Agro, one can probably find somebody who love a feature and somebody who hates it. It is all personal and there is a Dutch saying that translates to “there is no point in arguing over personal tastes” and that is the same here.
I don’t think it is intuitive and using several different flashlights the long press for off (or IMHO even worse on) is something to remember.
Were I only using 1 flashlight it would not matter at all.
It is just odd that light A uses long press for off, others for strobe and now the Q8 for ramp. I prefer it for ramp, one sees right away what is happening, and release to keep it on a level close to where it started, click hold to return to it So the long press of Narsil does not clash with other long presses.
One of the reasons the MF01 feels cumbersome is that I went to low mode instead of turning it off so many times, it just annoys the heck out of me.
But you see, lots of “I” and “me” in this, it is cool if you love it!
It’s not my favorite, but after I got a few lights that did it that way, I got used to it. It does have some advantages, such as switching modes is fast & easy with a single click. But turning off the light with a long click isn’t intuitive or obvious, especially for a non-flashaholic.
If you go the other way (short click off, and long-click to change modes), then changing modes isn’t obvious for non-flashaholics.
It seems like Narsil is attempting a kind of hybrid solution for the modes interface. I’m not sure that’s very intuitive, either.
I don’t know what the “best” interface is, unless we’re talking about a single-mode light.
bistro-HD ready for trialing on Q8 (Update, present version works for TA SRK board, will update when I have Q8 circuit information)
Symmetry is not a reason I care about in the slightest. Personally I actually just don't like single-function eswitches, and this is why. You can long-press-off a click switch with a short action. Or you can short press a click-switch with a short action. The switch itself is just more functional, and now with OTSM caps, it's capable of about anything an e-switch is too. For me, I want to be able to bump the modes up. I almost never reverse down anyway.
Anyway, for anyone interested, I just re-worked/tested the eswitch build in bistro-HD. No lockout yet. That's next. It might take a little fiddling to coax into HD, but I have a plan to try. It should I think work on the Q8 as is now, unless there are some pins on the Q8 that do something I don't know. It's setup for a standard tripple-channel TA e-switch board. The right build to use is the bistro-eswitch-TA-HD.hex Not yet tried in a real light, so experimental, but it bench tests fine. You want the 1.5 build for now.
I got my shipping notice on the 29th for both my lights. Anybody on the East Coast US with a shipping timeline report? Has “2 weeks” been the average like most BG stuff? All my new batteries are here and are lonely.
Yes there seems to be about two weeks between email it is shipped and delivery.
But with the holidays now it is not clear at all, just think “it comes when it comes”
So you believe it is just a solder issue? You reused the same parts? Did this pcb have the brighter led on one side, or was it just the flakey led.
Just curious of your final thoughts.
Sorry, earlier post had more details. Yes - reused same exact parts. Didn't track the LED to the side, but this board always had one brighter than the other. It's pretty well known at this point that LED to LED variations will result in uneven brightness with them wired in parallel like this. You need one resistor per LED to get more even results.
As far as root cause, I cant say for certain -- may be some issue on the PCB that was dependent on the reflow/solder work, or could have been some contaminant that was somewhat conductive under low heat or movement, etc., or might be the quality of the reflow. Dunno for sure the exact cause, but I'd say it wasn't the parts and don't think it was the wiring or driver side, so in this area of the switch PCB and solder.
I just touched the tip of my iron the both ends of both LEDs and behold: there was light again! 30 minutes later, no more light. Really weird. The voltage across the LEDs is also lower now than before the fix.
Edit: Took some measurements. When the LEDs work, Vf is 2.23V. 30 minutes later, it is back down to 1.5-1.6V and there is no more light. It’s like there’s a bridge which slowly rebuilds itself while the LEDs are on. I’m leaning towards “faulty” LEDs.
