ā¦ and a couple days ago I found a way to make moon mode run even longer ā like 3X to 4X as long.
Basically, underclocking the CPU and using an idle state while at the lowest modes. It doesnāt matter at most brightness levels, but on moon and a few levels above it, it really makes a huge difference.
I paid $3500 for the true original IBM PC, DOS 1.0, B&W monitor back in 81 or 82 - could not afford color. Having programmed both, I'd say the Attiny85 is far more advanced. Just fyi...
Received mine today with Air Parcel Register, Thailand post. Buyed on 7th September and shipped on 8th. Package was OK.
Out of the box, no signs of damage on the flashlight, itās perfect. Also, reflector is OK.
Leds: 2 out of centre, 2 perfects. Not so good but I think itās ok.
Threads are lubrificated but o-rings are completely dry.
There was some sandblast in the tube, especially in threads, cleaned all before lubrification.
Screws at PCB are a little stripped but no problem to unscrew them, they were not so tight.
PCB in the tailcap is well centered and the driver in the tube is dirty (black traces) but is flat.
Switch leds are ok, light is uniform but they are a bit misaligned. No problem. Now Iām burning them to test, hope they will not start flickering.
Thanks to all!
From what people are saying, it sounds like the issue is that a single short click must be less than 18 frames (0.288 seconds). If the click is too slow, it will be interpreted as a longer click or hold, and wonāt turn the light off.
The threshold here is a somewhat tricky one. Too short and people have difficulty getting it to register a short click. Too long and it makes the entire interface feel slow or cumbersome. And itās still subject to personal preference and dexterity.
The lights Iāve personally used vary from 0.288 seconds to 0.5 seconds in their short click threshold. Maybe even 0.6. I found the 0.5s ones to be a bit on the long side, and it sounds like 0.288 may be a bit on the short side. So on mine I went with a threshold of 24 frames (0.384 seconds). I donāt know if this is a good value, but Iāve found it pretty usable.
Received mine last night and everything looks great and functions perfectly. Button LEDās work great, narsil is fantastic, no damaged screws, threads are smooth, anodizing feels high quality, machining work is excellent. Unreal that this only cost $40!
Phew! Caught up on posts. One thing kept coming to mind while reading thoughā¦
I havenāt often marked posts as rude, even if theyāre obviously problematic. Maybe I should, but instead I typically use a different method ā if someone has a sustained or repeated habit of arguing, stirring up trouble, or escalating conflicts, I add them to my browserās stylesheet override. It makes their text small and dim and makes the header bar red instead of blue. Then when reading, I typically skip those red posts since theyāre unlikely to be interesting or productive.
Iāve only got a handful of people on that list, but selectively turning down the volume really helps make some threads more tolerable. And itās a good reminder that, most of the time, the most appropriate response to inflammatory posts is to ignore them.
Itās generally not that thereās anything particularly rude about any given post. Itās more like when a few people drive aggressively in dense traffic in order to gain a small relative advantage. Some of those maneuvers are things anyone would probably need to do from time to timeā¦ but doing it a lot creates waves which travel outward through the rest of the traffic, and those waves tend to cause collisions or other problems. It only takes a few overly-aggressive drivers to make the entire road come to a complete stop.
The idea is not just to consider oneās individual actions and circumstances, but to consider the larger effect it has on everyone nearby. Donāt be an aggressive driver on the internet.
Yeah, Iāve had it too and thatās probably it. It does not help that the natural reflex when the light wonāt turn off is to click again with more pressure and less speed. The correct solution is the opposite: a lighter, faster click. Once you know about it, itās fine.
It seems pretty similar to an old Intel 8086 CPU from the late 1970s, only with less space and more bonus features like the watchdog timer, ADC, and automatic PWM. The raw computational power is relatively low, and the storage space is even lower, but it has nice facilities for embedded purposes.
The PC I bought had 16KB external memory, so double the Attiny85 has built in. The 8086 was a full 16 bit processor, while the 8088 in the PC was a half breed - 8 bit bus, 16 bit addressing, If I recall correctly, and a clock rate of 4.77 Mhz. 8 Mhz was a big upgrade at the time. Yea, so I'd correlate the Attiny85 to that time period, but of course back then it took a large PCB board to have all the features built into the ATTiny85. I worked on projects using the 8086, 2-86, and also the Z-80, 8085, and assorted other micro-controllers.
But again where these small micro-controllers have evolved has been in the area of integration, integrating many of the peripherals on to one silicon wafer, where in the past, RAM, ROM/FLASH, interrupt controllers, timers/counters, etc. were all separate, and of course the interfaces were in general slower.
Ahhaā¦ā¦now i know why u misunderstood my statement. I posted a joke right after u reported your Q8 problem with photos. That was not my intention I did not quote you. No offence. But after thoroughly looking at your photo your Q8 is quite rough. Was your order same batch as those earlier problematic Q8??
Iām still waiting for mine don know what to expect :person_facepalming:
