This is the most pocketable thrower out there with over 1000lm possible with decent high current battery (to get highest light output spring bypass might be required).
Two LED tints are available: 1A(cool) and 3B(neutral), driver uses Bistro firmware developed here at BLF, turbo mode is direct drive (through FET), low modes are regulated by 1xAMC7135. Lots of mode configurations to choose from (driver is programmable).
What’s more it’s still possible to lower the price further with BG points!!! Prices can be as low as in table below(provided enough points is available):
New Ampcore Plus USB cables are now in preorder with great prices.
Those new version cables have metal plugs and are kevlar reinforced, cable organizer is included.
Only flashlights from the above list can use 17FLANNP coupon code. Collection includes almost hundred flashlights, batteries and chargers from leading brands.
Note: some flashlights have better discounts using dedicated coupons - remember to check list in original post first.
LED: XHP35 HI D4, dual tactical switch (both on tailcap), switchable tactical and general purpose/outdoor modes. Range exceeds 600m (650yds).
Magnetic charger connector and quality 3600mAh cell included.
