JasonWW in case you didn’t see this HKJ tests for Shockli
Thanks.
Very nice performance. I wonder what kind of amp draw you’d get from the Shockli in an L6 with a fet driver with the 70.2?
Hi all,
Has anyone done a direct comparison type test of Convoys copper mcpcbs vs like sinkpad or noctigon? They seem very good, I’m just wandering if there is anything to be gained from one board to another. I see here in this pic there is some kind of a mask over the center pad…
https://www.aliexpress.com/store/product/CREE-XLAMP-XHP70-N4-1C/330416_32651022105.html?spm=2114.12010612.0.0.4db25147EXJbv4
We had some really heavy fog roll in Saturday night. Heavy fog looks amazing in the beam of a high powered light. :sunglasses:
I set my L6 on the patio and took a few pictures. You could see the water vapor swirling in the air like a micro-snowstorm.
I also had my Q8 prototype near the door so that one had to come out to play too.
Fun in the fog.
Very nice pictures j-dub!
anyone know where to get a translucent tailcap for Convoy L6?
Simon of course. He has the side switch cover as well.
Thanks, i will ask Simon.
Or banggood or kaidomain. you need to look for 16mm diameter.
thanks.
I think Simon is the only one with the translucent side switch if you wanted that.
He will give you a couple for free, just pay for shipping. Or if you buy something from his store, he will toss them in for free. He’s a good guy.
yeah he answered my PM earlier today, he offered me both translucent switches for convoy L6 i am going to order S2+ desert tan from him.
I finally got my convoy l6 in xhp70.2… very nice light, and heavy too…hot spot is big. The side switch is disabled… only tail switch…
Why would you only want tail switch operation? It’s very awkward to hold like that.
I find it much better to hold in the middle of the light and turn on/off, etc… using the side switch.
Well tailswitch is cheaper… according from the skylumen, tailswitch l6 is $150. Sideswitch is $170…
I got my l6 testing sample for $120… so I am happy with that… skylumen said this l6 is tough mod… it put out 6500 lumen and 135k lux…
My Black L6 is now doing 8,230 lumens @30 secs, and 195 kcd, with a XHP70.2 P2 3B, running NarsilM. At turn on, it does 9,100 lumens. It gets quite hot @30 seconds of course...
The side switch works great with smooth ramping.
30 seconds of course…The side switch works great with smooth ramping.
That’s impressive lumens. I wish I had a lumen box/tube to measure mine.
Out of curiosity, what cells are you using and what amperage are you pulling?
Two LK's at 4.20V, one solder topped. Amps measured was 17.9A. Ideally, best if run with higher resistance cells - just too much amps, too much heat.
Two LK’s at 4.20V, one solder topped. Amps measured was 17.9A. Ideally, best if run with higher resistance cells - just too much amps, too much heat.
Oh, I know what you mean. I got 17.3 amps. It heats up super quick. I try to ramp down Narsil just until I see the output reduce a little bit and keep it there. It’s probably 5 to 7 amps if I had to guess. Then I use full power just for testing or for distance use. That’s more practical since I use it a lot as a work light.
Your l6 can turn on/off using side switch? Mine only changes modes.
