LED drivers and Accessories you want, but don’t exist
498 posts / 0 new
Schoki
Schoki's picture
Last seen: 2 hours 14 min ago
Buck should be possible to find, but buck-boost will be tricky…
Texas_Ace
Texas_Ace's picture
Last seen: 8 hours 51 min ago
Jensen567 wrote:
MPQ8633B would be the Buck IC with similar specs, I have info on that one too. No high power Boost-Buck that I am aware of yet, but the MP28164 is a 4.2A Boost-Buck chip.
Not affiliated with MPS in any way, i just found their catalog and thought they make some nice chips for flashlight drivers.
Both of those are interesting options. The MPQ8633B looks real good but it is hard to tell from the cover sheet, is the output voltage limited to 5.5v? Or is that just the reference voltage?
The MP28164 looks like it would make a great general use driver for small lights as you don’t need more then 4A anyways in most cases. I also like how few external components it needs.
Schoki
Schoki's picture
Vout max on the MPQ8633B is 0.9 of the input, or 5.5V depending on the input voltage.
Texas_Ace
Texas_Ace's picture
Yeah, thats how I read it as well. Sad it would not work for higher voltage LED’s, if it supported outputs up to 16V like the input it would be great.
Jensen567
Last seen: 1 year 3 months ago
The output voltage is limited to 5.5V, good catch, I didn’t see that. In that case, the MPQ8632-20 Is probably the better candidate, up to 13V output and similar in other specs. Little bit larger footprint though. The MPQ8632-12 has the same size footprint as MPQ8633B but a 12A limit (still probably enough).
Texas_Ace
Texas_Ace's picture
Hmm, 13V is not quite enough for a 12V LED at reasonable currents but at least it would handle 6V LED’s.
Who knows maybe they have some wiggle room in the voltage tolerance and could handle ~14-14.5v, kinda like how we push everything else past the datasheets as well lol.
Jensen567
There are certainly plenty of high powered Boost-Buck controllers out there, but many require 4 external MOSFETs which makes space a problem. Using some super small surface mount FETs it might be possible to build something in the 30mm range. LTC3780 comes to mind here.
I’m willing to bet the MP8632 would output beyond 13V by a bit, similar to how the TPS61088 will actually max out around 13.7V instead of 12.5 like the datasheet says. We do tend to operate a lot of things outside of specs here. Haha.
Texas_Ace
Texas_Ace's picture
Yeah, those FET’s really eat up the space which would already be tight without them. Thats what makes these chips so attractive. Plus the lack of FET’s reduces the complexity which is always good for small designs.
Schoki
Schoki's picture
Maybe I can get an ATTiny13A on the MP3431 board, for biscotti-HD. To control the IC I would use the method used in the H2-C.
Agro
Agro's picture
Last seen: 42 sec ago
How about ATTiny85 for e-switch?
Though either would be lovely…
Schoki
Schoki's picture
The 85 isn’t available in a package small enough to fit the underside of the board, I need 3×3mm, even 4×4mm is too big.
Lexel
Lexel's picture
Last seen: 1 week 23 hours ago
Schoki wrote:
First try on a 1-mode Buck-Boost converter for 2-3AA or 1 LiIon cell: It uses a TPS63020. You have to calculate max current yourself (see page 13 in the datasheet), but it can do more than 800mA, even worst case. The current can be programmed via one resistor. There’s a jumper as well to choose between normal mode and low current high efficiency mode (see figures 10 and 11 in the datasheet).
Which parts list for this one
I need it fot 1.4A UV LED with 4.1V forward voltage in 17mm
Agro
Agro's picture
OK, I thought you meant the usual SOIC-8. Anyway, there are many great uses. Thumbs Up Smile
Though I think there are uses for 20+ mm variants with e-switch too. Smile
Schoki
Schoki's picture
Forgot that, the inductor is 1.5uH.
But I haven’t tested the circuit myself, so I just can hope it works. I will check the pinout one more time. I can recommend some Opamps, but I need the input voltage range for that. To get 1.4A, your resistor R3 should be as close to 5932.2 Ω as possible. Less resistance for less current, more resistance for more current.
Scientist
Scientist's picture
Last seen: 9 hours 4 min ago
I too would like to build a UV light. Looking for a boost driver for 2×26650 to get 15V 1A to LED. Doesn’t need anything except on/off.
Lexel
Lexel's picture
Schoki wrote:
Forgot that, the inductor is 1.5uH. But I haven’t tested the circuit myself, so I just can hope it works. I will check the pinout one more time. I can recommend some Opamps, but I need the input voltage range for that. To get 1.4A, your resistor R3 should be as close to 5932.2 Ω as possible. Less resistance for less current, more resistance for more current.
Input is a single cell 3.7V
this 20Mhz one OK?
http://www.mouser.de/ProductDetail/Texas-Instruments/OPA322AQDBVRQ1/?qs=...
Schoki
Schoki's picture
Yes this OpAmp will do it. Due to the 2mV maximum offset the current could be between 1.3-1.5A.
L4M4
L4M4's picture
Last seen: 1 month 5 days ago
If you only want on/off you can just use one of those buck converters from AliExpress.
I use one too for my 3*26650 light with a 100W COB in front.
Lexel
Lexel's picture
Schoki
Schoki's picture
Take the OPA365, the microchip parts seem to have a really high input offset drift when the supply voltage changes.
Lexel
Lexel's picture
could you share that board?
Schoki
Schoki's picture
eh4
eh4's picture
Last seen: 2 years 11 months ago
Kinda crying out in the wilderness here, but I need a high discharge FET drive that will allow these five conditions simultaneously;
- always on momentary signaling switch,
-adjustable frequency and duty cycle strobe only,
-momentary only,
- adjustable thermal step down,
- ability to lock out programmability with closed solder junction.
The brighter the light, the darker the shadow.
Jensen567
Sounds more like you need custom firmware instead of custom hardware. Any of the BLF FET drivers should support that hardware wise.
Jassim
Jassim's picture
Last seen: 3 weeks 4 days ago
Can you Recommend a 17mm Driver (single cell) for xhp35 ?
Schoki
Schoki's picture
I currently try to make one. PCB is nearly finished, but I need to find an ATTiny25v rev. E in qfn package. I maybe will order from different shops, maybe some have the revision E.
Jassim
Jassim's picture
The attiny25V is good for low voltage Applications, I found this on Aliexpress https://www.aliexpress.com/item/ATTINY25V-10SU-SOP8-ATTINY25V-10-SOP-ATTINY25V-SMD-2piece-lot-new-and-original/32793537074.html…
Attiny13 is good too and Much cheaper , the only Problem with it is the 1024 byte Flash.
eh4
eh4's picture
Thanks Jensen567, you are almost certainly right.
If I could make it simpler, cheaper, higher output with a custom driver that would be great, but custom firmware is the place to start for sure.
Lexel
Lexel's picture
I reflowed the driver, but it seems dead any test I can do?
when I turn it on a current of about 6mA flows
I tested all parts to have continuity to the other parts and it seems all right
I get 1.3V from ground to LED+
and 0.56V over the LED
read the TI datasheet is says that the power safe mode pin must not be open, it has 3 pads so I have to solder bridge one?
Anthon
Last seen: 12 hours 38 min ago
H1-A and H2-C in 17mm
