ALL THINGS BUDGET KNIVES
Can someone recommend a locking small partially serrated knife - something comparable to the Gerber LST 300 in weight and quality would be ideal?
At this point my favorite budget knife is my zt 0808 clone. Smooth one-hand open and close with a smooth bearing pivot. Much better than the Ganzo knives I have. Not to say they’re bad but the 0808 clone is better. Wish I could find one with the Ti handle. It isn’t serrated but has handled every cut superbly and is still un re-sharpened. A bargain for the $20.xx paid. I REALLY like it. I would have slept better when I was at the quarterly stop in Wobeck with it vs the knife I normally had under my pillow - a case p62 - 4 1/2. The early 80s was a very tense period… The Case has the bonus of being silent due to the fixed blade and the quality of the blade although I did bend it abusively testing it against a car (1980s - before ‘cold steel’ started doing it). FWIW I was with the US military, but that’s all I can disclose.
FastTech they are not, placed an order last friday and it is not due to ship till tomorrow and i had to pay a little for the shipping as it`s a knife.
John.
You get SHOT if you talk about buying clones on Bladeforum.com, But buying clones is all i can afford.
Is their an Spyderco clone with a just under 3" blade, I will have to cut out the blade lock but it`s only a clone.
Thanks
John.
The “real” Ti handle clone version (quite good to perceive by the screw for the stainless lock bar insert) of the ZT0808 is currently avaiable at Dc_outdoor,
which i.m.o. is one of the recommandable sellers on DHgate. But with 61.21 $ it is far from being as budget as the steel version.
At post No. 2033 on this thread BLF member @Erethryn, who seems to live in the U.K. as well, says that it’s possible to modify the Ganzo F759M into a slipjoint, and where is even to find a link where is sth. to read about how to do it.
There are also some clones of Sydercos Byrd Tern slipjoint knife “hanging around”, that are avaiable around 10 $ or even less as well.
The Ganzo F759M is on sale at GearBest at the moment for $7.99 for black.
I found the back-lock to slipjoint mod.
John.
Just an update on that, I may have gotten lucky on my first attempt or unlucky on the second one I tried to modify.
The first one still works great as a slipjoint (carrying it today in fact), but I messed up the grinding on the second one. It sometimes slips, but occasionally “locks”. The metal of the back lock now protrudes out too high too.
Basically, it’s definitely possible to do, but you may wreck a knife or two before getting it right.
Thanks, there seems to a lot of cheap China knives with no-lock, But i think the Spyderco clone i saw had no-lock but was out of stock, I think maybe i miss-remmber.
Thanks anyway.
EDIT: this one, 59mm blade and no-lock but out of stock.
https://www.fasttech.com/products/0/10001877/2132001-authentic-sanrenmu-6020ruc-sa-stainless-steel
John.
I’ve got a “C94” from Aliexpress, the bevel was slightly off centre, but for the price it’s a really nice copy of the UKPK.
Is this the one, It does not mention an blade-lock, GOD those AliExpress links are Loooooooooooooooong.
https://www.aliexpress.com/item/BMT-C94-Hunting-Knife-Tactical-Survival-Combat-Portable-Outdoor-Camping-Folding-Knives-EDC-Rescue-Tools-S30V/32819419853.html?ws_ab_test=searchweb0_0,searchweb201602_3_10152_10065_10151_10068_10130_10209_10192_10190_10307_10301_10137_10303_10060_10155_10154_10056_10055_10054_10059_100031_10099_10103_10102_10052_10053_10142_10107_10050_10051_10084_10083_10080_10082_10081_10110_10111_10112_10113_10114_10179_10312_10313_10184_10314_10315_10078_10079_10210_10073,searchweb201603_3,ppcSwitch_5&btsid=4ba63d37-96ae-4c68-89ce-ef1d1d59557b&algo_expid=24078b63-9e3b-447d-8695-a1be6a73a28b-3&algo_pvid=24078b63-9e3b-447d-8695-a1be6a73a28b
John.
Yup, that’s the one…well, one of the various sellers of it anyway.
Edit: Just to clarify, that style is non-locking.
I will have one of those, thank-you.
John.
Technical question: Apologies if this has been covered before but I could not find anything about it.
Why do some folders come with one teflon washer & one brass washer.
Why not both the same ?
I guess blade centering (different thickness) might be the reason.
I’ve finished my review about the Spyderco C195 Positron style flipper from Aliexpress.
This is the smaller version with 2.91” (74 mm) stone washed blade:
I’ve just spotted that the Byrd Tern is available too, if you’re after something slightly shorter than the UKPK/C94:
https://www.aliexpress.com/item/WLC-FK-F1-Straight-Survial-Camping-Fixed-Blade-Knife-Tactical-Hunting-Knives-8Cr13-Blade-Outdoor-Rescue/32751858257.html
Thanks Erethryn, Looks nice.
Does that pocket clip look strong to you, also is the handle all plastic, not even a metal liner.
John.
I’ve just ordered one, so I’ll let you know, but it appears to be the same construction as the C94. G10 scales with no liners. I’m happy enough with that construction on the C94.
As for the pocket clip, the wire may be a bit soft. I’ve just had to take to the one off my C94 to slightly bend it back down as it had moved away from the scales.
If it`s G10 it should be alright.
I am looking a cheap pouch to fit an Rough Rider 3.5" Canoe folder to stop it rubbing on my K18 SS flashlight, I can only find 4.5" and above, even a DIY solution, The folder is only £11 so i dont want to spend much.
I have even looked at the swiss army knife pouches.
Thanks
John.
