I have some 80 CRI 3000k XP-L2 which aren’t too bad, lots of pink in the tint. But the 80 CRI 3000k XP-G3 looks fairly green. I’m sure there are good new generation Cree chips out there, but it seems a bit of a lottery right now.
The only amazing Cree I’ve seen so far is the 4800K XM-L2 EasyWhite (quad die) in the ZL H600Fd Mk3. Even if it is CRI 84 R9 19. The frosted lens makes wonders.
This is going off-topic, but I recommend shaving or de-doming the first generation high-cri XHP-50 and XHP-70s. It noticeably reduces the yellow corona and spot. The tint becomes much more even.
When will you find the time?
Yep, it helps a lot for the tint shift and even makes the tint better on some emitters but I haven’t been able to get the tint just perfect. The best one and the only one I would call neutral is a shaved 5000K XHP70 CRI90 in a K60. Beam.
Thanks for replies.
Yes, I know about R9 specifications, but I didn’t know, that Cree has so bad tints
Unfortunately, triples are too floody for me, so the E2L is off the menu.
Any chance of getting this LED into an M2?
That would probably be a unique light in the marketplace, because 5000K and 90 CRI in a cost-effective AA light are very hard to find. Zanflare might be thinking about one, but they’ve gone quiet lately, and the only other option I can think of would be a much more expensive Eagletac.
There are some:
Raylight Pineapple Brass 1xAA with Nichia 219C 4000K R9050
Zebralight SC64c with XP-L2 4000K 90CRI
The Zebra is not cheap though.
I have that same H600Fd III. It’s wonderful
maukka, do you have any measurements for the new LG leds in the Jaxman E2L? still deciding whether to get the warm white nichias or the neutral LGs in the Jaxman e2l but i wouldn’t decide until the numbers are out from maukka :nerd_face: .
Should get the LG today or tomorrow.
The real question is how will they act in direct drive
Curious to see the numbers as well
Almost sure they are far away from modern cree and nichias.
This is typical feature of LG and Samsung leds - they are very competitive at 350mA test current, but with current raise they look not so good. I suppose the reason is internal thermal resistance.
Thermal resistances:
LG H35F0: 2.5°C/W
Cree XP-L: 2.2°C/W
Cree XP-L2: 2.2°C/W
Cree XP-G3: 3°C/W
Nichia 219C: 4.2°C/W
Cree XM-L2: 2.5°C/W (but with much bigger footprint)
So they are all very similar in that regard. The XP-L2 tolerates a much higher maximum current though because of the flipchip design.
Brightness @ 3A (LG doesn’t state the temperature, I assume 25°C):
LG H35F0 4000K: 882lm
Cree XP-L2 U6 4000K: 1000lm
Nichia 219C D240 4000K: 800lm
Cree XP-G3 R3 4000K: 910lm
So the XP-L2 is indeed noticeably more efficient (13% more lumens, basically two Cree Bins). Even the XP-G3 is brighter.
The LG LED still has some benefits though:
- cheaper and easier to get compared to the XP-L2 90CRI (Mouser is very expensive for low quantities)
- larger Die size compared to Nichia 219C and XP-G3 => more useful Beam in some lights
Does anybody have the datasheet of the LG LED?
Thanks for the ideas :+1:
I must admit, I was very tempted by the Reylight, but the 4000K colour temperature put me off in the end.
I’ll be looking forward to seeing your data
I hadn’t even heard about this LED until I saw this thread!
BTW what about some Osram Oslon SSL LED with CRI=95, R9>90, R13>90?
Haven’t tried Oslon SSL, but I did test one Osram Oslon for Chouster some time ago. It is hideously green regardless of drive current.
Oslon Square 4000K CRI min: 90, CRI typ: 95, R9 typ: 90
GW CSSRM1.BM-MPMR-XX55-1
This is in a Thrunite TC12 V2 with an SMO reflector.
Still waiting for the LG.
There is no datasheet.
Maybe it’s unofficial or “confidential”.
@Maukka:
A guy I know has experimented with multiple Osslon LEDs and he thinks that the colortemperature makes a difference. His theory is that 4000K and above are greenish, but 3500K and below are not.
All my 3000K 90CRI Oslons from second and third generation have an underwhelming tint, ok but slightly at the green side of yellow. As opposed to Nichia’s that are at the rosy side of yellow.
I do have a girst gen. Square 3500K 80 CRI that has a great tint, also the first gen. SSL80 4000K 96 CRI is great.
I did the performance test on the LG led of the OP and will do a full post hopefully later this week.
A short summary on the current/output/voltage:
*the led died at 13A, which is exceptional for a led with bond wires, it was not even the bond wires that failed
*the maximum is at 8A (1733lm), pretty good for a 90 CRI led. The voltage is then 4.00V, so this led is pretty ideal for a direct drive single 18650 light.
*my ideal drive current would be 5A, at which current the led is at 3.54V and 80% of the maximum output (1400lm).
I looked at the tint for a brief moment at 50mA holding a small smooth reflector in front of the led, but I can not tell much about that yet, just that the hotspot seems to produce a ‘spiegelei’, which is pretty worrying for this led but it could be very well how I positioned the reflector in my hand.
