pkcell 14500. surprise! rated 750mah got 844@500ma
2nd cell shows the same numbers and as I am pretty shure all the other cells will do the same, I will not continue testing.
snakebite did the test @1A. IĀ“m sure my cells would just confirm his numbers.
It would be interesting to see some discharge diagrams in near future.
So far I recommend this cells.
i need to order more of both the 10440 and 14500.
they all left in restomodded vintage lights with friends.
Would be nice if HKJ tested these.
I guess for ā€˜high drainā€™ (but not too highā€¦) usage the Windyfires are still the best?
But for ā‚¬11.13 i can get 5 14500 PKcells with free shipping, which is nice. :slight_smile:
https://www.aliexpress.com/item/5PCS-ICR14500-14500-750mAh-3-7v-rechargeable-li-ion-Battery/32416099918.html
HKJ said that he had 14500 in the pipeline. But not 10440.
hi Box, what was the name of the ebay seller?
Hey mate.
https://www.ebay.com.au/itm/142272998192
Awesome, thanks. This looks like it could be good, they have NiMH batteries and all!
Theyā€™re in my AliExpress cartā€¦
:+1:
I got a few of the PKCell ICR18350, IMR18350 and ICR14500 batteries from AliExpress (fortunate to have ordered them last month, when they had free shipping via Turkey Post; just checked right now, and theyā€™re only offering expedited shipping options US$40+ Fedex ā€” seems like Turkey Post is not shipping batteries anymore).
What current should I charge them with? Standard charge current? Rapid charge current? There doesnā€™t seem to be a spec sheet. The sellerā€™s page in AliExpress only indicates max continuous discharge current (2C for the ICR type, and 10C for the IMR type). How about discharge current (when testing discharge capacity), is 1C too high or still OK (for the ICR types).
based on the seller item page description:
PKCell ICR14500 750mAh max continuous discharge current = 2C = 1.5A, cut-off voltage = 3.00v
PKCell ICR18350 900mAh max continuous discharge current = 2C = 1.8A, cut-off voltage = 3.00v
PKCell IMR18350 700mAh max continuous discharge current = 10C = 7A, cut-off voltage = 2.75v
So far I did discharging of the above batteries at 0.25A discharge current and also getting around 800-900mAh (the ICR18350 900mAh and IMR18350 700mAh seem to have similar capacity?)
Cheers
update on the PKcell 16340
a little over 700mAh and internal resistance around 120mR so itā€™s not high drain.
Jerommel, ā‰ˆ120mĪ©?
Fenix 16340 700mAh ARB-L16-700 (Orange-Black), top dog in capacity but ā‰ˆ190mĪ© of internal resistance. Those figures of yoursā€¦ to be believed. It would be great, of course.
Cheers ^:)
Originally posted on Tue, 10/10/2017 - 13:04; lil fixup. :-)
I calculated it here
keep in mind my ir testing was impedance at 1khz.
thats the most common method in most datasheets.
and testing at 3.5v is testing a discharged cell.
ir goes up as cell is discharged.
quote.
Okay, i calculated the internal resistance of one of my PKcells, i think i did it right.
The Voltage of the cell was 3.5 V without load.
I put on a load with a 1.35 Ī© resistor, giving a Voltage of 3.2 Volts over the resistor, I=U:R so the current was 3.2 V : 1.35 Ī© = 2.37 A
Now i can calculate the total resistance. R=U:I so R = 3.5 V : 2.37 A = 1.47 Ī©
Subtract the 1.35 Ī© from that, so 1.47 ā€“ 1.35 = 0.12 Ohm or 120mĪ©
When I (current) is 2.3 A (M3 turbo mode) P (power) wasted as heat in the battery is P=IĀ²Ć—R ā€”> IĀ² = 5.29 ā€”> 5.29 Ɨ 0.12 Ī© = 0.63 Watt heating up the battery, which is nothing to worry about i.m.o.
Anyway, with Ri=120mĪ© this is not a high drain cell at allā€¦
PS: The numbers could be off by 15% (or something) due to my equipment.
3.5 Volts is not discharged, 3.0 Volts is discharged.
But thanks for the point you make, i will test it again with a fully charged cell and one ā€˜half fullā€™ at 3.7 Volts.
I didnā€™t know it depends on the charge.
I wouldnā€™t know why i should test at 1kHz, and iā€™m not sure of you mean a PWM-ed load with 50% duty cycle at 1 kHz or what.
I was testing with a similar load as the turbo mode of a OTR M3 flashlight, which is a constant load of 2.3 Amperes.
3.5v open circuit is damn close to empty.
and at the steep rise in ir with the low state of charge.this is partly how fuel gauges in devices determine state of charge.
i am using a esr meter for capacitors but it does well for telling me state of health of pulls i am grading.i can test a group of the same cells from many packs in different states of wear from new to totally worn out and tell you which ones are new,useable,or a waste of time to charge.
its also great for spotting fakes once you record the results of a known real cell.
your dc ir test is sound but test again with a charged cell.
and dont expect this to match the ac test.esr meter=ac milliohmeter.
You did it right. :+1:
But here is a short cut.
In general, the internal resistance would be the change from open circuit voltage divided by the change in current.
(delta V/delta I)
In this case it would be (3.5V - 3.2V)/(2.37A - 0A) = 127mĪ©
You came up with a little less because you truncated your total resistance to 1.47 when it calculates to a little more than that.
Thanks for the feedback, guys. Itā€™s helpful.
good batteryļ¼Œif sanyo 14500p 840mah out of stock, choose it
