I took my Noctigon camping. A group of us were around the fire when I’d taken out my Meteor and shone it around the valley and lit the whole place up. Lots of ooos and aahs. I then put it back into the case and placed it behind me. About 30 seconds later one of the girls asked where the smoke was coming from and then zoned in on the flashlight. It was on, in its case, melting the hell out of the case. I must admit to you, it was quite spectacular to watch and everyone was thoroughly amazed, however, there was me with my head in my hands at my second flashlight oversight since fully indulging in this hobby. I now need a new case.
One broken MT-G2 emitter and a burnt noctigon case. Joy. Don’t mix alcohol with high powered technology.
Got my white Noctigon M43 yesterday. The first thing I had to do was to clean in. They’re using black grease in the threads for the battery tube and it gets all over the flashlight.
As I screw it apart it also felt like sand in the threads. So cleaned up, new grease and wiped some contact spray on the plus pole contact plate. Now it feels very smooth.
I did a short turbo mode test this evening and it’s a wicked light for sure. Almost as bright as my car’s two HID aux headlights.
When the light is turned on and the button backlight slowly pulses red and blue, what exactly does that mean?
I didn’t noticed much difference in light output although the cooling fins became quite warm when the indicator started to pulsate.
When turned off it went back to constant blue indication (I have the beacon blue turned off).
Thanks! Ok I think it works very well then. More then happy with my new “compact searchlight”. :laughing:
A tip if you don’t want to undauntedly melt your holster - screw off the battery tube just so the o-ring starts to peak through under the head
and the power cells loose their contact. Sometimes it feels like a hassel to click 6 times to lock the button.
It’s a popular item, not easy to keep the supply high enough to meet demand. And I think Hank is busy with the D1 and other projects, so his D4 time is limited.
As far as I know the M43 is still "in production", but I think that they have pretty much paused M43 production until they get caught up on D1 and D4 production.
UI3 is Narsil, but with three levels. If you “set” all three levels to low, then however you turn it on it will be in low, and available to ramp with a click click and hold. The Turbo is a available with a press and hold from any level, including off.
The strobe and battcheck and other fun stuff are not as easy as Narsil, but still available.
I love UI3, it is my favorite interface for all of my lights.
I have mine set to low with one click, then with the double click it goes brighter, then again, then I can hold for turbo. nothing wrong with this UI, its just that narsil is so simple haha.
It looks complicated, but it’s one of those things that is very wordy to explain but simple in execution.
I use UI 3 and love it. I have my 3 levels set like BeardedRaleigh just mentioned. Here’s my explanation from a few posts ago:
While the light is on, double-clicking will continuously cycle through the three brightness settings. A ‘fast then long click’ moves backward while the light is ON.
Once you get comfortable with the operation, you can also use shortcuts to the three modes from OFF.
At any time while the light is on, holding the switch activates Turbo until you let go and it returns to the mode you were in. This is one of my favorite features.
Out of shear curiosity: Has anyone (maybe ToyKeeper) identified the used chips on the driver or has at least high-res photos of the driver where the markings are readable?
I found this post on TLF where I can see the components or a photo on some russian site but neither A335 for the D1 component or VT1 are readable well enough or can be found somewhere.
From the general circuit it looks like VT1 is the mosfet for the boost converter, D1 is the uC since it has pads for the switch and LEDS and D2 is some kind of OPV?
I’m just curious how they implemented everything (discrete buck IC + control µC, µC does buck in SW, …)
