Sure. Just get it on a 20mm DTP mcpcb.
Thanks!
Does Simone sell spare OP reflector for convoy L6?
Not that I know of, but if you ask Simon he may be able to sell you one. You can contact him through his Aliexpress store.
ok so can someone link me to some batteries on ebay that work 100% with this light?
The problem with ebay is you never really know what your going to get. Could be legit cells or could be fakes. That’s why no one buys from ebay. Have you checked if Banggood, Gearbest or Fastech can ship cells to Sweden?
mortuus:ok so can someone link me to some batteries on ebay that work 100% with this light?
Maybe NKON can ship to Sweden too! The prices are not the cheapest ones, but maybe it can help!
sadly neither BG or gearbest ships those batteries to sweden anymore i am so doomed lol… i will check nkon thanks.
Is it common for the XHP70, XHP70.2 to only halfly light up on its lowest output?
Only 2 dies of my XHP70.2 are lit on the lowest mode, and noticeably dimmer looking on higher modes.
I was getting some faint flickering on the higher modes as well (fresh batteries), but have since not been able to replicate it.
No, this is a common problem with these new Cree “.2” LEDs. Your’s might be a defective one. A few people had problems with the XHP50.2 when it came it.
twisted raven:Is it common for the XHP70, XHP70.2 to only halfly light up on its lowest output?
I have not seen this happen as like the 50.2, yet? I would try to re-flow it with a bit more solder paste, I had one 70.2 do the same thing, well almost, flickering , low out put, testing on the rock, re-flowing it took care of it. The other thing was too much heat during the re-flow the solder mask turn color ever so slightly and the 70.2 ended up dying. I re-flowed another keeping better attention during the process, all went well!
JasonWW: mortuus:ok so can someone link me to some batteries on ebay that work 100% with this light?
There is no maybe.
They do and are relaible.
Jaxman sells the liitokala 26650 that do wonders in the L6, just add a solder blob. Jaxman battery link
I have ordered from them and got batteies delivered to Sweden.
Edit: Holy shit i just noticed the shipping price. That have gone up by alot since i bought from them.
MascaratumB: JasonWW: mortuus:ok so can someone link me to some batteries on ebay that work 100% with this light?
There is no maybe.
I know they are, I recently bought some batteries from them, and NKON and the batteries are reliable!
Took some days (a week, maybe) to arrive but were tracked and came well packed. The shipment is a bit pricy, though…
I normally buy my Li-Ion from an AliExpress store and so far they were reliable too (Sony US18650VTC6 and Sanyo UP14500P): https://www.aliexpress.com/store/1382210?spm=2114.12010612.0.0.5bdadf47w8hvZ5 .
L6vn - Power Pole 300 yards away.
That is SWEEET! Nice purchase. I’ve never owned one of his lights. Maybe someday…
We were talking about high-powered 26650 protected batteries earlier. The Orbtronic 5200mah is rated for 15 amps.
Another choice would be the Imalent 4500mah 26650. It is also rated at 15 amps. I think it tests at 5000mah.
I am using the Orbtronics,they are resting now after a malfunction w/ the torch!
First up was my STOCK TN32 that I bought in January of 2014.It lasted 5 days!There was no autopsy. I sent it back to Illumns and they replaced it. David[owner of Thrunite] was one of the first to chime in. He was very concerned, nervous and reassuring that I would be taken care of. They thought it was an isolated incident and I believe it was. Here are a few thoughts to how it may have happened: J.Mac-Holy cow! Looks to me like the emitter die was missing solder under the half that went bad a…
oke have to ask again, these purple efest work for l6 ? i think i read something about most flat 26650 cant make contact….
its so damn hard to find batteries that fits your budget and that can ship to sweden, aliexpress and other chinese sites is a no go for me… blah…
After a little hunting around I found some specs on those. They show to be 26.5mm ±.2mm in diameter. Does anyone know if that is acceptable?
If you look at the pics here
https://pink-mule.com/1-x-efest-purple-imr-26650-4200mah-50a-flat-top-en
you can see that they are a raised flat top so they should make contact. If not, you can always add a solder blob.
