I found the exact LED gaskets too:
http://www.kaidomain.com/p/S024686.11mm_8_2mm-White-Plastic-Insulation-Gaskets
A thicker lens will probably prevent the bezel from screwing down to the head all the way.
I would suggest to search for a lens with the exact same thickness as the Skilhunt lens.
the 16.9x1mm fits perfectly, I remembered it thicker
Jerommel, are you still willing to sell me the reflectors or I can send you the tirs they replace?
I would be interested in the reflector’s diameter & height so i can buy one .
Thanks
Yes, we’re gonna do an exchange (see PM).
It’s 15mm diameter and 17.3mm 7.3mm high.
Thanks ! It’ll be tough finding one .
MISTAKE!
it’s 7.3mm high.
Sorry…
I thought the same. I want the H03R but take too long to get here. I can get an H03 on Amazon in two days.
Where can I purchase the reflector and lens that will fit from? Prefer USA.
What about this reflector? http://www.kaidomain.com/p/S021651.15_8-D-x-8_8mm-H-OP-Aluminum-Reflector
Maybe it can be reduced in length…
Brands should sell spare parts i.m.o.
In this case, a headlamp reflector set = gasket, reflector, lens.
For TIR replacements they can simply refer to Yajiamei on AliExpress.
Hi guys,
I have emailed Skilhunt twice about TIR and Reflector parts and never got a reply.
Has anybody had any luck finding a 3rd party reflector that fits and works?
Thank you!
Me too
No…
I ordered one to try. It’s been delivered but I can’t find it. If I do I’ll let you know…
a downside of the reflector one is the hotspot of the NW is pretty yellow
I may consider a change, with the new AR lens, but it has its price to get a reflector H03 compared to the coupon TIR
Please keep us posted! Thanks
Yeah, typical small reflector hotspot, with a somewhat cooler white rim around the warmer circle of light.
I hate that.
It’s why i replaced the small reflectors of many of my lights with TIR optics.
What do you think the stock TIR resemble most in terms of angle? 30 degrees?
What TIR angles do you like most for your H03 or other lights?
I find the stock TIR is nice up close, but as soon as you want to use it to see further away, it diffuses and spreads the light too much.
yeah reflector has its advantages outside
but walking on snow with the NW Emitter looks yellow hotspot and white corona
