I probably don’t know what I’m talking about but here goes
9v MT-G2 to 3S
we all hate pwm and we all want the efficiency I love ramping but it seem like the D4 is (dear I say it) too much of a hot rod for getting more lumens for longer time. (yup most lumens its great) but I keep waiting (and I think some lights can do it now) but 3k-4k continuous in a nice tint. Yes I know that the heat dissipation of the material is/can be a bottleneck even in lights larger then the D4.
Love the BIG floody MT-G2 when can we make them in triples?
XHP to me has too many artifact issues and unpleasant tint (never heard of a 4C tint in an XHP 35, 50, 70)
Again not up on the latest but what about progress for us guys who want say the smallest light possible that will run three MT-G2 at 3000 lumens continuously with out getting too warm. don’t care if turbo is 5k or 6k or ?k the peak numbers are almost a game because they don’t address what it take to keep belting out big lumens.
Love the D4, but its a case in point, it can run over 4k lumens but struggles to constantly run over 400-600 depending on emitter. again not an expert and not up on the “latest” but it seems like something is missing in the “improvement” trend over time of technology.
And yes I am thinking every day use (not necessarily carry but at least use) the BIG MONSTERS just don’t seem to get actually used.
I know its a jumble and thanks for listening
P.S.
There also a 36v MT-G2 that we never get to use.
6v
9v
36v
If we were starting from scratch with would be the smartest voltage to run?
I so badly want a 2S current controlled buck driver that will output 5 to 6 amps at 6 volts! And then, a single cell boost driver for use with good 18650’s or 26650’s that will run the XHP50.2 as it should be.
right now, a driver that can drive the 6 and 12v xhp70s to 6000 lumens so i can put 3 of them into my chunky monkey. that should be about 8-10A an LED…
Personally I don’t see much use for the voltage references that the 1616 and 1617 offer. You still need voltage dividers to utilize them to measure the full range of voltage levels a cell can have. To use the 4.3V internal reference, VCC has to be at least 4.3V anyway.
The size of the 1616 interests me though, but other than that it won’t do much more for me than the easily available and widely supported 1634.
Maybe, I did not say that correctly. I would like to deliver 6 volts to the led, not something around 8 volts falling off to 6.something volts. And I would like to do it at a constant current as long as possible. The big thing for me would be regulation and not direct drive. Gives battery life stability if all of the modes are regulated. Currently I am using 2S FETs and a very old constant current from the BTU Super Shocker (I think) but it only delivers around 3 amps to an XHP50.2.
My understanding is that if it regulates current and voltage, from a voltage source above the rated LED voltage that it would be a buck driver? Correct me if that is wrong, have been building 1S lights for a good while, but 2S+ are more recent builds for me.
Both of you are right, although a linear driver for 2S voltages would be very inefficient and would be at risk of overheating.
Depending on the size of the driver there are already buck drivers for the xhp70 that do what you want. The FX30 in the convoy L6 does 5A from the factory, same for the driver in the S70 but those are both 30mm drivers.
I am looking for something in the 17 to 19mm range for my convoy M1 (MT-G2) and Nightfighter (XHP50.2) that will deliver more with out getting stupid with a full on FET.
6V LEDs use closer to 7 or 8v especially when driven at higher currents, so you won’t get stable output for very long using a 2S battery unless you had a special buck+boost driver that will keep a constant current even when the battery voltage drops below the LED voltage.
A buck driver would be something like 3S or 4S to 6v LED, 2S+ to 3v LED, or 4S+ to 12v LED.
Right now i would like to have boost driver with 2S input and output of about 100-150W and output voltage for 6 x XM-L2 in series, or maybe 12 in series. I have that 12xXM-L monster but can’t find good driver for that. Leds are now 3S2P x 2 and 2S input with FET just won’t work.
A good 1S driver to drive a 6 Volts LED would certainly sell.
Nearly ordered a H1-A from Kaidomain, but it has PWM at a clearly audible 3.6 kHz.
I don’t want PWM at all actually…
