Haha Mr.Scott, it is such a gift you decided to do the sorting and make mass PMs easier with SB
It takes away a lot of hunen error possibility , very useful in this strange GT situation that is rather complex and where errors could lead to very unhappy people, can’t thank you enough
I would not feel comfortable dedoming an XHP35, and am glad there is the hi version to be used.
I take my hat of to those who dare do it
I just had a thought that worried me, what if there is a problem or glitch with the PM system and some people on the list don’t get the payment request message and miss their opportunity to send their down-payment on time…
Can I ask that when you start sending the mass PM’s that you update the list so we all know what members in the list have been sent the payment request, and who has already paid?
we are about to test the mass pm sending.
of course a list of people paid will be kept
And yes it seems smart to post the nicknames of those to whom the pm is send to, good idea
New beam-shot. I swapped out the prototype’s cool-ish LED with a 3A-bin neutral white (the production units will also come with neutral white emitters):
Original LED:
Both shots were done using 5 s exposure, manual white balance, ISO100. Distance to tree is 150 m / 500 ft.
At first I wasn’t sure I agreed with calling it “Giggles”… but looking at Giggles next to other lights I think you’re right. That’s it’s name: The BLF Giggle Thrower, or Giggles for short.
I think you’re probably right, and it likely doesn’t need more than it already has… but I could probably patch in more detailed thermal regulation (copy/paste from the D4 v2 code) if it’s needed, or you could too.
With the GT’s mass-to-power ratio though, it’s probably fine.
what are we looking at for the final numbers
1.1 ? 1.2 ?
sure hoping its more than that on the finished product
theres modded tn42s running around out there ,with over a mill lux, and at half the size of the gt to boot
It is possible although it would add a fair amount of complication to the GB with the risk of people getting the wrong tint.
Like Miller said, With a thrower like this a cooler LED will give a bit higher readings on the lux meter due to the non-linear way it reads light tints yet in the real world you can easily see further with a warmer LED.
This is due in part to refraction in the air scattering blue light more then red (the same reason the sky is blue). This does several negative things.
Firstly is disperses the light quicker before it reaches the intended target.
The scattered light returns to your eye and washes out your vision making it much harder to see long distances due to having to squint.
On top of this cool LED’s have much worse contrast and it makes it harder to see details. At range this becomes even more apperant.
The end result is I have seen multiple times that a thrower that has higher throw numbers and higher lumen output on the meter get beat by less powerful light in the real world.
For example my S70 had a cool white LED and had numbers that were roughly 10% higher then my L6 that had a neutral white LED.
When I tried them out side by side I fully expected the S70 to shine further and be brighter obviously. Turned out that it was exactly the opposite. The L6 won easily and unanimously among many sets of eyes. I was so shocked I even swapped the batteries thinking maybe the S70 cells were low. Nope, same result.
The L6 could easily see 10-20% further then the S70 in the real world and you could see more detail at range as well.
I sold my S70 shortly after this.
To be honest going with a Warm white LED would most likely net you even further real world throw even at the loss of output due to lower bins.
