Thx, on monday I will update the app.
Nice weekend, mcpat
Nice weekend, mcpat
Who knows which device the golden one in the top left corner is?
And where is it available to buy?
Recently i found out about the round shaped device in the lower right corner, It’s the POWER-Z wireless charging receiver board (BG001):
Much appreciated, thanks!
I found YZXStudi products on eBay from >14 different sellers.
About which seller are you talking?
Is there some table that lists all the options and which each product has? Hard to keep track of, especially in english.
Thank you for your data. Need one more day, but it already works here for the zl1100, but chart need one day for developing…
Yes, Franky Tong helped me translate!
translated values Model,ZY1276,ZY1275,ZY1273,ZY1272,ZY1271,ZY1270,ZY1266,ZY1265,ZY1263,ZY1262,ZY1252,ZY1231,ZY1230 Nickname,Power-Z,?,?,?,?,?,?,? Display Type,TFT,LCD,OLED display size,1,44",0,96",1,3",0,96",0,91" Appearance...
Also check out the feature list:
https://docs.google.com/spreadsheets/d/1Dt—1kYYWxLFXcx3aZOOw8ely4mi9wtXAj397A9XvdI/edit#gid=696514437
staticx57:Is there some table that lists all the options and which each product has? Hard to keep track of, especially in english.
YZXStudio device list translated - Google SheetsAlso check out the feature list:
https://docs.google.com/spreadsheets/d/1Dt—1kYYWxLFXcx3aZOOw8ely4mi9wtXAj397A9XvdI/edit?usp=sharing
Ah, thank you thank you thank you!
I do believe the second link is broken though. Looks like the 1276 vs 1275 is a lesser model except for amp capacity
I can’t seem to find the power banks anywhere. Does YzxStudio still make them?
I guess that means no, the YzxStudio power banks are no longer available. Unless someone has a link to one
mcpat:Thx, on monday I will update the app.
Hello there,
Updated the app:
should work with the ZL1100 load?
sample rate can be defined in settings, also path and logformat
But chart is not finished yet, therefore I removed the icon until finishing this function.
Regards
Patrick
Nice! I’ll give it a go tomorrow when I get back home from the Netherlands.
Please download again, I fixed a small bug… Forget the chart icon, it displays something, but it is not working.
You’re welcome
I updated the second link again, no idea why it doesn’t work. Checked all permissions at google sheets, everything the same as the file in the first link.
But you’ll find the information here too:
https://aliexpress.com/item/YZXstudio-color-meter-USB-current-voltage-capacity-fast-charge-QC4-0-PD3-0-PPS-trigger-tester/32829743426.html
So there is no more YZXStudio power banks available now.
I got the last one from Franky, but sad to hear this great powerbank isn’t available anymore.
KAAYEE:So there is no more YZXStudio power banks available now.
Hi! Franky Tong here I’ve known about this forum through my customers for a while and finally decided to register for an account so I can post directly
I contacted YZXstudio just now and they told me there’s no plan to stop producing their power banks (perhaps it was another product KAAYEE was referrring to?). They will continue to make and improve them. I’m not sure who else would sell and ship them outside of China though.
Second link doesn’t seem to work for me too. Possibly because the first one is “usp=sharing” while the second one is not?
maukka: mcpat:Thx, on monday I will update the app.
Hello there,
Updated the app:
sample rate can be defined in settings, also path and logformatBut chart is not finished yet, therefore I removed the icon until finishing this function.
Regards
Patrick
Thanks! Was wondering if the DataExplorer opensource app can also be configured to work with the ZL1100 load tester?
Hi and welcome to BLF Franky Tong. Thanks for the update. :+1:
I‘m not the developer of Dataexplorer, and I don‘t prefer Java. So do you miss a feature in my app?
Not working for me with ZL1100. Says time out after trying to connect, same as with the original version.
