We have something in common gamezawy.
I got my SST-40s that I ordered from Shenzhen Great Technology on AE. All three appear to be the real deal. I also got one from Kaidomain and it is also a real SST-40.
There are some slight imperfections though. The one from KD and one of the Aliexpress ones are slightly raised. Probably not enough to be a concern since there is still solder under the center of the emitter. I will probably try to get the Ali one seated correctly since I plan on driving that one harder than the others. The DTP copper feels soo much nicer compared to the thin aluminum boards the others are on.
About heat:
I tested in a convoy C8 host samsung 25R battery, 10x7135 3500ma driver and with xpl HI the light got 60°C after 15 minutes.
Same everything with SST40 I got 61°C.
The XPL HI output with full battery is 1056 lumens and the SST40 I measured 1122 lumens.
@ gamezawy - Yes that is the seller I bought from.
I measured 8,2A and 1938 lumens with TA17 driver in Convoy C8
Im really liking the tint on this SST40 from both Shenzhen Great Technology and Kaidomain. Im not really a fan of colder tints but these turned out surprisingly nice. It has a pinkish white tint compared to the blueish Cree (cool white) emitters.
I have them DD’ed in a Convoy C8 and it is performing really well. Very happy with them.
Nice!
I tried to get my first sst40 mod working last night but those mcpcb’s from kaidomain were too thin. Have to make a spacer to get them to fit…
I’ve experienced the same. Very nice uniform beam and tint. It’s not nice as in pure white. It definitely has a tint but as was said this tint is a pale purpley tint. Hard to describe as it’s not the normal led tint we are used to.
Has anyone thought about sticking dedomed SST-40s under carclo 10 mm optics? For example with Emisar D4.
There’s no PCB for it, but since die size is similar to the XP-L, it should be floody, but not all flood. And significantly brighter than XP-L HI…
It wont be much brighter when de-domed. Hard to notice by eye and only at super high currents for a few seconds (20+A with three LEDs).
The way I see it:
- SST-40 has similar current-output curve to XP-L V6
- By chemical dedoming you lose roughly 1 bin, so it’s 2 bins ahead of XP-L HI
- But Vf curve is way lower, so it draws more current
Xml2 T6 shows almost the same result as highest bin xpl it is a bit strange. Xml u4 then will be best emiter.
I don’t really agree. I think if you want maximum output the SST-40 is the best from 3V emitters.
Watch my numbers in the Convoy C8 section.
Looking at your (very nice) chart I see that you miss a C8 with XP-L V6 dedomed. It is not that you should have one but with a collection so complete…
That's a great chart ZozzV6! Very useful for comparisons. Really like the SST-40 beats the XPL2 V6, even at less amps! And the dedoming, like you said, doesn't lose much in lumens, but still nearly doubles the candela. Wow! I gotta order some more!! Have 3 on the way.
Thanks A Bunch for the meticulous work!!!
Thank you!
Half of these lights are one of my friend’s property. And I don’t own 12 C8 at the same time I build some of them for request. And for the SST40 tests I replaced the leds and drivers in my grey c8 which earlier had the xp-l2. I wanted to see what mod worth the effortand what led is the best for a specific purpose. I know that I had to try them all but now I can refer things to people if they had idea for a special flashlight. :innocent:
Higher current means the battery sags faster, so the current is reduced faster than at lower currents. Also the light gets hotter.
Correct. Hotter, less efficient, but with higher peak brightness.
My 219c D4 is not too hot with VTC6. SST-40 has higher Vf curve, so it wouldn’t be too hot with this battery either.
Can’t wait for those VTC5As to arrive….
