I love my Smini Sus…but please… Olight!!! when the Smini in aluminium?
Yes, this !
What I love from my S-mini : the size obviously, the UI (much faster and usable than the S1), the brightness
What I don’t like : The clip that is not adjustable, no magnet (but you can use the S1 tailcap), the lack of an alu version
From the S1 to the S-mini, they made a few changes that I consider upgrades:
- Smaller size.
- Clip stays in one place, doesn’t rotate and scratch the host.
- Clip “fingers” removed and hex shape of head converted to round, so things don’t stick out any more.
- Clip has a rounded lift point instead of square lift; less likely to catch on things.
- Lanyard hole added to clip.
I don’t really care either way about the magnet. It was useful sometimes, but I also had to take care to keep it away from magnet-sensitive materials, and it got the tail scratched up a lot faster.
It’d be nice to have an aluminum version, and would be nice if *all* versions were available in neutral white.
Would also be nice if they’d let me upgrade the firmware to give it battcheck (at minimum). Ideally also optional ramping, reversing, configurable number of levels, and some extra blinky modes.
This is a bit off topic but I’m looking for a little sympathy. And you folks seem like you’ll appreciate what I have, er… had, er… still have but…
I hate olight for glueing their lights!
I purchase an s30 ti sandblasted limited addition from eBay
It wouldn’t turn on.
I hate olight for gluing their lights!
I thought I could fix it.
I thought, hmm… titanium, that sounds indestructible.
Heat gun, leather strap, vice slip, scratched, more heat gun.
Titanium light in pieces, faded from the heat.
Did I mention, I hate olight for gluing their lights!
Driver test=working fine
Led test=working fine
What!
Ok, that’s pretty much my story. The scratch is small but bothers me. The color faded a bid from the heat though one might not notice without another one to compare. The kicker though, is that there wasn’t anything wrong with the light. I think it was simply a poor contact somewhere. Idk? So now I’m trying to decide what to do with it. sigh…
If the S30 is like the S10, isn’t the bezel a screw-in type? I have a S10 ti and IIRC the bezel unscrews relatively easily by pressing it against a sheet of rubber and twisting.
Or if it’s like the S1, it might be a press fit? I’ve been meaning to mod my copper S-mini with a neutral white emitter… already have the emitter somewhere around here, but I haven’t pulled the bezel off yet to do the mod. It should only need a disposable knife and some patient, gentle prying.
Just do it :sunglasses: . These light are so mich nicer with a good tint. The neutral that olight used was also crap. Replaced mine with a 5D and it’s just such a nice edc.
The S30 bezel is screwed, at least it is n the Alu version.
But Olight love treadlock, and use a ton of it (the red one) so you have to use brute force to unscrew it.
Rubber inner tube from a bicycle and a vise plier will get it but be gentle or the pliers will go through the rubber and scratch the surface
Anyone willing to change the emitter in my copper S-mini? If so, what would be the cost?
Where are you ?
NC, USA
I ould have done it if you were frome EU, but there are plenty of better modder than me on your side of the pond
I think I did my first led reflow on my S1 mini. It’s not as hard as you think. Just take your time. X3 has a nice video on it.
X3 and Geuzzz: Thanks!
I just watched your video, X3, and you make it look rather simple. I’ve never soldered before but I think I could do that. I feel like I’m about to open Pandora’s box and become a true BLFer. Just gotta find the courage and the time.
Given the price of thi little Olight gem, I wouldn’t do my first soldering on its tiny MCPCB with such intricate space…
Give it a try with a Convoy or chatever cheap light before.
It’s not complicated, but it’s like every technical tas, you ave to practice a little to have a steady hand…
(I’m currently learning TIG, it looks easy… but it’s not)
Sound advice. I’ll definitely practice on something else first.
I actually changed my reflow technic.
Now I just apply my soldering iron (maybe 40W) directly Under the MCPCB and let the older liufy;
Just grab the emmitter with your tweezers and put the new in place with the same polarity.
Good advivce on the practicing. I use the steel center of a gas stove for reflowing. Put the mcpcb on it and turn up the gas. Works well for me.
Would an XM-L2 EasyWhite work?
Nope, this is a 12V emitter, you need a ~3V emitter (standard XM-L2)
Olight is tempting me to cough up 50+ bucks for this S mini…
It’s another über cuty from Olight, like the H1, which isn’t cheap either.
Not really B (as in BLF).
Maybe i’ll stick with my i3S’s
