MTN Electronics: LEDs - Batteries - Lights - Chargers - Hosts - Drivers - Components - 1-Stop-US Source
8370 posts / 0 new
RMM
RMM's picture
Last seen: 3 months 5 days ago
Firelight2 wrote:
RMM wrote:
...Quite a few with what I would consider to be V1.9 firmware (newer thermal throttling, but for more uses it is as good as V2.  If it blinks in the middle of the ramp then you do not have V1 firmware.
Main difference I've noticed between V1.9 and V2.0 is that V1.9 has some bugs. With my V1.9 light, I'll start off in moonlight and after a second it will occasionally jump to max turbo.... not good if you happen to be staring into the emitters admiring the pretty tint. Don't ask me how I know.... Evil I've also noticed that sometimes my V1.9 light will start in moonlight and then step up to a low brightness on its own even when not being touched. In all other respects it functions just like V2.0. However, V2.0 is better because it has no bugs.
Yep.  If that happens, then you can reset the prediction table by loosening the tailcap to remove power to the driver and it will temporarily reset the bug until you hit thermal protection again.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
RMM
RMM's picture
Newlumen wrote:
Hi mtnelectronics, i was told shockli 26650 5500 mAh in button top are available. When will you stock them? Thanks.
We have already had two batches of them come and go, and we are waiting for another batch to arrive.
RMM
RMM's picture
Just a heads up: we have more D4 that came in this morning and we are going to be finishing up testing in the next few hours, so look for them to hit the website later this evening.  cool
JIGHEADWORM
got any green 18350 tubes this time .I got a green d4 last week but tubes where out.
RMM
RMM's picture
Yeah, we got some.
vwpieces
vwpieces's picture
Last seen: 2 weeks 6 days ago
Richard,
Is it possible to get the 30mm FET+7135 Driver – 2S Momentary – Convoy L6
with the D4 firmware?
JasonWW
JasonWW's picture
Last seen: 9 hours 37 min ago
vwpieces wrote:
Richard,
The D4 firmware is kind of a stripped down Narsil. Most noticable is it lacks memorized levels.
It would be better to ask if full Narsil was available.
RMM
RMM's picture
vwpieces wrote:
Richard, Is it possible to get the 30mm FET+7135 Driver – 2S Momentary – Convoy L6 with the D4 firmware?
Yes, but I would change the firmware so that it only uses the 7135 for moonlight.
---No offense to Tom, but I haven't been a big fan of Narsil's UI---too complicated.  I played with it early on and it was a pain for me to figure out, so I could imagine the frustrated e-mails I was going to receive if I offered it on any drivers.  I also haven't received many requests for it, so I never got around to optimizing it for any drivers.  Maybe it has changed enough in the past year to change my opinion of it, but I will have to look at it again and see.
Smittymojo
Last seen: 1 year 4 months ago
Richard, Just want to confirm you are going to get some more of the button top Shockli?
RMM
RMM's picture
Smittymojo wrote:
RMM wrote:
Newlumen wrote:
Hi mtnelectronics, *i was told shockli 26650 5500 mAh in button top are available*. When will you stock them? Thanks.
Yes, we have hundreds on the way.
We also ordered more Aspire 18350s about three weeks ago, but I haven't heard anything about shipment yet.  I am checking up with them (they were slow last time too).
Lexel
Lexel's picture
Last seen: 1 day 22 hours ago
you may also choose the TA 8+1+FET with NarsilM
I got 2 of em here right now
can be configured as you wish
RMM
RMM's picture
Lexel wrote:
you may also choose the TA 8+1+FET with NarsilM I got 2 of em here right now can be configured as you wish
Added D4 as an option on the 30mm FET+7135 and got it all tweaked for 2S.  If there is enough demand for Narsil, I will add that as well.
Smittymojo
We also ordered more Aspire 18350s about three weeks ago, but I haven’t heard anything about shipment yet.  I am checking up with them (they were slow last time too).
Sounds good, I’ll keep an eye out for them.
Thanks
BeardedRaleigh
BeardedRaleigh's picture
Plan on putting this in my S70S. Any forceen problems?
Slow is smooth, smooth is fast.
JasonWW
JasonWW's picture
None that I can see except the size. The S70s is smaller than 30mm, but I can’t remember exactly what it was. 27mm or so.
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 41 min ago
What did you have to change for 2S? Could I get a copy?
From what I recall, it didn’t have code to handle voltage measurements on 2S, or at least the comments suggested that it might not work (and I didn’t try it).
korpzgrinda
korpzgrinda's picture
Last seen: 3 hours 52 min ago
Location: Eastern Woodlands in the Wilderness of North America
Thank you for posting this Richard. I saw it and was able to make an order later that night for a green Nichia version. It was shipped the next day and received yesterday, so I had time to mess around with it over the weekend. Thanks again for such prompt and thorough service!
I honestly didn’t get all the hype behind this thing. I understand now…
RMM
RMM's picture
ToyKeeper wrote:
What did you have to change for 2S? Could I get a copy? From what I recall, it didn't have code to handle voltage measurements on 2S, or at least the comments suggested that it might not work (and I didn't try it).
Enable volt_mon_pin7 option, add tk-calibWight.h header, define 360K option, change ramping level tables, fix a few other broken references in the code.  It's not clean enough for you to see it yet, but it is working.  Let me get to cleaning it up, then I will share it.
Lexel
Lexel's picture
In NarsilM you also have to disable Onboard_LED line
PBWilson
Last seen: 2 hours 51 sec ago
Richard, I read that you are ordering some S2+ hosts in desert tan and clear, but will you be stocking the desert tan flashlight with Biscotti?
RMM
RMM's picture
Perhaps at a future date, but not in this order.
BeardedRaleigh
Can you add this to website please.
DB Custom
DB Custom's picture
Last seen: 5 days 3 hours ago
Priceless! Big Smile
(Remember, it is actually Richard’s wife Lisa that prints that receipt… just sayin)
RMM
RMM's picture
Lisa says the price is $7.95.  money-mouth
Gunga
Gunga's picture
Last seen: 15 hours 2 min ago
Oh that’s too cool!
b1i1l1l1y1
Last seen: 6 months 1 week ago
Any idea if/when any 1.6mm thickness drivers will be in stock again for 17mm or 20mm diameter?
allcool
Last seen: 1 week 1 day ago
Will you get any convoy s2+ holsters..? They seem to fit the D4 well…
JIGHEADWORM
Do you have a fet driver that will run an xhp 70.2 in a convoy l2?
RMM
RMM's picture
The 20mm should have some.  The 17m FET driver is only 1.6mm, and it is an option for the 20mm FET+7135. 17mm, I am not planning on any, at least not for a while.
DB Custom
DB Custom's picture
Efficiency, a difficult assessment as well as tough to maintain.
Richard trys so hard though! Like, I ordered 4 emitters that weren’t available bare, on 16mm Noctigons. I also ordered some quad boards. Richard saw a need and pulled the emitters from the Noctigons then re-flowed them to the quad board. Efficient! And then adjusted the price I paid, efficiency again!
Only problem with the efficiency is that I needed the 4 16mm Noctigons. lol I’ve got well over 100 of the 20mm SinkPAD’s, but somehow I can hardly ever find a 16mm MCPCB in my kit. Oh well, I’ll have to order some I guess, one day, if I can remember to.
I didn’t say this to gripe about anything, but if you, like me, actually want the boards your emitters are on for a different project it might be wise to clarify that in the notes so Richard knows. Wink
Heck, if I’m not careful he’ll have my light half built for me before I can fire up my soldering iron! Wink
Yo Richard…Love Ya Man! Big Smile
