Walkie Talkie for children?
Since BLF seems to have an answer to everything, I’ll just throw this out there:
I am looking for a set of walkie talkies that is suitable for a 5-year old child, not too expensive, for use in the UK.
Any suggestions? Specific properties or features that I should look out for? Do I need to be careful about country-specific regulations?
EDIT: I’d like to get some real two-way radios with a fairly decent range, not the toy ones with Spiderman / Peppa Pig etc. design. Are these ones any good? I like that they’re rechargeable, which means not having to worry about a separate charger. But for obvious reasons I don’t trust random reviews on the internet.
+1
i got a retevis too but different model and i give it to my nephew so he and his friend can use it during school camping and i already set it to high power and he said it can reach more than 1km on open area
I want to get it for my nephew, too. 1km sounds like a decent range. A lot of them state 3km, but I doubt whether manufacturer’s claims are accurate in real-world situations (taking into account weather, terrain and so on). Shouldn’t be necessary anyway for just taking it outside to play, or on a camping trip.
Any PMR446 (Personal Mobile Radio 446) as these are European licence free two-way radio system. About 5km range in the open, legal and cheap.
https://www.amazon.co.uk/Motorola-Walkie-Talkie-Consumer-Radio-Blue/dp/B00KAQYJLU/ref=sr_1_11?s=electronics&ie=UTF8&qid=1507640655&sr=1-11&keywords=pmr446
How do I know whether a device is licensed for use in the UK? Could there be problems if I order from abroad, e.g. with specific carrier frequencies that are reserved for other uses such as emergency services?
EDIT: Just found the answer myself
I’m a licensed Amatuer radio operator in the US. The radio you linked to is a little short on power. .5W won’t get you much range. Although it is using UHF frequencies which is best used in buildings with walls or other barriers. The higher frequencies work better with barriers, trees, etc in between radios. The pmr radio the gentleman linked is built by Motarola which is a very trusted name in radio communications. Although it also has just .5W power, the reviews I read were good talking about kids had good results using them outside with decent range reached. If you could find a GMRS or FRS radio with more than .5W power I would give it a try. More power gets more range. And these type radios are open frequencies that do not require a license to operate on. Atleast in the US they don’t require a license. It looks like you found a source explaining the rules for the UK. Good luck. If you have any questions, I’ll be glad to help with any technical questions about radios.
As its Budget light forum, maybe look at two platic cups and a long length of string;-)
I got some Cobra ones that are good and easy to use but do eat batteries.
Got some Baofeng BF-888S they work well, seem to have a good range, says 5 watt but i doubt really its more than a couple at most.
But they were under £20 for a pair are rechargeable which is handy and they come with charging cradles and ear phones earphone/mike etc
It seems that is the maximum power permitted in the UK without a licence. Firedome is right - only PMR446 is allowed, with 8 bands at 446 MHz. FRS and GMRS radios with 14-22 bands can’t be used here. A radio licence is free, but somehow I doubt that they’d issue one to a 5 year old child.
I’ll be having a look at the Motorola set. Cobra also seems like a very good brand, so I’ll need to read some reviews before I can make up my mind.
Thanks! :slight_smile:
I was wondering about Baofeng - they seem to be everywhere, including eBay. Which kind of made me a bit suspicious, as I had to think of all those UltraFire batteries and ‘super bright Cree T6’ torches that are swamping the place. But maybe I should have a look at some of those as well. It’s for a child so doesn’t need to be high end, but I do want to get something that is safe to recharge, doesn’t break after a few uses, and still works if there are a few trees or a building between two handsets.
I recently bought a pair of these for my kids (and for me to stay in touch when they’re playing outside ;)): https://www.aliexpress.com/item/2Pcs-set-baofeng-BF-888S-Walkie-Talkie-Portable-Radio-BF888s-5W-16CH-UHF-400-470MHz-BF/32313659613.html
Works great and covers a lot of distance!
Baofeng is a decent budget radio. Many licensed HAMs use them as backups and some use them as their primary radios. They are reliable, easy to use and inexpensive. Many hardcore hams will trash them because they are cheap, but they actually are pretty reliable and easy to use/program. I have a few different Baofeng models and use them in my vehicle hooked up to a mounted antenna and get a decent 30 mile range out of 5W on VHF frequencies.
The EU law is quite clear. USA GMRS and FRS is not applicable.
You can have a PMR446 radio, with eight channels and subcodes beneath, 500 mW and fixed antenna to limit erp.
It must be type approved and marked PMR446 to be legal.
That said, plenty of us know how to program e.g. Baofengs etc, on the proper frequencies, at illegal powers, with good antennae, and get good use from them.
There are also a further 8 PMR446 channels assigned to digital use, which never caught on. Some use those too, analogue, to avoid congestion.
Then, in the UK only, there are three frequencies assigned to “UK business light” which are uncongested, allow higher powers and within range of typical re-programmed things. More frequencies also for e.g. re-programmed marine VHF or 2m/70cm band amateur radios. To be legal you have to buy the license (no test), for unlimited handsets throughout the UK, costs about £75 for 5 years.
If you move beyond the assigned 16 PMR bands (8 analogue, 8 digital), or the UK only “business light” ones, expect to be monitored and maybe even investigated.
Stick with legit. PMR446 radios, the non-toy ones are good, and have enough range for many purposes, especially children. They can be a lot of fun.
Otherwise “citizens band” 27 MHz transceivers are legal and license free across Europe, though frequency bands and modulation (AM, FM, SSB) may depend on country. More expensive, but in the right conditions can propagate across continents.
I hope you re-programmed them onto suitable frequencies. Out of the box they are usually coded with factory test channels which are AFAIK quite illegal, not even in amateur bands. Very decent otherwise.
You guys in the UK have too much government over reach on the airwaves. They want to restrict frequencies amd make you buy a permit without a test. Sounds like another way to generate revenue by restricting airwaves and making citizens pay to use them.
You have it utterly wrong. The UK “business light” license is really for business users (site security, taxis etc.) but nevertheless anyone can buy one, and operate on the assigned frequencies.
And I think the real rules are just as tight in the US.
You have your FRS and CB, as we have PMR446 and CB. EU is much more crowded and congested than USA. Try using a PMR446 at e.g. a crowded EU ski resort for example. We mostly don’t care, because mobile phone coverage is almost 100% in such areas, roaming charges between countries have been abolished, and it is almost free.
Edit, in UK e.g a pay as you go SIM can be had for 3p/minute for calls, 2p for texts, 1p/Mbyte data. I pay £18 for unlimited calls, unlimited texts, 30 GBytes/month data including tethering my laptop etc. Anywhere in Europe. In my case, also including Australia, Brazil, Hong Kong, Indonesia, Israel, Macau, New Zealand, Puerto Rico, Singapore, Sri Lanka, US Virgin Islands, USA.
Well, thanks for setting me straight.
That’s OK, but you did weigh in with disparaging comments about the kit we are allowed to use, then some unnecessary stuff.
It’s all cool, we have good stuff here too, and very liberal amateur radio licensing, just different. And can buy whatever we like, licensed or not.
100 km contacts on unmodified 1/2 watt PMR446s are fun, as is other stuff.
But we do also have almost blanket mobile coverage, cheap as chips, even my dog has one, GPS tracking collar.
Until you get into really “Big Country” which means Scottish Highlands for me. Where e.g. a stashed repeater on a suitable high point, can help a lot.
And others in the party can continue to use their ordinary over-the-counter legal PMR446s without worrying. 0.5, or 5 or 25 watts would make no difference in this terrain, except for draining batteries faster. But a high line-of-sight repeater, does. Especially with high gain Rx antenna, and several watts transmit power.
I didn’t intend to say anything disparaging or unnecessary. I was merely discussing how things were different for radio operators here and in the UK. Please tell me what I said that was unnecessary? I’m glad you have excellent mobile coverage there. I let go of any cellular device when I retired in 2010. I keep one in my vehicle for emergencies. Most people these days can’t survive without a cellular glued to their head all the time. I’m only speaking of people in the US though, not sure how people are with cell phones in the UK, plus I wouldn’t want to talk about how people over the pond act with their devices as that would be arrogant assuming and insulting and I don’t do that.
I don’t think things over your way are much different from here.
If you look into amateur radio licensing I think you will find it much the same.
We have “free” bands for unlicensed operation, same as you. Low power UHF stuff for short range, and the CB VHF band which has so much (mostly wasted) potential.
Then there are the amateur bands, massive bandwidth, recognised worldwide.
I think you will find that your government guards the rest of the bandwidth just as jealously as any other.
You guys in the UK have too much government over reach on the airwaves. They want to restrict frequencies amd make you buy a permit without a test. Sounds like another way to generate revenue by restricting airwaves and making citizens pay to use them.”
That’s what I disagreed with. The content, and the tone.
I thought we were talking about walky-talkies for kids here, not tuning higher powered Amateur 70cm transceivers into the same band. PMR446 is a good useful system. Maybe US equivalents are more powerful, but in Europe this is what we have, and it works OK.
The radio you linked to is a little short on power. .5W won’t get you much range. … If you could find a GMRS or FRS radio with more than .5W power I would give it a try. More power gets more range.”
1/2 watt is our limit for unlicensed personal radios. Imported GMRS or FRS radios are not legal here.
