ENEDED
Spring could be silver plated. Will regular solder and temperature work on them?
Ok, Pete7874 had spring issue too.
Thank for pointing it out. We aware of the issue of spring soldering, Will find a solution to improve it.
Hhmm. Hobbyists typically use leaded solder, while manufacturing uses non-lead solder. I'd think leaded solder should work fine with silver, not sure bout non-lead. Always wondered if silver coated springs is real silver, or do they cheap out on the thickness of the coating so much, the bonding is a problem.
I have haikelight SC02, it’s great, except the oring
interested in this light
Do you mean the XHP35 HI version? i dont know, Haikelite only mentioned briefly yeah could be that one. but frankly i have no idea but that one is a zoomy right so that could not be it?
yeah Pete7874 also has the same spring problem, i notified Haikelite earlier and they are aware of the problem.
I opened the board from MT02 and MT01, i noticed that the solders are not flowed properly and the solder was rather dull no wonder you could crack the solder easily. i had to reflow that and replace the solder with a usual leaded solder plus a little flux and it was also only soldered on one side. I wish they could improved that, kind of ruined an otherwise a good quality light.
Put me down for one please.
already added two sodering tin joints in all stocks to improve
I’ll take one, with an extra reflector if I can too so I can try both
interested
Good to hear.
Interested depending of the price
also depending on price, but definitely interested
Already released, any updates?
Should be listed for sale next week.
Interested
Freeme does the GB being approved yet?
interested
Interested
Hello Haikelite, I have dedomed my MT07 4S CW and it throws further than my NitecoreTM16GT
So I am very curious about this new concept.
