Just saw the OP. We have not published this light officially. But whatever, it will get ready within 10 days.
In fact , MT07S outperforms the big MT07 in many respects. More functions, More lumens and more throw and similar heat-sinking.
More test results will come out this week. If any interests ,better waiting some more days. From comparison , compact MT07S is much brighter than big MT07, and throws better.
MT07S ( only 470 gram in weight, but the cooling base design is much thicker than old MT07)
Batteries are in 4S, Full current regulation ( brightness maintains until batteries under 3V)
Camera setting: 1.3S / F4, ISO200
MT07S XHP70.2 NW 4800K SMO Reflector
MT07 Buffalo XHP70 CW 6500K OP Reflector
From comparison, MT07S is brighter than MT07.
Brightness Modes:
Low: 150 Lumens
Medium I: 450 Lumens
Medium II: 1000 Lumens;
High: 2200 Lumens
Hidden Turbo:5000~5500 Lumens (double click at any time)
Double click again:Strobe
Hidden Moonlight:1 ~3 Lumens (In off status A long click for 2 seconds to access moonlight. )
Thermal control Remove / Activation:MT07S comes with thermal control by default. If you want to remove thermal step-down , turn the moonlight mode on first and press the switch for 3 seconds to remove thermal control function. When you see a signal flash, it means the thermal control function has been removed, and MT07S will have no step down any more.
The thermal control function will recover when you cut off the power supply.
Operation:
single click on; single click off
Long click to change modes ; Double click to Turbo ; Double click again to Strobe ;
With last mode memory
In off status a long click for 2 seconds to access moonlight mode ; another long click for 3 seconds to remove thermal control. Cut off the battery power to recover thermal control.
A single click followed by long click to lockout the switch. Repeat to unlock.
Power indication light:
100~50 Blue led on
50~9 Blue led flashes
Blow 9% Red led flashes
Can you make photo of MT07 and MT07s side by side to compare size?
Does the battery tube interchangeable with MT07? just like MT03 and MT07?
You mention of new thrower with XHP35 HI in other thread so assume it is a different light but not HT08? cant wait for that one too…
I am glad that Haikelite went with 1 button just like MT01/MT02 and SC series and unify their UI and i dont like the rubber button either but MT03 button is fine. :+1:
