Of course, when someone finds a very good IC that would work great with a driver, just post the datasheet. And if there is some interest, I can make a post briefly talking about different possibilities to “convert” regular buck drivers into LED drivers.
The 15A TA buck driver that nobody has built or tested yet.
Do you mean the SRK type driver?
4x18650 series boost driver to power a XHP70.2 at 6000+ lumens with configurable brightness and number of modes from 1 to 7, ramp up, down, easy access to turbo and firefly, hidden SOS and blinkies, e-switch compatible with a find me led under the rubber button
OK
A driver with:
6V input (2S)
Output two independent 10A channels (controlled by own switch)
Fan connector that recieves power based on either or both output cmchannels (so when the two are at max, fan runs at max)
4s boost driver for an xhp70? Are you thinking of a buck driver? Or a 4P boost driver maybe?
Firmware sounds like you just want it to work with Narsil lol.
Which diameter?
Is there a test for the XHP70.2? How many amps do you need for 6000 lumens?
Ideally I would love a buck-boost driver with a 2.5V to 24V input, 2.5V to 36V output at 100W+.
Realistically I’d like to see a boost driver based on the MP3431 IC, and a buck driver based on the MPQ8632-20 IC.
For MCU it would be cool to see something more modern like an MSP430 or even an ARM Cortex M0+, but at the very least the Tiny1617.
Multiple output channels for multi-color lights would be nice.
1. Buck-boost-FET, 1s/2s in 1s/2s out. On fresh battery, it’s a buck. On less fresh buck-boost, at the end boost. For max power, FET. Near optimal efficiency and optimal peak output.
2. High power, very efficient 3V in 6V/12V out boost. Actually moderately-high power (like GXB17) would be superb too if it got first-class firmware.
Buck/boost driver for high Vf UV LEDs
Input 1S
Output 3.8-4.4V max. current 1500mA
At low current Vf can be down to 3.2V
If possible double sided 17mm with 5-6mm spring pad
For e-switch lights, firmware will probably be relatively simple. I’ve been making a UI toolkit which abstracts out the hardware details, so pretty much any UI should be able to run on pretty much any hardware. When there’s new hardware, patch the toolkit to add support, and then every compatible UI should work with little or no changes.
Or that’s the idea, at least. So far I’ve only actually tried it on the D4 and Q8 drivers.
A 17mm 3.7v input 6-12v output boost driver to put xhp series leds in a S2+ or C8.
Edit: or mtg2 leds
It should be roughly the same as the xhp70 tests with a bit lower Vf.
At 6V it should need around 10A to reach 6000 lumens. Pretty normal for an XHP70 in a flashlight. Some are driving the .2 versions to almost 20A.
As a general rule we like to drive each die of an LED to 5A and as high as 10A. Less then this is not in great demand on BLF but there are cases where people would want this.
Big, 4 26650 touching for 2S4P
Haven’t measured it but 46mm would be nice for compatibility.
There are a few that I want.
1. 1S Buck-Boost Driver for 2.8-4V LEDs which does up to 5A, but it configurable down to 3A. Controlled by eswitch with many low modes (like Zebralight), overtemp and overdischarge protection. Maybe also a version for clicky switches.
2. Buck driver with 7-8A for 3-4V LEDs and 2S-3s input. Should have all the usual features.
3. 30-50A Buck driver for 3-4V LEDs with flashlight compatible form (round, diameter not more than 50mm). Battery input should be 3-4S (with very low internal resistance). Must have overheating protection for driver and also LED. Must also have additional, small buck circuit for much lower modes. I know this one is rather difficult, but as long as it stays under 100$ and is actually useable it would be great. It would be used with Luminus CBT-140 and CFT-90 LEDs.
4. Boost Driver for 6V or 12V (preferably 6V) with 30W output, lots of low modes, eswitch, and all the other usual features.
A twin button e-switch driver with miniscule queissant current draw, as I’m tired of button pushing!
Edit for spelling correction(s)
As a Buck-Boost, one option would be the TPS63027 usable, maybe up to 2A for UV LEDs.
The more you step down voltage, the less efficient the driver is. So a 2S config for 3-4V LEDs would be better, or 4S with 2 3-4V LEDs in series or one 6V LED.
Agreed, it would be foolish to input 4S and output 1S at 50A. There is no single LED that can handle that so you are better off running multiple LED’s in series. It makes things much simpler and more efficient.
Remember, voltage is easy, you pay no penalty for voltage other then needing to make sure your components can handle it (very easy up to around 30V).
On the other hand you pay BIG penalties for current. A 50A buck driver would be very difficult, I know as I am working on a driver that needs 30A and we ended up needing to split it into 2 separate 15A drivers to get the features we wanted.
I need a 17mm boost driver to run a Nichia 144A at around 3 Amperes from 1 cell.
It would be nice to have a boost driver like that with the option to set the current, like from 3 to 6 Amperes.
Optional e-switch would be nice too.
