Never had a “flax handle”, but I like the feel of it. It’s got a nice texture, not slippery.
The edge isn’t too sharp right out of the box, so I had to give it a touch-up.
Anyone ever experience a handle like that? Do they hold up over time, or potentially flake/chip/crumble/etc.?
Okay, dumb question…
The sheath comes with a pair of small holes at the end (you can see the pix at the GB link above), and a “shoelace” threaded through it and held together with one of those plastic squeeze’n’slide clamp-thingies on it. The “lace” isn’t very long at all, so if the sheath is hung on your belt, it’s not as if you’d wrap it under and around your thigh like a gunfighter to hold down the sheath in-place. So what’s it for? As far as I can tell, it just, well, dangles.
Fasttech are on the ball lately, my C192 arrived in a record 9 days.
The blade length is 77mm and not the 80mm that FT stated. It came oily - that’s ok and gritty - not ok, it’ll need to be stripped to get all the grinding dust out from washers.
It has a strong slip joint which makes it difficult to open one handed - it certainly cannot be flicked open. No blade play and shaving sharp.
Overall for $12.86 I’m very pleased - especially as it’s UK legal
76.2mm or 3 inches - but is that blade length or the length of the cutting edge which in the case of the C192 is 68mm? Actually, I don’t think anyone knows for sure - even the UK gov website is vague on the issue:
It’s illegal to:
sell a knife to anyone under 18, unless it has a folding blade 3 inches long (7.62 cm) or less
carry a knife in public without good reason, unless it has a folding blade with a cutting edge 3 inches long or less
It actually has a soft “clothy” feel to it. About the only thing I can think of would be those clipboards made of what seemed like compressed cardboard. Ie, it’s not just textured plastic, but actually has a softness to it. I was pleasantly surprised.
I notice the holes on quite many sheaths. No idea what to use it for. The fact that the included lace was so short really threw me.
I guess the blade steel of the Jin01 might be 9Cr18MoV or 8Cr… something. It’s still a great deal for $13 shipped. Atleast I like mine. (If I ordered a folder from the US the shipping alone would cost me more than $13.)
So what’s the conclusion of that test? (Native speakers correct me if I’m wrong pls.)
- The Jin01 costs only the fragment of that Viper.
- Their cutting performance is almost the same (as I understand).
The Jin01 is more rust resistant.
—-> The blade steel of the Jin01 can’t be D2. What a shame! What a bad knife! :person_facepalming:
Sure they are nice knives, even with a lesser steel. But I dont think I’ll ever put more than 30€ on a knife on Aliexpress because of this false steel tricks
Considering how great the edge retention is on my SRM 910+ and how sharp it can get you could try a knife with that Sandik steel 12C27.
The 910+ might be a bit big for you so you could try the flipper knife SRM 7076.
The SRM 7129 with thumb studs and rather cheesy looking dragon - but nicely full flat ground blade.
Or if you want a traditional swiss army knife style - but with a pocket clip - you could check out the SRM WA721-A1
The 910+ is my edc knife and I’m still amazed. I have to cut rawhide and EVA materials on job which usually dull a blade pretty quick.
The swiss army styles one has a hollow ground blade and comes very sharp, I’ve cut myself on the first day but the straight cut healed without a trace
I’d only wish the blade on the 910+ was ground a bit thinner, I guess you’d more like the other options.
