Just got my second one. This time a green xp-g2 3D. Love the green color but absolutely hate the tint. No rosiness, only purple and blue… This can’t be normal with this LEDs, right?
Edit: I’m talking about the corona. The hotspot is yellow.
I am holding myself to buy one because even though it offers good choices of tints (thank you for pointing them out) I need high cri (R9080). I hope we will see NVSL219BT-V1 option available to purchase. Do the producer of this light know that there is a demand for high cri version?
Just checked mine for you. I see differences between the hotspot and corona (yellow, and purple) when standing 50cm from a white wall. If I move to 150cm all is nice and neutral. Compared it to my 2014 Eagletac D25 nichia 219b 5000k and the tint is almost identical.
Remembering, as TK and Clemence have both pointed out, HiCri fidelity occurs at a predetermined current level.
Overdriven, the tint goes far away from the ANSI BBL….
Curious enough to try 4 x Nichia 219BT 4000K. sw40, 93 Cri 9050 leds in my D4,
………when overdriven, the output produces way more magenta than a normal driven sw45,
enough to make a normally driven (pinkish) triple with leds from the same reel appear greenish when compared side by side.
If you want a side switch noPWM triple for your Nichias, the MecArmy PT 10, 14, 16, and 18 series keeps the tint faithful.
Maybe that’s why they do not provide hi-cri version. Thank you for the information, I now remember the case about overdriven hicri leds. It looks like I will wait for new hi cri led
That sounds normal to me, typical of a lot of the emitters that try a mix of phosphors over the blue base layer for higher color rendering.
Remember the base layer is blue, it’s the blue photons that excite the phosphors which re-emit the energy as various wavelength of red to yellower light.
The published spectra show several peaks from the phosphors:
Getting the right mix of the right phosphorescent chemicals is the art of designing the higher CRI LEDs.
Getting phosphors that don’t degrade with time or flake off is also part of their art.
The focus is using the light from the face of the phosphor, to make the hotspot.
The light coming sideways off the base layer — there’s always some — will show up in the less focused corona and will be more bluish.,
You can use a different Carclo quad optic with diffusion built in. Or put DC-Fix on the lens. Both work.
You mean, you like the 219b more than the 219c? That’s fair — the 219b had more of a rosy tint. However, it also has much lower maximum output… particularly when limited to the current which produces the best tint. A quad 219b configured to optimize tint would probably make about 1600 lm at 6-8 A. Maxed out completely, it might make up to 2400 lm at 14 A. A quad 219c could theoretically make up to about 4800 lm at 24 A.
One of my nicest-looking lights is a triple 219b at just one amp per emitter. It makes only 800 lm, but it’s 800 very nice lumens.
It’d be nice to see a D4 with 219c at 4500k and 90+ CRI. That seems like more of a true neutral, halfway between warm white and cool white.
Cree emitters tend to put out different tints at different angles. So does Nichia, to a much lesser extent. To get a beam with a consistent tint, you’ll need a diffused optic to blend different parts of the beam together.
Agree, bought S4 5D and immediately put a frosted optic on it.
You may want to stay away from the XP-G3 under an Optic.
I forget the tint but ordered an XP-G3 triple board from Mtn… Tested it under an optic before install. My reaction was, that’s quite the rainbow! Put every Carclo I had over it including Frosted. That board went back into the bag, in the parts bin.
XP-L HI does not give that same effect.
I will eventually swap out the G2’s in that light. Just undecided… to what.
I do have a new Mtn quad board with 319AT but not unless I get an 18350 tube and some Aspire batts to calm it down a bit.
I can’t say that it did 100% but it helped a lot. Definitely less blue/purple but still kinda pinkish like a 219B with a yellow spot.
Carclo are also noted for the artifacts, mostly noticed as you spin the light. Frosted also removes most of that too.
The frosted quad I have from Mtn. is a medium spot, 10623 Carclo. So it will be wider pattern than original.
Ok, that’s good to hear. Only thing that matters is that the blue/purple disappears. Do you know if it’s available for purchase in Asia/Europe? Shipping is too much from the states for me.
I like how smooth and fast it reacts and that the current level stays in memory for the next turn on. However if i set the light to some mid level i like and next use the shortcut to moon for instance (long press from off) and turn the light off, the next time it will also start on moon with a single click - the memorized mid level has been ‘erased’ by moon, even though i didn’t use ramping. Same thing if i fired a quick burst of max output (double click from off) and turned off without ramping. Next time it turns on at max level which may be unexpected and quite annoying.
In both case, the memorized level was forgotten and one of the shortcut has become redundant. I would have expected the memory to persist until some ramping occur.
Another suggestion i would make would be to have an option to limit ramping to a level that the light can at least sustain for a few minutes without stepping down or becoming ridiculously (and possibly dangerously) hot. It’s actually too easy to go overboard with this light. On most lights with a turbo mode of some sort, you have to do something special to trigger it - at least click through the other modes for instance.
So… there happens to be a fairly popular 219B FET quad: the Astrolux S41. I have one, and I notice a distinct shift to a much cooler tint after a second or two on max with a Sony VTC6. I don’t see the shift with an LG HG2 or Samsung 30Q. Output was 2272 lumens at power on with the VTC6 and more like 2000 with other batteries.
The D4 has significantly lower resistance than the S41. That means more current, and the 219B won’t respond in a good way to that. Tint will get cooler, CRI will get worse and the emitters may be damaged. A 219B D4 without adding a resistor to the circuit doesn’t seem like a good idea to me. 219Cs do come in 90 CRI though, and they still have nice tint and CRI when driven crazy hard. Some do prefer the tint of the 219B (I’m one of them), but the 219C is getting tint deviation bins, so it’ll be possible to order more rosy versions.
Yeah that was one thing I did not know about 219b. As you and ToyKeeper have pointed out, it seems for high cri 219c 4500k 90CRI is the best option. But the bad thing is that it is not available. I do not know why they went with 82 cri 219c. Is it because of cost or availability of leds?
For the tint, I think the reason behind 219b’s beautiful rosy tint is its high R9 value. I do not think 219c can achieve this tint without that high R9 value.
219Bs in R9050 are usually a bit on the rosy side, and the R9080 in 4000K is reportedly not nearly as rosy as the 4500K. 219Cs in R9050 that I’ve seen so far aren’t rosy at all, however, Clemence reports that tint deviation binning is coming to the 219C and it will be possible to order bins that are more rosy or at least less green.
I have no insight in to why Hank chose the emitters he did. The 219C is widely available in 4000K R9050, which is used in production lights from Reylight, Kaidomain, Eagletac, Manker and others. It comes in other color temperatures and R9050 too, but the only one I’ve heard of in a production light is 5000K in the Astrolux S41. Clemence sells a number of color temperatures, so it’s not like they’re impossible to come by.
