Vacation… Well then…. have fun Neven!
Should give me enough time to decide what I need (want ) next!
The price is indeed superb. If only the driver was supported by FSM firmware….
Does ILC-1 fit into E2L?
I don't have E2L, but I have Jaxman U1 and tailcap parts are identical to Convoy S2+, so ILC-1 fits (just tried). If E2L also has 18mm washer and 16mm PCB then it would fit.
Thanks. So I’m thinking about NOCTIGON 3XP MCPCB & Nichia NVSW219CT R8000 D260 + LD-A4 + ILC-1 + E2L.
What do you think? Will it be good match? What amp version should I choose? 6A for 3 LEDs = ~600lm per LED. 12A for 3 LEDs = ~1000lm per LED (I’d prefer 12A because I could configure it at 8A and it seems to be ideal). Is LD-A4 enough or should I consider B-version?
For triples and quads LD-B4 + MOSLED pcb is better because build is easier, with LD-A4 you have to take care of thermal path.
Built my first light using the single-emitter MOSLED board. I put an XP-L HI in my Convoy L2. I know they come with that, but I bought mine as an empty host and built it up using a big XHP emitter, and I never really loved it. Now its living in its single-cell form like it should be, in my opinion
FWIW, in case anyone is wondering, the ILC tailcap module works in this host too. Its smaller than the space so you have to be careful to center it properly, plus its too short for the retaining ring to fully tighten down without using a spacer. I have some brass rings that are intended to adapt drivers and such, I’m sure most of you have seen those, so I stacked one on the back of the ILC module and used an extra-long spring so it’ll make good contact with the cell. I’m sure this spring would be terrible for current but a bypass takes care of that. I’m very happy with the results.
I read but something its not clear to me:
The ILC-1 illuminated tailcap turns off when the flashlight its on? In other words, the leds in the tailcap works when the flashlight its on or not?
That is correct, when flashlight is on tailcap switch basically a piece of wire so illuminated taicap can't work. When flashlight is off switch is open, driver can bypass battery + to flashlight tube and illuminated tailcap can work.
Thanks for the aclaration
light modification of modes is possible ?
for example,
M O D E GROUPS SUB-MENU
1 CANCEL
2 100%
3 35%
4 16% - 100%
5 2,5% - +_35_+ - 100
6 2% - 10% - +_40_+ - 100
7 1,5% - 7% - 18% - 35% - 100%
PM sent.
New product: ILC-0
https://led4power.com/product/ilc-0-illuminated-tailcap-switch-module/
Basically, it is a low cost simplified version of ILC-1, but also fits in any flashlight with 16-17mm switch PCB diameter.
White reflective PCB and switch greatly improve light output and uniformity in this kind of setup.
LVP shutdown is identical to ILC-1, CC part is not as precise or simple to set as in ILC-1(and CC in ILC-1 is very precise - overkill for tailcap anyway), but end result is pretty much identical.
Nice product! I really enjoy my lighted tailcaps and suppose that I’m not alone in that, but I know that soldering all those tiny components is not for everyone. This is a great solution that avoids all soldering!
Btw, great price for such a nice custom build part.
One day I’ll have a set of l4p-powered S2+s
My order arrived fast and perfectly seall. Very good customer attention. This is by far the best flashlights drivers in 17mm and more important with a lot of unique features and PWM LESS.
Btw this new ones iluminated tailcaps ILC-0 , looks very nice and at good price :+1:
I received an order today, packaging was good and shipping was relatively fast (less than 2 weeks to Italy).
I have a question about driver behaviour when using illuminated tailcap: if the driver shuts down while the switch is keeping the circuit closed because of lvp, will the drain be limited to the driver standby drain or will it pull the 1mA bleeding current too?
When driver is ON (tailcap switch is ON)and shuts down because of LVP (2.8V),it would drain ~1mA because of bleeding.Of course it would be not a good idea to leave driver/switch turned on when this happens, but since LD-x4 is clicky driver,turning flashlight/driver off after LVP is intuitive/normal thing to do.
Also this is the case where ILC-0/ILC-1 LVP shutdown becomes very important: ILC-0/ILC-1 has ~3.0V LVP shutdown level,below this voltage it draws ~1uA of current, so battery is safe from over-discharge.
Without LVP,illuminated tailcap would constantly draw current below safe level (especially red,orange,green) which would lead to destruction of battery.
Thanks for the quick answer. I agree it isn’t really a problem, this was mostly a curiosity I had. Also the LVP feature of your tailcap is great indeed, I think I’m going to order a couple of ILC-0s in the near future.
This is great! Beautiful product. Any concerns with high current through that switch? Should it perform as well as the reliable Omten in high powered lights?
