This succinctly says how I feel about my D4 compared to my ZL SC62w.
I have the sc62d in work(only 320lm but use H2 mainly at 145lm!..………its enough for me), so easy to pocket and not know there. For an 18650 fed light, its sure impressive in the compact form stakes.
Here is the sc63w next to the D4
Been using the D4 xp-g2 4000k quite a bit this evening, damn this CT is nice. So easy on my tired and should be in bed eyes…………really like it.
Just a few rough n ready beam pics for a rough idea
Nice beamshots. Got to love that 4000k xp-g2.
+1 that was my favorite as well.
the D1 looks like it has great spill
although it looks like the camera changed the exposure
unless that one is out of sequence and was earlier in the evening
Mp0wer:Just got one delivered from MT, thanks for the review
Ah, so that’s where the last 4 Aspire cells went.
I had the page open to order, but went to eat first and when I came back they were out of stock. Oops.
Too bad I can’t try out my aspire batteries, I think there’s something wrong with my 18350 tube, the light works great with the 18650 and 18500 tube…any suggestions ??
did you try turning it around?
the shorter threads go toward the head
I did try both ends, I also tried using a paper clip to see if maybe it wasn’t grounding properly
Could you post a picture or 2 showing the 18350 tube, particularly the ends?
Thanks
you might try putting the longer threads toward the head
and then trying the paperclip to bridge the battery base to the bare tube edge
it’s such a simple tube there must be a simple explanation
like the shorter threaded part not reaching deep enough?
MPOwer
I had that problem. I used some steel wool on the edges/ends, mine works fine now.
Thanks
Interesting.
Just found out from reading on CPF about a hidden feature in the UI:
After you double-click while the light is on to jump to max turbo, you can double-click again to return to the previous brightness setting.
and then trying the paperclip to bridge the battery base to the bare tube edgeit’s such a simple tube there must be a simple explanation
The long side worked with the paper clip, but not with the cap, if you look at the picture one side of the tube is thinner.
Well, that is strange, butt we know the short end is the problem.
I’m sure Mtn will make it right. Give them a call.
Sub’ing because how did I ever miss this thread. Will have to order one here shortly…
Just to clarify, what are the differences in the D4 and the D4vn models? Somewhere in the last 70 pages I am sure I missed some important information.
The stock D4 is available with XP-G2 (dome on), 219C, or XP-L HI emitters. Vinh’s mod uses dedomed XP-G2 emitters for increased throw.
strayz:Sub’ing because how did I ever miss this thread. Will have to order one here shortly…
Thank you for the quick answers
I figured that Vinh had done something before putting his name on it.
Is that a hidden feature? It’s in the UI diagram, and Hank found it important enough to add some text about it to his version of the diagram. Here’s the image shown at Intl-Outdoor’s product page for the D4:
I measured my D4vn just yesterday, if that helps.
