staticx57
(staticx57)
October 16, 2017, 4:26pm
97
Is there some table that lists all the options and which each product has? Hard to keep track of, especially in english.
mcpat
(mcpat)
October 16, 2017, 6:30pm
98
Thank you for your data. Need one more day, but it already works here for the zl1100, but chart need one day for developing…
angerdan
(angerdan)
October 17, 2017, 4:56pm
99
Yes, Franky Tong helped me translate!
translated values
Model,ZY1276,ZY1275,ZY1273,ZY1272,ZY1271,ZY1270,ZY1266,ZY1265,ZY1263,ZY1262,ZY1252,ZY1231,ZY1230
Nickname,Power-Z,?,?,?,?,?,?,?
Display Type,TFT,LCD,OLED
display size,1,44",0,96",1,3",0,96",0,91"
Appearance...
Also check out the feature list:
https://docs.google.com/spreadsheets/d/1Dt—1kYYWxLFXcx3aZOOw8ely4mi9wtXAj397A9XvdI/edit#gid=696514437
staticx57
(staticx57)
October 16, 2017, 11:46pm
100
Ah, thank you thank you thank you!
I do believe the second link is broken though. Looks like the 1276 vs 1275 is a lesser model except for amp capacity
RobertB
(RobertB)
October 17, 2017, 12:09am
101
I can’t seem to find the power banks anywhere. Does YzxStudio still make them?
RobertB
(RobertB)
October 17, 2017, 2:17am
103
I guess that means no, the YzxStudio power banks are no longer available. Unless someone has a link to one
mcpat
(mcpat)
October 17, 2017, 10:53am
105
Hello there,
Updated the app:
should work with the ZL1100 load?
sample rate can be defined in settings, also path and logformat
But chart is not finished yet, therefore I removed the icon until finishing this function.
Download here
Regards
Patrick
maukka
(maukka)
October 17, 2017, 11:09am
106
Nice! I’ll give it a go tomorrow when I get back home from the Netherlands.
mcpat
(mcpat)
October 17, 2017, 2:56pm
107
Please download again, I fixed a small bug… Forget the chart icon, it displays something, but it is not working.
angerdan
(angerdan)
October 17, 2017, 5:03pm
108
staticx57:
You’re welcome
I updated the second link again, no idea why it doesn’t work. Checked all permissions at google sheets, everything the same as the file in the first link.
But you’ll find the information here too:
https://aliexpress.com/item/YZXstudio-color-meter-USB-current-voltage-capacity-fast-charge-QC4-0-PD3-0-PPS-trigger-tester/32829743426.html
I got the last one from Franky, but sad to hear this great powerbank isn’t available anymore.
Hi! Franky Tong here I’ve known about this forum through my customers for a while and finally decided to register for an account so I can post directly
I contacted YZXstudio just now and they told me there’s no plan to stop producing their power banks (perhaps it was another product KAAYEE was referrring to?). They will continue to make and improve them. I’m not sure who else would sell and ship them outside of China though.
d_t_a
(d_t_a)
October 18, 2017, 3:41am
110
Second link doesn’t seem to work for me too. Possibly because the first one is “usp=sharing” while the second one is not?
d_t_a
(d_t_a)
October 18, 2017, 3:45am
111
mcpat:
Hello there,
Updated the app:
Download here
Regards
Patrick
Thanks! Was wondering if the DataExplorer opensource app can also be configured to work with the ZL1100 load tester?
MRsDNF
(MRsDNF)
October 18, 2017, 4:20am
112
Hi and welcome to BLF Franky Tong. Thanks for the update. :+1:
mcpat
(mcpat)
October 18, 2017, 6:00am
113
I‘m not the developer of Dataexplorer, and I don‘t prefer Java. So do you miss a feature in my app?
maukka
(maukka)
October 18, 2017, 2:11pm
114
mcpat:
Not working for me with ZL1100. Says time out after trying to connect, same as with the original version.
mcpat
(mcpat)
October 18, 2017, 4:15pm
115
I will add variable timeout setting, now it is fixed 2 seconds.
But the other zy is working or also broken? Can you please try to connect with putty? So when putty is working, then my app is fault, otherwise it‘s your zl1100. Anyone else here with a zl1100 for testing?
Regards
Patrick
Edit: my zy only times out when I display the chart screen on it, other screens don‘t cause a Time out
maukka
(maukka)
October 18, 2017, 4:36pm
116
Putty or any other terminal program works fine with the ZL1100. ZY1270 also works with the new version.
RobertB
(RobertB)
October 18, 2017, 5:37pm
117
iloveelectronics:
Welcome to BLF Franky. If you happen to find out who could sell the power banks, let us know. I would think someone could sell quite a few of them if there was a solid place to buy them from, especially if they were converted to English.
angerdan
(angerdan)
October 18, 2017, 7:38pm
118
Yea, great to have you here Franky :+1:
