Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
Did you use a screwdriver or a driver with replaceable bits? Try a brand new bit which has sharp edges.
You can also try adding a rubber band to get extra grip. Apply heavy downward pressure and twist.
Can it be gripped by vice grips?
You may need to use a dremel or similar tool to cut a slot in the head, then use a flat blade screwdriver.
As in http://www.q8.com ?
My Post office guy told me to use the physical address and put the PO number as a suite/apartment #. I would check with your post office first :wink:
I tried both with no success. Both were new. Screwdriver tip broke when trying.
I don’t have vice grips like that, but will try to find them if I have to.
Will try dremel tomorrow, i give up today.
It’s dark now and I want to see the light :slight_smile:
Added to list in OP, check modding topic, there are several things to try
Starting here
I would sacrifice an old bit and attach it with JBweld to have a nice grip.
Please elaborate a bit on “that button LED thing”? Maybe a pic?
I see in the OP it mentions that lube may be required. Can anyone recommend lube suitable for the Q8’s threads, especially products available in Australia? Thanks.
Try applying the tip of a very hot soldering iron to the screw head for about one and a have minutes and then use the Miller’s rubber band technique.
They could have put glue on the threads.
stephenk, I can’t help with Aussie products, but I use a DOW silicone grease that works fine, I think it was The Miller who suggested SuperLube. It’s not the Space Shuttle where it can’t be done wrong or else.
My 3rd and final Q8 (gift for my son) arrived yesterday. After a quick strip-down, clean, lube & reassembly I can report that everything is perfect except for the switch LED's, it has the uneven brightness "problem". I have a feeling he'll want them changing to either blue or white like I'll be doing mine so a non-issue really.
On a side note, I gave my daughter's BF my 2nd Q8, 4 button-top 30q's & a Lii-500 earlier today for his birthday and he was chuffed to bits, he's really impressed.
It really does make for a fantastic gift, many thanks again for all involved in making this concept a reality!
:THUMBS-UP:
I don’t know that this is available in Australia Sil-Glyde , but you can find it in any auto parts store, here in the US. I read a flashlight article a few years ago, where this was mentioned. I just happened to have some in my toolbox. I haven’t used anything since.
Try a local Ford dealer parts department. This XG-12 electrical grease is supposedly Nyogel 760G repackaged for Ford. 3oz tube was $15 dollars at my local dealer.
I ordered my Q8 on the 12th. According to the numbers a few pages back, I think it should have been in the “third” set of 500 lights. I just checked my account, and it’s marked as shipped, but the note says “Shipment information sent to FedEx”. So, I dunno. That’s kinda weird. Maybe they’re just pre-printing all the labels?
UPDATE: since i received my other two Q8s (second pair came day after the first pair, but got my hands on it only from Monday)
Out of 4:
First came non-lubed, uneven beacon LEDs, beacon LEDs stopped working next morning, has switch contact issue rarely
Second came well lubed, even beacon LEDs, beacon LEDs do work, has very ofter switch contact issue
Third came OK lubed, uneven beacon LEDs, beacon LEDs do work, no switch contact issues yet after 3 days
Fourth came non-lubed, even beacon LEDs, beacon LEDs do work, no switch contact issues yet after 3 days
switch contact issue video (FLASH) → http://tinypic.com/r/2rpqid5/9 you can hear clicks but it won’t turn off at random positions of flashlight
Two assembly lines?
Maybe more. I’d love to get a shop tour and see the lights in action being built.
Anyway, my two are being shipped and I’m really excited about it.
Mr.Poppy: according to previous posts about the light not turning off with a single click, it seems it is a matter of timing: the click must be very short - 1/4s. Can you check if a faster/lighter click makes a difference on those two lights?
That is an interesting find RobertB, How did you find out that XG-12 = Nyogel 760g?
It tried looking up the MSDS for XG-12 but doesn’t appear to disclose what is it,
Here is the MSDS of XG-12
https://www.fcsdchemicalsandlubricants.com/main/msds/us184665us.pdf
The only reference to it being Nyogel comes from this thread
as you may see it’s a matter of angle, at some angles it just won’t turn off… and when i rotate the angle just a bit it will turn off, and turn on
This won’t happen on the last 2 flashlights that i got, so I’m sure it’s not timing
Should my light be shipped? My order was #700-some but im yet to get an email about being shipped.
They happily took my money tho :-))
BangGood says mine has shipped! :slight_smile:
Out of curiosity, has anyone tried 4.35V laptop pulls with these? probably not gonna supply enough current, but…
