Wow, D1S 700 meters? It was going to be my next purchase anyway. That’s more than I expected, (right up there with my old M31 Triton).
My D1 arrived yesterday and I played around a little with it this morning. I wasn’t expecting that much (over 400 m?) either, I was thinking maybe 200 m. I’ll have to give it a better workout tonight.
I still have some things to do before making a “1.0” release and merging it into trunk, but it’s already at a pretty usable state.
Things which still need to be done:
Finish more example UIs.
Add a half-sleep mode for things like a locator flash or alarm clock mode.
Add a waking idle mode for lower power use at moon/low levels.
Add support for voltage-divider style measurements on pin 7.
Add indicator LED support.
Add an option to use short-click/long-click/hold instead of just click/hold, because it’s needed for compatibility with UIs from fonarevka.
Test thermal regulation on a wider range of hardware, to ensure it “just works” on hosts of many different sizes and power levels.
Better documentation.
Hopefully make the fourth PWM channel less funky. It works, but not quite as well as the first three.
After “1.0”, it should probably also add support for newer MCUs, buck/boost drivers, more than one e-switch, and power-disconnect switches.
Oh, um, I also settled on a name for the “unnamed” UI. It’s called Andúril, because it’s inspired by Narsil. Narsil was the sword of Elendil and Isildur, which defeated Sauron. Andúril is Aragorn’s sword, the flame of the west, the blade Narsil reforged. Granted, it didn’t defeat Sauron — it only scared some ghosts. But still. I thought it would be appropriate, and Tom seemed okay with the idea, so that’s what it’s called now.
I don’t understand most of the things spoken in this thread, I confess, but I do appreciate your work and efforts - TK - along with the one of other members! Thanks for making better UIs and for putting your imagination “at the service of the Light”!!! :+1:
Now, following your last post, I just wanna suggest that the first BLF light with the “Andúril” UI be named “Mithril”, being a “impenetrable” maybe “bullet proof” flashlight!! A flashlight for knights that can be kings of the Light! Just saying
This forum is getting better and better (and I’m just a noob here) due to people that are working and investing time, money, intelligence and other resources to make things (lights, components, UIs, drivers….) that somewhere in time seemed impossible and that now are just cool and feasible realities!
I’ll keep on reading, and trying to learn a bit from this work!
Keep it up :+1:
Hum, don’t know if the FW3A creators/developers team would agree/appreciate that but…why not?
Sharp inside with Anduril firmware, armored and blasted outside with a silver “shining” look as Mithril, aiming to protect us from darkness
If it wasn’t a long name, “Light of Earendil” would also be appropriate :sunglasses:
(well, just hope these names wouldn’t raise Copyright or whatever issues)
Ohh, I was talking about the “Mithril” name for the FW3A, not about the firmware
Independently of the name of the flashlight, I’m sure I’ll love that firmware on it!!! All my lights have “conventional” clicky modes, so a ramping mode, also with clicks, and extras like those you’re inserting on it, will be awesome!!
Once again, thanks for the efforts on these masterpieces :+1:
goshdogit, it’s intended to be built with the bin/build-85.sh script and flashed with the bin/flash-85.sh script. These are written for unix-like systems though, so it’ll require adaptation to build in Windows.
It’s also a good idea to grab the entire repository to retain its directory structure, so all the files will be there. This is easy with bzr installed, or not so easy otherwise. Perhaps I should get in the habit of doing .zip releases of the entire repository, since that’s easier in Windows.
FWIW, this is what I’d normally do:
bzr branch lp:~toykeeper/flashlight-firmware/fsm
cd fsm/ToyKeeper/spaghetti-monster/anduril
…/…/…/bin/build-85.sh anduril
…/…/…/bin/flash-85.sh anduril.hex
The build uses fsm~~.c and fsm-.h in addition to the files in the subdir for the current UI… and some of the tk~~*.h files in the parent directory. Basically, it relies on having parent directories in the include path with the “-I… -I…/… -I…/…/…” options in the build script.
Thanks for the reply! I managed to download the header files individually and got a successful build.
I’ve got about 30 browser tabs open between two desktop machines and a tablet, but no Linux box. The last time I used unix was on a Sun Workstation in the tail-end of the ‘purple logo’ era.
Can you offer any guidance for the fuse values? I read some stuff that made me worry about bricking the 85 by using the wrong values.
I’m honored! I will fiddle with Andúril and report back with my thoughts. I’m loving it! I just put it on my D1, too.
I feel awful that you don’t have a Q8 to play with yet! As you mentioned when photos of the internals appeared, it’s easy to reflash because of the long emitter wires. Remove the two driver screws and you’re in.
I’ll be glad to test the illuminated switch when you add support. I didn’t put these pink 0603s in to remain dark!
I took a class in C (or was it C?) in high school, and I’m having fun browsing your code and attempting to understand what’s going on. It’s nicely commented. “Sleep dammit! (but wait a few seconds first)”
BTW, to turn the indicator LED on or off, I’m thinking maybe triple-click in lockout mode? This would configure whether the button stays illuminated while the main light off. Unless there’s a better place to put this option.
I could instead put an actual config mode inside lockout, for all settings related to standby behavior, but so far it looks like there’s just one option.
I’m also thinking maybe it should do something different with the indicator LED depending on whether the light is off or locked. Like, one could blink while the other is steady.
Speaking of sleep… I finally made it go to idle mode during regular output (and goodnight) mode, since the MCU doesn’t really need to do anything timing-sensitive. It keeps PWM active, and the voltage / temperature measurements, and the WDT timer, but it doesn’t need to do any actual processing.
This only reduced power use by 2mA, but that’s still useful. It means the lowest firefly mode went from 5.6 mA to 3.6 mA.
Was hoping to reduce it by 4mA, but that might not be possible without turning off some features it needs, like the ADC, or reducing the clock speed (which would make PWM slower).
I like that idea. I don’t like the indicator toggle in Narsil when you ramp and quickly power off the light. When I want to ‘park’ the light and set memory, I tend to inadvertently disable the indicator. Don’t tell Tom!
Yes. It seems intuitive that a solid indicator means ‘ready’ and a non-solid indicator means ‘locked.’
Do I remember you making reference to a ‘heartbeat’ or ‘breathing’ mode? Or something like a MacBook’s ‘sleep’ indicator?
I tried a couple other things. Running at 6.4 MHz seems to drop the PWM speed from 15.6 kHz down to 3 kHz. So that’s no good. I was expecting 12.5 kHz, not 3.0 kHz.
Turning off brownout detection reduces standby drain by quite a bit. Granted, it’s basically dropping from zero to even zeroer, but still. 24.7 uA with BOD enabled, or 0.35 uA without.
0.35 uA. That’s 0.00035 mA or 0.00000035 A. I had to use my Fluke to even measure it, since my regular DMM couldn’t.
So I think I’ll be leaving BOD off… It’s not really used in FSM and it increases standby power by a factor of 700.
It has no effect on non-standby modes though. So, I’m still at 3.6 mA or higher for firefly mode.
Dropping the clock speed to 4 MHz works. Moon mode is then 2.5 mA, but PWM runs at 7.7 kHz instead of 15.6 kHz. So I made it change clock speed depending on the brightness. The bottom ~dozen ramp levels run at 7.7 kHz and everything else runs at 15.6 kHz. This gives more stable and more efficient moon modes without making higher levels audible or strobey.
Long story short, I managed to decrease the lowest level from 5.6 mA to 2.5 mA, while also increasing the brightness from about 0.01 lm to 0.10 lm. This means a usable moon mode’s runtime went from 18 days to 50 days on a 3000 mAh cell. And standby time went from 14 years to 977 years. Not that the cell would last over a decade anyway.
