press and hold until it starts showing the current mode, then start clicking, the light behaves funny. Click turns it on, but at the next digit it turns off by itself and continues showing the number. I guess it would be better if de-pressing the button made the light quit the thermal-calibration mode immediately.
Have been playing with the ramping for a few days, I felt the need for an extra way to get to a maximum sustainable mode directly (so not after letting the, well working, thermal stepdown algorithm figure it out). I’m sure in most situations that is about 2.5 A in this light.
Been thinking of ways to implement this.
There is the short hickup at 350mA, easiest is create a same hickup at 2.5A but once you see it you overshoot it, it is not precise.
A way to implement is to let ramping up stop at the two locations. Letting the switch go and pressing it again resumes the ramping to the next stop.
This requires the ramping-down to have a new unique command, that could be the shortclick-hold that DrJones uses in his ramping UI.
TK and Tom and Led4power and the Dr have been tinkering much longer about these things so I realise that my thoughts may be primitive and flawed, but I wanted to post it anyway
With a Lamp on your side you can get distracting light distribution if you use it at armlength.
In fog or rain left and right eye see different brightness. Thiss can be annoying
Your neck musculature isn’t trained for sideload. Waering a light sideways a few hours you will fell it the next day.
Front mounted is easier.
A LED in front, battery on the back of your head is even better.
For working in narrow spaces you dang your head often sideways seldom the front. You are usually better avoiding a slam in your face.
For a dedicated headlamp you want a broad beam over 100 degree if need it for armlength to 3 meter distance. Side mounted you have a shadow.
I have troubles to calibrate it thermally. It’s always too hot.
If I start with a cool light, delay makes it overshoot. Now I did a hot-start.
Previously I got it at 36 or so. I warmed it up slightly, waited to cool down, so it was well within my comfortable range, started heating up, stopped almost immediately. Result? 71, way above what I can touch.
now:
random brightness 2 clicks> Turbo -> 2 clicks -> old brightness
What about adding the thermal save level like this :
random brightness 2 clicks> Turbo -> 2 clicks -> max. thermal save brightness 2 clicks> old brightness
TK, are the sources of the thermal control simulator that you wrote available somewhere? I’d like to play with it.
On another topic, I went to the kitchen a moment ago and took a mug. I noticed it was dirty, it had something yellow at the bottom. I moved it slightly to see it better and the yellow thing moved. Afterimage again….
Maybe just pause for a moment and then continue, as long as the key is pressed? I’m afraid that otherwise users would be stuck at 350 mA thinking it was the max……showing off how they have light that’s brighter than the neighbour’s.
Interesting. Once user has used turbo, their night vision is destroyed already, so putting another bright mode in the middle shouldn’t hurt really.
Though I would consider implementing this idea slightly differently.
I would skip the max thermal step if it’s dimmer or equal to the old brightness.
Actually I would skip it too if it’s only slightly brighter than the user-set mode.
Pros: no useless transitions.
Cons: User may be unsure whether the next 2-click will go up or down in case they had level somewhat close to the limit. This can be made less of a problem by making the required difference to be quite large, so the “hey, my mode must have been lower” reaction is nearly guaranteed.
My personal solution was to make it accessible with a 3-click, shifting other modes.
