I need three 18350 flashlights
I already have the D4 with 18650 tube :smiley:
Well get the $5,- 18350 tube, and you will have the cheapest solution as well! :smiley:
Solarforce l2m? If you can find it nowadays.
Jaxman E2L
Emisar D1 (once it’s available).
Blf a6/astrolux s1 with short tube, or the S41 both for under 20 euros at bangood at the moment.
S41 for under $20 is a must buy i.m.o.
You don’t want to go for a 2x18350 light?
Hum, what would be a good suggestion for one of these 2x18350? :sunglasses:
BTW, nice ones above! (I think I’ll have to get an Emisar D4 too… :person_facepalming: )
@ L4M4
The Convoys S2+ are the ones I use with 18350 and I’m not disappointed so far! I’ve been using them with IMR18350 Keeppower but some Aspire are arriving (from Neal) so I’ll check what they can do with those :smiley:
If you want to mod it you must buy the host only version because of the glued PCB. IMO the nicest 18350 light in the universe.
Do you know a good place to get the host? Jaxman store does not have them available.
Emisar D4 modded to use 2s2p emitters?
Emisar D1 with dedomed XHP50.2 for 2500-3000 lm and 25-35 kcd?
ai, so the E2L host is sold out :frowning: The aliexpress Jaxman store was the only place that had those. I hope that they will make a new batch of E2L hosts.
Thanks! I’m just not familiarised with what 2s2p emitters are… :person_facepalming:
Gonna check that around! Anyway, that would imply the 18650 tube and the 2x18350 cells inside, right? The driver would have to be modded/changed too?
(I guess that sticking with a stock light with just 1x18350 will be easier for now as I’m not savvy enough to make those mods or dedome!…)
D4 has all the LEDs wired in parallel, 4p. 2s2p is having them as 2 parallel groups of 2 emitters in series. Doing so halves electrical loses of the host. It also spreads the load over 2 cells. But the cells are significantly weaker, so it’s uncertain (to me) what would be the gains. I suppose they would be small.
Thanks for the explanation! Regarding capacity in runtime, 2 18350 will certainly loose for a 18650. Maybe the initial “boost” is better specially with IMR cells, but then it will certainly drop a lot.
Yeah, like I said, I guess a Emisar D4 stock light may be a good option, with 18650 and 18350 tube. :+1:
@ L4M4, there is Thrunite Neutron 2C V3 that goes with 18650 and 18350 too, with no extra tube!
Honestly, you should try messaging the Jaxman seller on Aliexpress. I just was looking to order a 18350 tube for the E2L host I bought from mtnelectronics.com, and they showed “no longer available”. So I messaged them about it, and they said the listing had expired and it would be up again. I checked back and it was available again the next day.
I ended up ordering the original short tube, as well as a black E2L host and black 18350 tube. This was just on August 16 and I’m still waiting for them, so I’m surprised the hosts are gone already. It really could be an expired listing or something like that.
Indeed it is.
But under 20$? where?
Well… I have a XHP70 laying around… :smiley:
I will think about that!
I won’t order a 18350 tube for the EMisar - that light is tiny enough and I have not the smallest hands, so a side-clicky light that small wouldn’t be nice to operate.
THe Jaxman is just too close to my two Convoy with triples (S3 grey, S2+ green) :P
those new aspire 18350’s changes the game for 18350 use.
That’s a novel approach to the hobby, order a new cell size then hunt for suitable flashlights. :open_mouth:
