1807?
That is sweet and a bit tricky at the same time.
I really like that BLF as a whole did order as much as were spoken for despite we know people have left BLF.
I remember it was pulling with reserve lists to get to the amount needed on other projects, so this is nice.
Of course a 99ā99.9 order rate would have been ideal, leaving more with a profit in it for Thorfire and Banggood. Making ~104% a bit tricky.
But well all in all very happy, also for the trust, when issues became clear people stocked to their pre order, very kind and nice.
I donāt see a pause after moonlight mode when turning on the light with a press & hold. For me it seems that it immediately starts ramping up and I need to ramp down to have the lowest output.
Is the pause duration at moonlight of the D4 the same as the Q8 ?
The moonlight is easy to catch with the D4 while I always miss it with the Q8.
I just found this Ford XG-12 / Nylogel on US Amazon, a couple of options: Amazon.com Around $16 from the Amazon mothership (not too many left) and $14 from an alternate seller. Saved me a trip to a car dealer.
As I know itās only a pause for easy catching, you canāt really see it on long distances.
But when you hold the hand a few centimeters in front of the lens, then itās noticeable.
I estimate the pause is 500msec ālongā
If you ramp down to moonlight with the hand close you can see also the same small flicker as in turbo, indicating end of the ramp.
First of all, I am very glad that you liked the comparative, thank you all for commenting.
Yes, devastates the S70, it is true that the S70 throws something more, but the Q8 gives quite more light, and the flood is impressive, in addition the tint is very nice, the combination of launch and flood of the Q8 along with the tint it has Itās love at first sight.
How good to read that, I am from Galicia, a region similar to Asturias, both very beautiful. I wish I could visit your city, Iām sure is very pretty, too.
I bet you do not need more range or flood than the Q8 can offer you. But of course, we always want more of everything XD
I was skeptical about Q8, I thought I would not be surprised. But I was wrong, I was surprised, and much, it creates a great blanket of light, and throws quite a lot too, and letās not talk about UI, etc, and all for only $ 40, a must have.
My flashlights are standard, without modification.
Mine shows shipped, but it canāt be found on 17 Track, so I am sure it has not actually moved yet. - Not complaining, just wanted to let others know that even though we have a shipping notice, it has not actually left the building yet.
For those of you in the USA that do want to check Tracking of you Q8, but DO NOT know howā¦ here is the proper procedure.
This procedure is only valid for USA orders that were shipped Priority Air Mail. The FREE Shipping option for this light.
1. Get the Tracking Number of your order either from your Banggood Account or the Shipped email they will send you.
2. Go here https://www.fedex.com/apps/fedextrack/ and enter the Tracking Number from step 1. Click Track. At this point it will probably say LABEL CREATED.
3. Scroll down to SHIPMENT FACTS & get the Reference. This number will most likely begin with YT
Once the package actually ships, movement will show in the tracking information on 17Track.
Do not be alarmed if your package sites in one place for 1 to 3 or 4 days, this just happens sometimes. It is just the way it is. Nothing to worry about.
DO NOT worry about what it says on the FEDEX Tracking. It will not show there until Fed Ex actually has the package, if then even.
17Track has been very reliable for these packages sent to the USAā¦ all of mine have been 100%. More accurate then FedEx tracking by far.
While writing this I checked my last 2 Pre-Ordersā¦. both above #1680ā¦ AND much to my surprise & shock they both actually show movement. It appears they have actually shipped, as in āleft the building shippedāā¦ā¦ ā¦
Will know for sure in a couple of day though.
So there it is if anyone likes to see where their package may beā¦ā¦
Enjoy.
I did a factory reset and now both D4 and Q8 are fonctionning the same way with a click & hold from OFF.
Before the factory reset, when I was doing a click & hold at the same time on both flashlights, the D4 was turning ON on moonlight almost instantly and after the āmoonlight + pauseā it was ramping up. The Q8 was turning ON after a longer delay directly to ramp up without āmoonlight + pauseā.
I probably disabled the moonlight (but there is no way to do it in the manual) so I probably set it to the lowest level by mistake. It seems that the emitters werenāt even emitting light at this lowest moonlight.
I'd be interested if anyone shows so called "conductive" grease actually improving their case connection. Any low viscosity grease should be fine and conductive greases are not standard for such applications in my experience.
