Should be cool :+1:
You know, a simple pipe bomb can be made with not much more than a pipe and a 18650! Here’s hoping the driver doesn’t short on this one!
I like it. :+1:
Thanks lads and good luck every one! I look forward to seeing the lathes at work.
As you can see i have already put in a venting hole
Slightly updated so i have ran into a few bumps lol.
I should also say this is only the inside of the torch it will have a different outer shell.
Looking good !
Its a rush to get this done
made it flat and pretty on the threads took of heaps of stock
This was meant to have a wooden outside but i dont think i will have time to complete.
Angle grinder makes such a difference much better then using my reciprocating saw on smaller stock easier to handle besides the sparks going every where. I cut some M8 bolts with the reciprocating saw it works like a charm on bigger item plus no sparks.
Just a few days left - no pressure!
I must have missed this the pipe bomb light…
1 weekend left you can do it
Yea i am trying lol. Just done 3 hours or so now. I will eat dinner at 10:30 and go back out. I ran into a few issues.
Making the heat sink and shelf
press fit shelf lol mallet time
Drilled wire holes and now i am trying to deburr them?
Just a light touch with a bigger drill bit.will take the bur off
Thanks for the tip! I ended up going .5mm bigger in size i was having trouble getting the wires through but they are 22 gauge lol. All that is left is the tail cap but it does work all be it dodgy lol
I glued the optics in place only way i knew how to make it work and be water resistant.
Hahahaha don’t ask! This needs some TLC.
Tested with a safer cell first lol
Tested with a 18650 this time so much brighter.
So i had to shave down a 20mm board i have no 16mm MCPCBs so i done this lattice bright first. I could not do this to BLF so i shaved down an alloy board XPL-HI even though it pained me lol
The optics are random ones from Fasttech Ultrafire brand i think. So throw heavy!
I really wanted to add some wood but i have none and i know nothing about wood so i will see what happens. I want to make this look prettier i will polish it up a tad but i like the rough look of the brass fittings.
Buy some toothpicks, the tapered flat kind would be best I think. Glue them around the pipe, alternating pointy end direction. Predation or dye them different colors or TRY to find colored ones.
Thanks don that is an awesome idea! I just bought a glue gun the other day lol.
I just cleaned up and 5 mins later it looks like this
Needed to use my good soldering iron to get enough heat into the brass for the driver. 450 degrees Celsius
Making the switch retaining ring from 1mm aluminum its easier then the 3mm pill i made.
That is done i just have to widen the middle a tad bit
This XPL-HI has seen better days lol. I am not sure where i got it from?
So the light powers on so technically all that is left is aesthetic work. I want to add some tape here and there and maybe some plastic in case of shorts.
I think its to late for wood but i may add wood in the future or another scratch build coming up maybe?
We need beam shots! I was thinking about running the XPLHI direct drive and just using a partition board but its on an alloy board so it wont last long.
Hahahaha i was fishing on the Haweskbury river at Brooklyn and i went past some ones house and they where throwing out some old tree wood and i was like on the way back its mine. Then when i was back in Sydney i remembered about the wood. It had a sign and all saying free wood that was my one shot lol.
Might as well add some fishing pics. This is Brooklyn NSW. These pics are a tad older when i went the other week it was raining but fishing time is fishing time rain hail or shine lol.
Nice shots .havent been fishing since i left gladstone in central queensland.
Bit jealous.
So mine is done for now! Its not what i wanted but it works and functions as a torch.
I stuffed up the tail cap kinda i could not decide what i wanted so i went for a more classic look. I think the rubber boot doesn’t suit the light. So i made another tail cap ending from scratch but didn’t like that so i cut out PVC instead of an aluminium gasket.
I painted the battery tube in and out so its none conductive
I put some plastic around the driver as isolation
I wanted to paint it red but then didn’t like it so i stuck with the primer but you can still see some red lol
I will add beam shots tonight.
Beam shots here! Its actually better then i thought at around 800 lumens i am happy!
Pics at the usual ISO800
Congrats on finishing the build :+1:
s. I reckon you could do with a larger lawn mower
