I donāt know about the LT Tool AA, but there are AA/14500 flashlights that have LVP, and when using Li-Ion batteries blink and/or turn OFF when voltage is lower than 2.8V.
It is Please take a look at the first post with the specs
The question that remains is really about protected or unprotected batteries! That and reverse polarity protection
Iāll probably stick the unprotected Sanyo UR14500P that I have.
It is curious: I was checking about the specs of some LT lights, including the Lumintop Prince Mini (AA/14500), about these āprotectionā aspects, and so far I couldnāt find any reference to themā¦
I believe the 18650 lights will probably have LVP and RPP, but these AA/14500ā¦I donāt know!
On high some protected cells will either trip there protection or provide less currentā¦ ?
IIRC on the Prince mini, the RPP is implemented as a raised ring around the positive contact on the driver. The cell raised top has to reach inside to make contact whereas the flat negative end wouldnāt. Flat top cell donāt work. I think i had to use some KeepPowers or a magnet. Iāll check tomorrow. Not sure how it will work on the Tool AA.
Edit: i checked my Prince mini and it has the raised ring around the positive contact on the driver. I use KP protected 14500 800mAh (black w silver label) which are BT but the raised bit is not even tall enough and i need to add a thin round magnet to get it working. Obviously those protected cells do work - when you help them a bit.
If it works the same on the Tool AA, be prepared to fumble a bit with whatever 14500 youāve got. Only āvery raised topā cells will work as is.
Thanks for the info patmurris! Didnāt know about that characteristic!! The Prince mini is a very nice light
Well, the only thing I can wait is that the Sanyo UR14500P fit well on the LT Tool AA, without magnets or other tricks. Those are the only Li-Ion cells I have for this lightā¦ :person_facepalming:
Suddenly I see myself surrounded by some AA/14500 lights, but somehow I am āexcitedā and curious to get the LT AA on my hands
The LED in the AA Tool is XP-L
If the AA Tool is anything like the AA Maratac, it will have PWM also. The Maratac offers a Nichia LED.
The ālowā mode of the AA Tool is 7 lumens, similar to the AA Maratac (made by Lumintop)
yes the AA Tool officially takes 14500, so does the AA ReyLight Pineapple (also made by Lumintop, and like the Maratac, offers a Nichia).
The Pineapple also has PWM. The Pineapple has a sublumen low that the Maratac and AA Tool lack.
NO the AA tool does not have Low Voltage Cutoffā¦ Like the Pineapple, the AA Tool calls for protected cells.
see
āthis flashlight need to use protected battery and there is no low voltage protectionā
My only question: is it that hard for Lumintop and Banggood (as the seller, in this case) to include that info in the specs sheet?!!! Why do we have to be digging for this kind of - IMPORTANT - information when it was supposed to be on the specs?
Also, is it that hard for LT to make these lights with LVP? Unless it was made only for alkaline batteries - which is not -, a flashlight like this, that can use Ni-MH and Li-Ion, should have (in my humble perspective) Low Voltage Protection and Reverse Polarity Protection. Mandatory! :person_facepalming:
It is annoying to know this, I must say! Iāll probably have to buy 14500 protected batteries to use it with full powerā¦
correct
be a good consumer, when you buy stuff, you have to accessorize and buy stuff for your stuff
buy protected cells for your inexpensive unprotected Tool
and or buy unprotected and take personal responsibility for monitoring battery level
and or buy lights with built in protection
and or buy Lithium primaries
and or buy Eneloops
and or buy Alkaleaks,
so you can buy new lights when they leak
If the light have no problems with the lenght, I have not problem in buy 14500 protected. 18650 are very common and realiable, but there are not a lot invested in create top quality 14500 (I think), for 14500 I always prefer protected batteries.
In any case, probably I will use my tool AA (when arrive) with NiMH P. Eneloop of fujitsu (the most reliable for NiMH) or with Primaly Lithium. For Li-Ion there are nice and compact EDC 18650 today
Itās not really compact, the same size as a T10.
Low mode should be lower, tint is really cold white, with hints of green around the spot and some purple hue in the outer spill (due to AR glass I would guess).
High mode on Eneloop is not impressive, lower than my T10.
On 14500 itās impressive, I think this one will run on li-ion
The clip is not sturdy (same quality than AAA tool), but is sturdy enough to stay on the light firmly.
Tailcap is good, the clicky switch is precise and gives a good feedback.
I will not use the magnetic tailcap, because I donāt like AA twisties.
It should find a place in my EDC rotation, after a Nichia swap
So, 14mm aluminum LED board, non DTP.
I donāt know what the SMD component is, but I guess itās just a shunt (0 ohm)
Anyway, much better now with the 219C 5000K
It seems very similar to the Pineapple Reylight driver. Seems to have a little ātopā to make contact with the battery, right?
Did you use 14500 with or without button top? Any ārattleā with the battery?
