How does everyone track? I tracked at Fedex.com and I get a generic āinformation receivedā for a few days now.
Assuming it has left their facility, I feel comfortable expecting them in two weeksā¦
I think the answer to that is probably āspaceā. Thatās a big component. What would you do with all those switches in there anyway? There is a tailswitch board with a single switch on it though, designed to allow you to turn the taillight off. It mounts inside the spring.
Even if you found a micro sized dip switch, you would still need to run several tiny wires from the driver near the head, to the tail cap. Then how would you be able to twist the cap and keep the wires connected? There is no way. Thatās why you donāt see them in tail caps.
Soon flashlights will need to have a locking key like some lasers
This way you can go from 0 to some lumens, then turn the key and unlock insane mode.
When ramping mine up its like when i reach the top there are 1 ālargerā and a smaller flash of the beam, dunno what it is but it dont bother me that much, just saying.
I got a shipping notice from Banggood! Ordered on 9/9. Tracking number doesnāt show up in 17Track.net at first, but then if I click the FedEx link it does come up. BG order says itās āPriority Air Mailā with an ETA of 10/22 (How is that āpriorty air mailā? Though I expect it will deliver sooner.) Weāll see if I win the Chinese lottery in regards to all of these reported issues.
I thought about that, and it's true a little, unless you had a UI lockout for 1 second after entering mode-lockin. Personally I think any system that changes its UI on its own at time where the user might be expected to provide input, should always lockout input long enough for the user to react or be sure that the change has occurred. A great example is the android screen rotation. I'm continually frustrated by pressing the wrong thing, right after the screen inadvertantly rotates. With a 1.5 second or whatever timer on the lcokin, there's going to be an edge where the user has a second thought, thinks "I can still click up one more mode", but misses it and clicks off by accident instead. If you have a 1 second UI lockout that won't happen, and also by the time that is over the user will be very sure that he's in mode-lockin now and will know he'll need to click twice to bump up. To fix the final race, you'd need the single-click lockout to last just a touch longer than the double-click lockout, to avoid a double click where the first one is during the lockout and the second one registers.
I also don't find the double click that confusing with regular clicks, since it does the same thing, it's just that the first one gets ignored when in lock-in. And it's no more confused with mode advance clicks than the off click is. Mode advance doesn't exist at that point anyway as it stands.
Anyway, as for long click off, what bistro is supposed to (when e-switch works again, soon) is always be off when the switch is pressed. That's has its own ups and downs (and is easy to change) but one up is that even long press off, turns the light off instantly. The wait is for locking it off. So you still have to spend your time to turn it off, but you do get instant turn off.
Number: RG61XXXXX61CN
Package status: In transit
Destination country: Malaysia
Origin country: China
2017-09-30 20:13 Bulk acceptance packet processing center in Guangzhou, has received send
I went for a 2 hour hike in dense forest with a friend and a Q8 last night. My friend was very impressed with the ramping UI, and got the hang of it right away.
The Q8 is nicely balanced. I hold it at waist level with my thumb near the switch, forefinger near the tripod hole, and my other three fingers around the battery tube.
The beam is perfect for seeing down the trail and has just the right amount of spill to light the sides, too.
The four 30Q cells were at 3.8V after 2 hours of low and mid modes, and a good amount of turbo in open areas.
For those who are waiting for their Q8s, stay strong. Itās worth the wait! :partying_face:
Hank, you might be over-thinking this. It would not be usual to use a āconductiveā grease simply to ensure good electrical contact in this sort of application (not bolting together heavy electrical switchgear, where metal-loaded pastes might be appropriate, but only when skilfully applied).
What is normal is a ādielectric greaseā. The contact surfaces readily displace it, the grease then keeps out air and other gases that might corrode the contact interface.
Use of true ādielectric greaseā, usually with a pure silicone base, is important when preparing e.g. high power RF connections, high integrity crimp connections, automotive connectors etc. or even just packing outdoor satellite TV connectors for long-term reliability. In high power RF. or high voltage applications, specialist dielectric grease is essential, the dielectric properties being much better than air it prevents arcing or corona discharge, and continues to do this reliably, being stable under most environmental conditions.
Superlube, Nyogel, etc. are fine here. They are not a true ādielectric greaseā, being synthetic hydrocarbon based, but I think they are perfectly appropriate here.
Edit: Compatibility with O-rings is important for us, this is where e.g. plain mineral based greases, or even Vaseline, may be problematic, and silicone based greases to, if silicone O-rings are suspected, rather than e.g. ordinary nitrile onesā¦
Nice story goshdogit, I made an aluminum short post with a taper head SS screw to go in the tripod mount for my M6, it indexes the light and lets me know, blind, where the switch is. Also makes it super easy to hold as it simply canāt slip out of your hand with the finger hooked around the short post.
I have two Solarforce lights that came with a standoff for mounting on the tripod, using them on the lights for the same indexing purpose as my M6ā¦
You can see that the Solarforce piece has a hole through it sideways for using a small screwdriver or Allen wrench to torque it down.
Why are people acting like they have never ordered something online? I suppose it could be true for some people, but lord have mercy! And I doubt that people care much to read about the fact that Joe Schmoeās light moved from the back of the warehouse to the frontā¦ bfd.
korpzgrinda, did you not notice how many people signed up at BLF just to get in on this group buy? A LOT! For the vast majority of those new folks it really is a BFD!
You are right, I can truly understand the excitement. Itās just these posts that are basically copy/pasting their tracking infoā¦ it feels like spam at this point. I would much rather see posts that show the lights actually arrived. Not trying to rain on anyoneās parade, though!
