It would seem HID is dead.
WOW bro! There is really something crazy behind that picture.
That’s a beamshot of the Maxabeam from DM51 over on CPF. It’s one of the nicest beamshots I have ever seen.
Because of the pictures age (~2008) it’s probably a Gen2 Maxabem with 3-6Mcp depending on the used bulb. The current Gen3 Maxabeam does 12Mcp. It also seems like the bulb isn’t positioned perfectly in the reflector (beam and spot are a bit fuzzy).
Hey Driver!
Yes this is surely a monster thrower. Like your LED version of Maxabeam here
But I have to admit that I would like to see some monster emitter in your edition and sacrifice throw a bit :slight_smile:
Is it just me, or does anyone else think that the BLF Giga Thrower really should be using HID instead of LED?
Only, when the luminance is the same or higher ;).
I am getting a BLF GT for bigger emitters (it has more batteries).
Not possible at this price point. Also only a standard car HID would be possible (35-80W). A short-arc would probably require 10x the cost.
I think LED is taking over HID in term of throw.
It will only get better in the long run when LED technology improve further :slight_smile:
HID bulbs are still faaaar ahead of LED.
I think I will be able to pass the maxabeam with my next LED flashlight build, but it’s gonna cost a lot of money and be pretty large.
Kudos to you for even attempting it!
I would still recommend saving up for a (used) Maxabeam. It’s such a great toy with motorized focus :D. The current models have no Step-Down and all Xenon bulbs have 100cri, so the light quality is much higher compared to LEDs.
Enderman will build another Zooka :laughing:
Thanks :slight_smile:
It’s expensive though, like $500+ usually, which I could put towards my next flashlight project.
On top of that, it is like 1.5x more expensive for me thanks to the canadian dollar xD
Certainly, I will not stop until I have a non-bulb flashlight that can beat all of those short arc lights on that graph :wink:
Well I guess you’re gonna need some serious XXXL aspherics for that… Good luck :+1:
Not this time, it will be reflector only :smiley: and thank you
I made an ‘invention’ for a reflector LED light:
“Wavien dome”
The dome will have to be attached to the glass lens
Pretty similar to the design often used for short arc lamps:
Compared to a lens+wavien collar of the same diameter it will have less lux though, since the lens won’t have the dead spot in the middle.
The lens will also give a tighter beam since all of the points on the surface will be at a longer distance from the LED.
Thanks but no thanks, I don’t really want to cosplay as Captain Toad.
Sure, but it would be fun (difficult fun) to try on the GT for example.
No more spill and a bit more beam.
Yup.
Wait…I must have missed that memo about hid’s getting phased out. :person_facepalming:
Hmm, what’s the “texture” on the front lens of the Polarion?
It’s a factory diffuser. It just clips in the grooves of the bezel ring. They work amazingly.
I call the diffused light from this a big ol ball of cotton beam, removes the hotspot completely.
